Question about Maytag MZD2766GES Side by Side Refrigerator
Ice accumulation on the bottom of the freezer
There is a sheet of ice on the bottom of the freezer floor. Sometimes there is a puddle of water on the floor next to the freezer.
    Sergeant:
    Champion:
  • 263 Answers
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Posted on Feb 06, 2010
This can be coming from the icemaker. If there is ice underneath the ice tray, it can be from the water inlet freezing up. This can be due to a small leak in the electronic water valve for the icemaker, allowing the water to drip slowly in. If you suspect this, clear out the ice, remove the ice bin and the ice maker itself. If the water entry hose then accumulates ice over the next day, replace the water value.
Posted on Feb 15, 2010
Ice maker leaking
Are you sure it's the ice maker that's leaking? We have this model & ours accumulates a HUGE iceberg in the bottom of the freezer, but the water seems to be coming out of the back, at the bottom of the back panel, where the vents are.
Jun 29, 2010 | Maytag MSD2732GR Side by Side Refrigerator
Water puddle on floor from inside refrigerator could it be defrost heateris bad? water accumulates in the bottom of freezer and freezes seems to come out of evaporator/fan location
unkink the drain hose...I just opened up the back of my Frigidaire Side by Side counter depth to find the drain hose was bent and collapsed coming right out of the bottom of the freezer and the pan was dry as a bone. It doesn't look like my drain hose has ever drained a drop of water. The freezer bottom is full of ice And the rust and chipping paint under the bottom of the freezer door along with the mysterious puddles of water every morning means the drain system definetely never worked. Frigidaire should be responsible for this. This, along with the ice maker rebuild I had to do,... after ice was spilling all through the fridge. I actually had warrantty left on that one and called customer support in India to find out I could make the repair myself. Yep I had to do it. Frigidaire you failed.
Jun 12, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Water is accumulating and freezing on the bottom of the freezer
YOUR DEFROST DRAIN IS PLUGGED, YOU NEED TO REMOVE THEBACK PANNEL THE DE-ICE THE BOTTOM TRAY TO FIND A HOLE, YOU NEED TO CLEAN IT OUT UNTIL YOU CAN RUN WATER THROUGH IT.
Apr 26, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I have a maytag bottom freezer refrigerator model#mbf1956keq
apparently its the way the maytag defrosts. I have had this issue since I bought it. FIrst of all, you dont have to go through the whole defrosting process with water on the floor and removing your freezer contents. Simply take a butter knife and from the front corner, slide it under the edge of the ice and the whole sheet can be slid out intact right under the freezer door. I think it had alot to dowith having the humidity switch on, because when it isn't like in the summer when the AC is running, the amount of ice is not that bad.
Apr 04, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
Water accumulates and freezes at the bottom of our freezer. Once the bottom of the freezer has formed a slab of ice the water eventually drains out of front of freezer and leaves a good size puddle on our...
your refrig. goes through a periodic defrost cycle whereby this water is produced. It is supposed to travel down to the evaporation pan near the floor of the frig. Your evaportation pan may be clogged, remove the front lower panel and get a flashlight and examine it., or the tube leading from the freezer floor may be clogged or have ice it it. Check that out and if the opening of the tube has ice in it, melt it with a hair blow dryer
Oct 06, 2009 | Refrigerators
Our GE side by side model GSS25SGRE is leaking water toward the front of the unit. We have pulled it out to see if it was condensation and that is not the problem. At times there is a lot of water that...
okay, my name is marclavoris, what happens is your refrigerator goes into defrost, the heaters comes on and melts the freon off the coils, the water goes down in the drain, which you will see on the freezer side at the very bottom of freezer, you may need to take off inside back panel to access the hole. it is clogged up with alot of debri, so when it is backed up, it overflows under your bottom tray, it then goes into defrost again and it pushes water on your floor. To solve problem, clear the drain in the freezer
Sep 12, 2009 | Refrigerators
Freezer icing over at bottom and leaking onto floor
Hi, You will need to remove the rear panel in the freezer and then remove the ice build up in the drain pan. The drain hole will have ice down in it.Make sure all the ice is gone and then flush the drain hole out with hot water (a basting serenge works great)
This should take care of your water problem.
If I can assist you further, please let me know and please rate me response so that other as well as my self will know how I am doing.
Thanks
Vic
May 22, 2009 | Refrigerators
Water accumulating in bottom of freezer and leaking onto floor
Yes the drain is clogged and the water that supouse to go through became ice so it make it worse.Put hot water in the drain hole until it runs through,it'll go to an evaporative pan on top of the compresor to keep it warm and vaporize the water.
Apr 04, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Maytag MZD2766GES Side by Side Refrigerator Logo
730 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
