Keyboard and caps lock
I turn on my caps locks and as soon as I use shift the caps lock turns off. I can't keep my caps locks on.
  • B1RD Feb 21, 2008
    I have tried 3 differant keyboards
  • Anonymous Mar 18, 2014
    CAPS LOCK NOT TURN OFF AND ON
    Genius:
  • 1,019 Answers
Due to the fact that the two keys are both together, i,d say that theres some muck under the keypad, thats sticking the 2 keys together. Try blowing air into the keyboard. Or put a vacuum cleaner on the keypad.
Don,t hold me responsible if the Vac, sucks the keys or Keyboard Up :)
Mike @ Compurepair.
Posted on Feb 21, 2008
TURN OFF CAPS LOCK DELL SK-8185
Click on the Caps Lock button ;) if that wont work, then for lower case just use shift and the wanted letter
Aug 04, 2012 | Dell y530k - Slim Black Usb 104-key...
Letters are all capital caps lock is off
you may have the Shift lock activated. keep pressing the shift key numerous times at a fast rate to bring p a prompt to deactivate it.
Failing that, you may have a stuck caps lock button (even if the led is off...yes it can still be stuck) so replace it
Oct 20, 2011 | Acer NSK8458AN Keyboard
THE CAPS LOCK ON MY KEYBOARD ON AND OF IT SELF.
The most likely thing is that the users themselves have inadvertently
pressed Caps Lock. This is especially likely for anyone who learned to type
on a typewriter (and you can even configure Windows to make the Shift key
turn off Caps Lock just as it does Shift Lock on a typewriter). If this is a
real problem, there is a setting in the Windows Accessibility Options to
sound a tone whenever Caps Lock is turned on or off.
Any doubts you can get in touch with a technician through
www.thebestpcdoctor.com
Toll Free: 877 407 9229
Aug 11, 2011 | HP Mini 1000 Netbook
THE LOCK DISPLAY FOR CAPS LOCK IS TURNED OFF. HOW MAY I TURN IT BACK ON. ASPIRE 7551G-5755
Thank you for using fixya.
Here's what you need to do to turn on CAPS LOCK. Just press the button in keyboard that says "CAPS LOCK". It's located in the left corner in between the TAB and Shift button.
I hope this helps.
var geo_Partner = '82910b1e-9b92-42fd-b83f-fa09a0787ae7'; var geo_isCG = true;
Mar 03, 2011 | Acer Computers & Internet
My caps wont turn off
Try this. Press: Start>Accessories>Accessibility>On Screen keyboard. Try turning it off from there. If that doesn't work:
1. Choose Start'Settings'Control Panel and double-click Regional and Language Options.
2. In the Languages tab, click the Details button.
3. In the Settings tab, you should see a button called Key Settings. It may be grayed out. If it is, click the Add button and add another keyboard layout (it doesn't matter which one). Press OK.
4. Back in the Settings tab, click to make sure your original keyboard is highlighted and press the Key Settings button.
5. Now under To turn off Caps Lock, click the radio button next to Press the Shift key. Click OK.
6. Click OK twice more to exit the other two dialog boxes.
Jan 13, 2011 | HP Computers & Internet
TRY TO ENTER MY EMAIL ADDRESS WHEN TRY TO PUT IN PASSWORD BLACK DOT APPEARS AND SIGN SAYS TURN OFF CAP LOCKS DONT WHERE CAPS LOCK IS ON THIS LAPTOP
Caps Lock will be on the left hand side of the keyboard and probably above the shift button and below the tab button. It's usually labelled as 'Caps Lock' or as an arrow pointing up.
Sep 03, 2010 | Acer 90.46907.001 Keyboard
The Shift Lock is stuck in the CAPS position. When I turn it off it goes off CAPS but as soon as I hit the shift lock for caps which I need to do, I can't get it back to where I can type numbers, which I...
Sounds like the shift key isn't entering. Try both shift keys and see if one will turn the light off. If so tou need a keyboard rebuild. It may be cheaper to replace it.
DickyO
Aug 16, 2010 | Brother EM-530 Typewriter
My keyboard acts like the shift button is down but when i plug in a usb board it does the same thing.
Check if the CAPS LOCK is on. The key to toggle this is right above the left Shift key (next to A). There is usually a light with the indicator near the top of the keyboard (other lights for Num Lock and Scroll Lock).
You can tell if it is a Caps issue if the pressing the numbers above QWERTY give the numbers not !@ etc.
I hope this helps.
(you should turn off the computer and clean both keyboards. Sometimes, some dirt gets into the keyboard and triggers stray signals. There are a number of cleaning products that work; just make sure the keyboard is dry before turning the computer back on.)
Jul 14, 2010 | Toshiba Computers & Internet
Stuck caps lock condition -- even if caps lock LED is off
disasemble the key board and clean it very well unplugged from pc of course..keyboards can go quick with a slight drop to the floor and will mess up buttons..walmart has them for 15 or 20 bucks..if all else fails.
Jun 09, 2009 | Apple Computers & Internet
Caps lock won't turn off by pressing the caps lock key
Ok, here ya go.
Start-->Control Panel-->Clock, Language and Region,-->Change keyboards or other input methods
Once the window pops up...
Change Keyboards -->Advance key settings-->Now select "press the CAPS lock key" option
Hit apply and OK.
If this works, don't forget the "fixya" rating! Let me know okay?
Apr 03, 2009 | Computers & Internet
Computers & Internet Logo
Alun Cox
David Payne
David Payne
