Question about RCA D52130 52" Rear Projection Television
Blue censor not working
Blue censor needs replaced
Replaced cam censors still won't start why
U need to run a datastream..code reader is general..cars are really complex now. If theyr aftamarket parts..computer may not recognize them. Or issue is somethin unrelated. A vehicle specific scantool is required. Seek a privateshop
Oct 26, 2016 | Cars & Trucks
I have changed both oxygen sensor and spacer also the coolant tempature sensor and the check engine light is still on in my 2005 Audi Quattro 1.8t what else could be wrong?
P0420 means that the catalytic converter is operating below efficiency threshold. Normally, you only get this code if both O2 sensors ARE OPERATING PROPERLY. If you change the O2 sensors and still get the same code, it's an indication your catalytic converter needs to be replaced. But before you replace it, ensure that everything else in the engine is operating properly, so that whatever may have damaged your current catalytic converter doesn't damage a new one.
Apr 10, 2017 | 2005 Audi A4
I REPLACED O2 CENSORES AND THE MAF CENSORE
Check wiring, animals love to chew them.
May 19, 2013 | 2000 Nissan Xterra
MY RADIATOR FANS WON'T WORK
check wires to tempature censer, follow wires from fan to censor if there ok replace the censor, be sure to disconnect the battery first.
Sep 07, 2012 | 1989 Nissan Stanza
When u get to 35 or 40 MPH the car starts chugging. We replaced wires- throttle censor.temperature heat censor.map censor. What else could be the problem?
I see you like replacing computer sensors. Did anybody try something really high-tech like performing NORMAL MAINTENANCE? You know, high-tech stuff like replacing a fuel filter?
Nov 16, 2011 | 1992 Chevrolet Lumina
2006 chevy colorado abs light on changed left speed censor
if you broke sensor wire at the electrical connector.the dealership more likely can get you another sensor connector with new wires splice in new wires and connector.
Nov 12, 2011 | 2006 Chevrolet Colorado
My middle button is not working it is stake
Most common problem of this phone is the censor or the navigator due to water damage or dropping the phone in high place etc.
Check this procedure :
* Remove the back cover of the your phone.
* Remove the battery.
* you can see a screw with a metal shield in the middle part. Unscrew the screw using a T6 precision screw driver and remove the metal cover.
* you will see a flex cable connected on the socket and that would be the censor or navigator we're looking for.
* check and clean the socket or connector with a solution or lighter fluid together with a cotton.also clean the socket of the censor. then put it back and assemble it then try if it's working.
If it's not working, then needs a censor replacement.you can buy to any parts dealer or distributor nearest you. this is so easy to do so you don't have to bring it to a mobile phone technician for replacement just to save service fee and discount on parts too..
Good luck and thank you for visiting fixya.
Jun 22, 2011 | RIM BlackBerry Curve 8520 Smartphone
My '95 Bonneville is running rough and idling low and is shutting off and is very hard to crank
This probably is the mass air flow censor located just behind the air cleaner in the metal part of the throttle body. Wiggle the connector if it stumbles or shuts off the connection inside the censor is bad. You will need to replace the censor.
Jul 12, 2009 | 1995 Pontiac Bonneville
O2 censor
You would use an oxygen censor socket to repair that. You can buy one for pretty cheap or you can rent one from the parts house. You'll want to disconnect the electrical connection to the O2 censor, slip the socket over it (using the appropriate ratchet) and take it off. You can also use a 7/8 inch wrench on most cars if you can get it in there.
Apr 27, 2009 | 1989 Ford Crown Victoria
Cranks but wont turn over
you know. i took it to a mechanic and actually.... The timing belt cut the Crank Shaft Censor... So it was the crank shaft censor again. The wires were routed wrong from the first mechanic that "fixed" the car.
Aug 01, 2008 | 2000 Hyundai Sonata
RCA D52130 52" Rear Projection Television Logo
20 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
