Question about EliteGroup L7VMM2 Motherboard
Can I put a 4x/8x AGP card on this motherboard? Also can I upgrade the memory to 1 Gig of PC2100 SDram Non-ecc unbuffered?
  • samjr67 Feb 06, 2010
    So I can't use an AGP card, I can't find a 4x card anywhere. I Can use a pci card i guess but need one with shader support. Any ideas? My son wants to use Microsoft's Flight Simulator X on our older desktop. AMD Athlon 2400+ XP 1.8 mgz
  • 644 Answers
The AGP (graphics port) only takes 4x on this motherboard, you can upgrade the memory as far as 2 gig, so yes you can upgrade the memory to 1 gig pc2100.
Posted on Feb 06, 2010
Testimonial: "Thank you for your help"
  • jimnuggats Mar 31, 2010
    You can still use a 8x graphics card as long as it will run at 4x which most graphics 8x do, but it will not fuction to its full pertential.
Compatible memory at 2gb capacity and video card for asus p5pe-vm motherboard
Hi, you can download a manual here at asus:
http://www.asus.com/Motherboards/Intel_Socket_775/P5PEVM/#download
Dual Channel Memory Architecture
2 x 184-pin DIMM Sockets support max. 2GB DDR400/333/266 non-ECC, unbuffered DDR RAM memory
1 x AGP 8X slot.
Hope this will help you.
Aug 14, 2011 | ASUS P5PE-VM Motherboard
P4vp-mx can support dual core proscessor, 2gb. ram and 512 video card
http://www.asus.com/Motherboards/Intel_Socket_478/P4VPMX/#specifications
1 x AGP 4X (0.8V, 1.5V only) (graphic card AGP)
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
Memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory 2 x 184-pin DIMM Sockets support max. 2GB PC2100/PC1600 non-ECC DDR SDRAM memory
and if you click on the CPU Support List you see that it does not support Dual core processor :(
May 06, 2011 | ASUS P4VP-MX Motherboard
How to know that the ram can match with your motherboard?
This motherboard supports DDR200/266/333 SDRAM
The memory needs to match one of these numbers so:
DDR200
DDR266
DDR333
one of these types will work
This motherboard will support a maximum of 4GB of memory.
Apr 13, 2011 | ASUS VIA KT333 Chipset A7V333...
Ram support for intel 845 motherboard
Hello. this website will show you the supported RAM for your Motherboard.
RAM Support
Hope this helps!
Apr 11, 2011 | Intel D845EPI (INTELKD845EPILPAK10)...
Helo mr
Hello you mainboard support Memory configuration:
Dual-channel memory architecture
4 x 184-pin DIMM sockets support up to 4GB of unbufferred non-ECC 400/333/266 MHz DDR DIMMs
so it wont support DDR2
and for the VGA
it is
1 x AGP 8X
so you can put only up to vga card to 8x and no pci express or something like that WILL NOT BE COMPATIBLE TO YOU BOARD
OK
CHEERS
UTTAM
Jan 22, 2010 | ASUS P5P800-VM Motherboard
I wish to add RAM in the PC. Mine motherboard-Epox-EP-4BDA533(I). ID(identification)-05/09/2003-i845d-6A69VPA8C-00. On it costs RAM 256Mb -DDR PC2100 266Mg FSB-400Mg. How many Mb it is possible to add....
Manufacturer Specifications - EPoX EP-4BDA533I Number of Slots:
Slot 1
Slot 2
Each memory slot can hold DDR PC2700,DDR PC3200 with a maximum of 1GB per slot.*
*Not to exceed manufacturer supported memory.
  • 184-pin DIMM Banking: 2 (2 banks of 1)
  • Chipset: Intel 845D
  • Error Detection Support: ECC and non-ECC
  • Graphics Support: AGP 4X
  • Max Component Density: 512Mb
  • Max Unbuffered DDR SDRAM: 2048MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR SDRAM only
  • USB Support: 1.x Compliant
Q: What memory goes into my computer, and will a faster speed be backward-compatible?
A: DDR memory with support for DDR PC2700,DDR PC3200 speeds.
Because DDR memory is backward-compatible, you can safely upgrade your system with any of the guaranteed-compatible DDR speeds listed below, even if your manual calls for PC1600 or PC2100 speeds.
Q: How much memory can my computer handle?
A: 2048MB.
Adding the maximum amount of memory will improve performance and help extend the useful life of your system as you run increasingly demanding software applications in the future.
Q: Do I have to install matching pairs?
A: No.
No, you can install modules one at a time, and you can mix different densities of modules in your computer. But if your computer supports dual-channel memory configurations, you should install in identical pairs (preferably in kits) for optimal performance.
Q: Does my computer support dual-channel memory?
A: No.
Your system does not support dual channel.
Q: Does my computer support ECC memory?
A: Yes.
Your system supports ECC. You can put non-ECC modules into an ECC system, but be sure not to mix ECC and non-ECC modules within a system. Install the same type of modules that are already in your system.
Jan 13, 2010 | ASUS Intel 845D Chipset P4B266 (P4B266-PA)...
Upgraded ram to 2 gig from 4 X 256k
what system or motherboard you have ?
possible it don't support 2gig ram
try 1 stick of ram
Apr 10, 2009 | Computers & Internet
P4S8X-X motherboard. Latest list of compatable RAM 1.gb
  • Chipset: SiS 648
  • 184-pin DIMM Banking: 3 (3 banks of 1)
  • Max Unbuffered DDR SDRAM: 3072MB
  • Error Detection Support: Non-ECC only
  • Graphics Support: AGP 8X
  • USB Support: 2.x Compliant
  • Jul 06, 2008 | ASUS Computers & Internet
    New graphic card
    ya go for it it will may lower card specks if u have any limitations but your ok agp 8x 4x slot
    Jan 24, 2008 | Computers & Internet
    Memory swap
    This is the memory specs for your board 4 x 184-pin DIMM Sockets support max. 4GB unbuffered non-ECC PC3200/2700/2100/1600 DDR SDRAM memory Dual-channel memory architecture
    Jun 08, 2007 | ASUS P4S800D-X Motherboard
    EliteGroup L7VMM2 Motherboard Logo
    170 people viewed this question
    Top EliteGroup Computers & Internet Experts
    David
    David
    Matthew Spark
    Matthew Spark
    Jerry Umali
    Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
