Question about Xerox Phaser 8560MFP Laser Printer
I wish to use the 7-day free support: A plastic arm near the end of the paper travel has broken. The part is about 3 inches long, is visible when I lift the platen deck (as if I need to add ink, and is on the left side. There is a matching arm on the right side. Paper jams result whenever I try to print a page, because the roller that is visible raises up in the printing process, to deliver the paper back into the machine for dual sided printing, or to send the paper to the output tray (I may have the order of these things incorrect). Also, I expect that after about 1 and 1/2 years of use since I bought the machine new, the machine probably needs cleaning. My question is: where can I take the machine to repair this part and to have the machine cleaned. Should I take it to an authorized service repair place? Where can I find an authorized service center near Baltimore/DC? Do I have to go to Xerox for this?
  • Gary Christoph Feb 20, 2010
    How do I figure out the part number for this part? Can I find a free Xerox 8560 manual or repair manual online, to know how to get at this part?
  • 583 Answers
You can either order the part yourself directly from Xerox if you feel you have the expertise to replace it... otherwise, here is a link to a reputable service company in your area that can provide the repair service you need.
http://www.rotcsolutions.com/
Posted on Feb 07, 2010
  • Mark Tidwell
    Mark Tidwell Feb 20, 2010
    I usually use this website http://www.sparepartswarehouse.com/Xerox...
    I've linked directly to the 8560 page above. You can also contact these guys and describe your broken part as you did above and they can usually tell you if the part can be ordered and replaced separately or if it has to come as part of an assembly.
Shifter wont shift
Hi, Anonymous and the usual suspects are:
1. Clutch not disengaging.
2. Bent shift shaft.
3. Shift fork bent or seized.
4. Gear seized on the shaft.
5. Gear positioning lever binding.
6. Shift return spring weak or broken.
7. Shift return spring pin loose
8. Shift mechanism arm spring is broken.
9. Shift mechanism arm is broken.
10. Shift drum is broken.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
yz85 transmission not shifting after bottom end rebuild Yamaha 2 Stroke
Dirt Rider Magazine
YAMAHA YZ85 LC Owner Service Manual
OEM parts for Yamaha
YAMAHA YZ85 Owner Manual
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 18, 2014 | 2004 Yamaha YZ 85
Tip
Printer will not feed paper
Printer would not feed paper no matter how many sheets were in the bin or how clean the printer. I even cleaned the roller. The issue was I just needed a little more tension on the roller that pulled the paper in.
I removed the rear access door (see manual). Off to the left near the feeder roller you will see a spring. What I did is mover the spring to the END of the plastic arm that it is attached to (if it is missing ..you have a bigger problem). If you have moved your printer around a bit, the spring may have slipped down on to the arm and is no longer sitting at the end. This will extend the spring another 1/16 of an inch ...and that is all all it took for me. My printer will now feed a single sheet of paper with no issues. BTW: I put a drop of glue on it after so it would not slip off.
on Aug 30, 2008 | HP PSC 1610 All-In-One InkJet Printer
Hp2300 jams half way out of tray 1 and tray 2
1. Up to where paper traveled.. If its reached up to Fuser assembly & curl folds accrued under cartridge.. replace Teflon sleeve or Fuser assembly.
2. If paper traveled up to Fuser out(near 2-3 inch)...Clean/replace/flag Fuser out paper sensor
3. If paper traveled up to registration assembly:Clean registration sensors/flags.
4. Check pickup rollers.
Feb 20, 2013 | HP LaserJet 2300 Printer
1988 Kawasaki VN 750 Vulcan will not shift
1. Improper clutch adjustment or not disengaging.
6. Shift return springs weak or broken.
11. Shift lever loose on the shift shaft.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
http://www.vn750.com/forum/26-transmission-rear-end/1601-shifter-not-working.html
Shifting problems Kawasaki Vulcan Forum Vulcan Forums Kawasaki VN 750 Service Manual
OEM Parts for Kawasaki
1989 Kawasaki Vulcan 750 Owner Manual
Mar 29, 2012 | 1988 kawasaki VN 750 Vulcan
Burnt smell from clutch when im in 3rd gear
It sounds like the clutch is close to being worn out as the pressure plate is not gripping the clutch plate with sufficient force when power is applied. Before you consider replacing any thing, first check the clutch free travel adjustment because as the clutch plate wears the free travel does decrease and if there is no free travel, then there will be some releasing action on the pressure plate allowing cluth plate slip. Hydraulic setups are usually self adjusting but you should check the free travel of the clutch pedal which should be about 3/8 to 1/2 inch measured at the pedal rubber. This is done by adjusting the push rod that links the pedal arm to the piston in the master cylinder. Adjust by first loosening the locknut on the rod at the end where it attaches to the pedal arm and turning the rod in either direction to obtain the correct free travel. One adjusted retighten locknut.
For a cable setup there should at least 1/8 inch of free travel of the cable before it starts to move the clutch fork on the outside of the bell housing. To adjust, hold the operating fork so that the release bearing is touching the fingers of the pressure plate. You will need to turn the cable adjuster so there is only about 1/8 to 1/4 inch of free travel of the cable where it attaches to throw out fork before it starts to move the fork when the pedal is depressed.
If all adjustments are correct and clutch is still slipping then the pressure plate diaphragm spring has lost its tension and /or the clutch plate has worn down to the rivets. Either way you will have to do a complete clutch rebuild.
Oct 28, 2010 | 1989 Volvo 240
Printer problem
even a very small piece of paper (A small piece torn off a jammed sheet) can cause the sensor arm to stick in place giving a false paper jam. Double check the entire paper path (what is visible) using a flashlight.
Also, check for broken "flag" sensors. Basically a flag sensor is a small piece of plastic that is pushed out of the way when the paper is traveling through the unit. If one of these flags is broken it may display a paper jam error as well (The flag after paper travels through will drop back into the paper path.) If this is broken it will not trigger the sensor and thus the error condition exists..
Most likely you have a small piece of paper stuck inside the paper path somewhere.
Do not, I repeat do not use any sharp or pointed metal objects to remove any small paper from within the fuser unit, the fuser covers are very delicate and such poking and prodding will likely damage the fuser covers, causing bad print quality or drastically decrease the fuser life (a small tear will quickly render the fuser useless).
Hope this helps!
Aug 31, 2009 | HP Office Equipment & Supplies
Canon PC770 - paper tray wouldn't slide in all the way
Thats right that spring help to counter balance the top,the pease of plastic is to keep the spring in place.There are 2 spings that support the top.That plastic is not so expensive but to install the new plastic and spring is a very big job and it can be expensive.It normally takes me 3 hours to replace.The mashine can work normally it is only a hassel when you want to replase the toner .
Jun 16, 2009 | Canon PC-920 Black and White Copier
Sun visor on 2005 Nissan Murano won't stay up/falls down
go to a dealership with a screwdriver and your broken sun visor in hand. take out a nissan murano with an interior that matches yours for a test drive and perform a switch on the sun visors. install your broken visor in place of the one that works, and take the one that works out of the car that your test driving.
Problem solved, its free, and you didn't have to get creative to fix the problem. Plus, they can't blame you for a broken visor considering that they fail in these cars all the time. You're welcome!!!
Jan 12, 2009 | 2005 Nissan Murano
Xerox Phaser 8560MFP Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
