Hi
Thanks for using FixYa. This
might have happened due to over-voltage. Please check the power supply unit for
swollen/bulged capacitors and burnt wires/components on the power supply board
of your TV. You should try and turn off the TV for 8-10 hours to reset it. Please
make sure to turn off and unplug the TV for at least 1 hour (this
will drain off current from all components especially capacitors) before you
perform any repairs. Also note that the TV consists of very high voltages even
when it is in OFF condition. All this is only recommended if you have
electrical expertise and know how to solder/re-solder components. Please do accept the solution if the issue is resolved
or else revert for further assistance.
Thanks
Rylee
I believe its the power supply board that has gone bad and needs to be replaced. The cost of repair will be around $200-$300 including labor if you get this done by a professional. As I said blinking light itself states that the power supply has gone bad. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
May be you can take the back off the TV and blow all the dust off then inspect the power supply board and all the other boards for any blown capacitors however, still I would recommend to take help from a professional instead of doing it yourself just to avoid future issues. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
thanks for your response. I am not an electrician. I did look at the components and did not see anything obvious, but I am not sure what capacitors are? I will try the 8-10 hour reset. Any other advise for a novice?
not sure if I sent my reply correctly. Did you receive my response....if so, where do I go to receive your response on the web site. (new user)
thank you. Is there any other visual inspection that I should do to determine if it is something simpler than what you suspect?
yes. as much as possible..nothing solved.
