Question about Brother MFC-8220 Fax
Error Message: Scan Unable A6
Just bought the Brother MFC-240C and, after trying to send in the product registration using the fax feature, got the 'Scan Unable A6" error message.
The troubleshooting section of the manual says the cause might be that the machine has a mechanical problem or that there is a foreign object. It suggests that I open the scanner and remove any foreign object, then, disconnect the machine for several minutes. I tried both! There doesn't appear to be any foreign objects and unplugging the machine didn't help much.
What should I do next?
Getting same Machine Error A6
  • Anonymous Feb 18, 2009
    errore 6a
I did not. The solution is a new scanner head which is almost as much as a new machine which I bought at Costco. I'm using my old machine for printing until it wears out, the new one for copying and faxing.
Norm
Posted on Aug 16, 2008
Did you get the solution to the problem u mentioned
How to clear the memory on a brother mfc-240c-- error when faxing is out of memory
You can also try to send the fax with Real Time Transmission ON so that memory will not be full.
Sending in real time for all faxes
a Make sure you are in Fax mode . b Press Menu, 2, 2, 3. 3.Real Time TX Realtime TX:On
c Press a or b to choose Realtime TX:On or Realtime TX:Off.
Press OK.
Please click Yes if this helped
Thanks,
vikroks
Feb 05, 2011 | Brother MFC 240C All-In-One InkJet Printer
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
PRINTING...
Have you unplugged the printer for a few minutes to clear the memory ?
Jan 21, 2009 | Brother Multi-Function Center MFC-240C...
Print unable see trouble shooting and routine maintenance
sending fax is working alri.ght, only when I try to recieve fax it gives an error 30 on the display. At the same time it unable to clean. Please help me with this.
Jan 17, 2009 | Brother Multi-Function Center MFC-240C...
Brother mfc-240c printer error message unit unable 43
http://support.brother.com/g/b/faqend.aspx?c=gb&lang=en&prod=fax2440c_us_eu&faqid=faq00000168_003
Jan 06, 2009 | Brother Multi-Function Center MFC-240C...
I am getting an A6 error on my brother MFC8220
The a6 error is Scan Unable, So i assume your trying to scan something? Dont know how to fix it, But i figured id try to help by giving you the meaning to the error code.
Nov 25, 2008 | Brother MFC-8220 Fax
MFC-8220
Its the CIS unit. Part number LE7949001. $70 retail price.
Aug 15, 2008 | Brother MFC-8220 Fax
Cannot Send or Receive Faxes
here you might find an answer:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_top.htm?reg=us&c=us&lang=en&prod=mfc240c_all
Mar 29, 2008 | Brother Multi-Function Center MFC-240C...
the scanner or main circuit board is defective. Give it back to dealer due to warranty.
Jan 12, 2008 | Brother Multi-Function Center MFC-240C...
Error message unable to print
Send it back. The printhead voltage is innnnn disorder. Netxt will be Error 41 (Every Error starting with 4 means probs with printhead and in 99,9% the head has to be changed and cant be fixed!)
Sep 20, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC-8220 Fax Logo
2,945 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
