Question about RCA D52W19 52" Rear Projection Television
Rca hdtv d52w19b
When i turn on the tv, the green power light comes on, and then goes out, i never get a image
  • 1030 Answers
SOURCE: RCA Projection TV won't turn on
Ok you got you a Rca ITC222 I See ALOT of these things. To start the troubleshooting.. UNPLUG the set for a min of 30 min the plug back up. ( I have never seen this work) If the set stil fails to come on then you have a processor lockup. The first thing you can conclude if the light flashes is it is NOT a FUSE. THe sets processor has determined that a safety condition has occured and shuts it down to prevent further damage and fire. THe top cause of this include Horizontal output trasistor, flyback transformer and high voltage splitter. but There is about 25 different failures that can drive it into shut down. technicains have interface equipment that can read errors codes much like a car.
typical repairs on this set run 150 to 350... if you have to replace tubes...250 per tube +labor which runs 250 ... these set new cost 800 so unless under warrenty.. you got to determine if it is worth it.
Posted on May 12, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA hd50lpw62a green power light
That set is famous for faulty flybacks. But its an easy inexspensive fix that takes under 30 mintues to do. You can get a new flyback at the following link for around 50 dollars and they provide free online tech support so you can do the repair yourself. You would need flyback number 259296 heres the link.
http://servicemanuals.vstore.ca/
Posted on May 15, 2008
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
lighty comes on three times no picture no sound
Posted on Nov 30, 2008
ladywinn
  • 5138 Answers
SOURCE: 52 inch rca big screen tv will not come on
ck capacitor cp150 if it is bad replace 2 other caps in same circuit 2200uf 16v -220uf35v cp111 cp114?
Posted on Dec 09, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
My rca tv d52w19b dont turn on
There may have been a power supply failure.
Apr 15, 2014 | RCA D52W23 52" HDTV CRT TV
I have a 52" rear projection TV. D52w19b. Green
Make sure you resolder the flyback and recheck any RCA fuses that may be blown - they are usually near the flyback. If this does not help check the site www.tvrepairkits.com for repair kits or tips for your projection tv model.
Apr 27, 2013 | Televison & Video
RCA D52W23 HDTV; WHEN WE TURN T.V. ON THE GREEN
most likely its the smsp /deflection board for the shut down
there are some caps in the power supply cp 140 cp120 cp114 look at them and see if there puffed up
they will need to be replaced
this could also be a flyback transformer that has failed or a ribbon connector
this where you will have to look for caps first the trouble shoot through it
then you you can addresse the cmp1 issue but id guess thats the ribbon connector causing that one
Nov 01, 2009 | RCA D52W23 52" HDTV CRT TV
RCA D52W19B makes high pitched buzz when on
Sounds like a coil is vibrating or a component is bad causing the transformer to whine. Could possibly just need soldering.
Jul 08, 2009 | Televison & Video
RCA TV Will Not Power On - Powered Off Suddenly
Theses sets had 2 problems pip mod or most of the time Flyback Transfomer bad.
Jul 13, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
May 31, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
