Question about Radio Communications
Walkie talkie symbol stuck on cannot remove it
Walkie talkie symbol stuck on cannot remove it /or is there a factory reset button motorola xtr446
  • 4 Answers
In order to reset the radio, power on while pressing both volume buttons (+ and -) together with the PTT (speak) button, until you year a high-pitched tone.
But I have found that the "stuck on receive" problem is related to the battery voltage: non-rechargable AAA or incorrectly charged batteries can give 0.2-1.0V above the nominal voltage. Try to leave the radio open for a few hours or replace some of the four AAA batteries with slightly exhausted ones and see if that helps.
Posted on Sep 19, 2012
  • CMAZ Sep 24, 2012
    I've try to exchange batteries between a working one and one with the stuck symbol, and the problem stay on the walkie talkie (not following batterie).
  • Radio Commun... Master
  • 1,654 Answers
The symbol you are describing indicates you have the radio on HI power. It will not go away unless you reprogram the radio to LOW power, or change to a low power channel. Here is a link to the user guide: http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTNiD/Static%20Files/XTNiD%20Manual%20EN.pdf?localeId=252
Best regards.
Posted on Feb 06, 2010
  • 21 Answers
This is a fault in the receiver which requires a component replacement. Protea Electronics can sort this for you. Needs to be done in a workshop.
Posted on Feb 12, 2013
Motorola xtr446 not receiving
Check your interference eliminator code. It must match on both radios.
Best regards.
May 18, 2014 | Motorola Walkie Talkies 2-Way Radio
How to disable time-out time on Motorola walkie talkie
Press volume up then volume down and then menu, keep all three pressed at the same time until the handy comes on. Then press the tone button, the handy will start to display all symbols at the same time. When finished the timeout will be disable
Apr 24, 2014 | Motorola Walkie Talkie 2-Way Radio
Xtr446
Sounds like a receiver fault. Could be you need a new filter
Nov 22, 2012 | Motorola Walkie Talkies 2-Way Radio
Motorola XTR 446 talkie walkie is not receiving
Try programming the radios without an eliminator code and see if they work together then. If so, there is something wrong with the eliminator code portion of the radio. Also, check your batteries, switch batteries between the units and see if the problem moves to the other unit. It takes more energy to transmit than receive, so a bad or very weak battery could exhibit a similar problem. The radio icon will illuminate whenever a radio is transmitting or receiving. When the radio is in standby mode, the icon should not be shown. Your radio with the icon on all the time may be stuck in transmit. Check your PTT button to see if it is slightly stuck or depressed. Here's a link to the user guide http://www.motorola.com/web/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103
Best regards.
Jun 24, 2012 | Radio Communications
I have a motorola cp 110 walki talkie .red light comes on but no beep or commuunication
If you have no initialization beep when you turn the radio on, it is likely the radio is in need of repair. Immediate things which come to mind are a sticking PTT button, something stuck in audio accessory jack, or a bad speaker. You might check the radio using a second radio and see if you can transmit.
best regards.
Nov 08, 2011 | Motorola Walkie Talkie 2-Way Radio
We have a set of 6 XTR446 about 2.5 years old. 3 of the handsets are (for no apparent reason) displaying the little handset icon permanently and not operating (either to receive or transmit). One of the...
But I have found that the "stuck on receive" problem is related to the battery voltage: non-rechargable AAA or incorrectly charged batteries can give 0.2-1.0V above the nominal voltage. Try to leave the radio on for a few hours or replace some of the four AAA batteries with slightly exhausted ones and see if that helps.
Jan 11, 2011 | Motorola Walkie Talkie 2-Way Radio
My motorola xtr446 has an icon stuck on it and no one else can hear me when i speak out? how do i get rid of the icon? the icon is a mini walkie talkie
The mini walkie talkie emblem has a variety of meanings. If the emblem has parenthese around it your PTT (push to talk) button is depressed, stuck or partially depressed. If the emblem does not have parenthese your radio is in receive mode, awaiting a call.
It is possible you do not have your radio programmed identical to the other radio(s). Your frequency and interference code eliminator must be identical to those used in the other radios. Here is a link to the manual where you can check this http://www.motorola.com/staticfiles/Business/Products/Two-Way%20Radios%20-%20Unlicensed/_Documents/XTR446/Static%20Files/XTR%20Manual%20EU.pdf?localeId=103 Look around page 7 for instructions.
Also, if you find your radios are programmed identically, the other problem might be bad or low batteries, as it takes more energy to transmit than to receive.
Best regards.
May 15, 2010 | Motorola Walkie Talkie 2-Way Radio
I have 4 motorola walkie talkies but no
The Motorola GP340 radio is a dealer programmable radio. It requires a cable, radio interface box and Motorola proprietary software (which is available by subscription to dealers and qualifying entities).
Oct 13, 2009 | Motorola Walkie Talkie 2-Way Radio
The power button on the talkabout is jammed into the on position so the walkie will not charge or turn on. How can we fix this or where can we get it fixed?
Please open the set with the help of screw driver , & check for functionality of switch , & remove any particle that is jamming PTT button . You can check the functionality of walkie talkie by pushing the PTT inner switch with the help of a screw driver.
Sep 02, 2009 | Motorola Walkie Talkie 2-Way Radio
Radio Communications Logo
3,075 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
