Question about Watches
Have a Bulova watch, age unsure it is quite old still working but not keeping good time, seems to be gold, has three buttons one for winding, one for alarm, the other unknown, would like to get repaired to work properly and would like to appraise
    President:
  • 2,501 Answers
If you go to their web site "boluva.com", select your area, then click on one of the pictures, at the top of the page is a menu.
Select "dealer locator" to find your nearest dealer of if there is no convenient to get to, go the "service center" to find the address to send it to for repair.
Posted on Feb 07, 2010
Wich battery number may i use in this watch bulova 96t63 ??thanks
cant see that model watch on the Bulova web site user manuals
http://www.manualslib.com/brand/bulova/watch.html
if unsure if it needs a battery go to a jeweler or watch or battery seller
some model Bulova Watched instructions
IF YOUR NEW WATCH IS A MECHANICAL WATCH
(no battery)
Mechanical watches differ from Quartz watches in several
respects:
1. No battery changes are needed - they are powered by a main-
spring, which is wound either by wrist movement; or in some
models by daily winding of the setting crown.
2. Because it is a mechanical device, it's accuracy is subject to
the effects of gravity and temperature. You can expect, on the
average, a daily variance of up to 10 to 20 seconds for
mechanical watches.
3. Just like automobiles, these watches require routine mainte-
nance. Due to their mechanical complexity, mechanical
watches require cleaning and new lubrication every 3 to 5
years to run at optimum efficiency.
FOR THE AUTOMATIC SELF-WINDING
MECHANICAL WATCH
it must be wound at least six or seven times before you wear it.
After that, your daily activity should wind the watch sufficiently
to keep it running at night when it is not being worn. If your
normal daily activity is not sufficient, occasional supplementary
manual winding may be necessary. It is suggested that your
mechanical watch be cleaned and oiled periodically to insure
optimum performance. As a mechanical watch, quartz watch
accuracy cannot be expected. References to the power cell do
not apply to Automatic watches
May 02, 2016 | Bulova 96T53 Watch for Women
Any idea what a Bulova watch, 14K white gold, number on back case 962158. Any idea what it is worth?
I'd need more info. First, is it a "real" Accutron, made from '60 to '77, or is it one of the things Bulova kept calling Accutrons after they stopped making the tuning fork movement watches? The quartz so-called Accutrons are just a nice old watch, not worth anything special. The self-wind "Accutrons", which Bulova is making now, are just a nice, mid-range aurtomatic watch. On the back of Bulova watches is a date code, usually right under the serial number (SNs themselves really mean nothing where Accutrons are concerned). The code is a letter and a number. If it begins with the letter M, or if it begins with the letter N and is followed with a 0, 1. 2. 3. 4. 5. or 6, it is a "real" Accutron, and is collectible. Some with N7 (1977) are also, but it depends on the actual watch. Bulova did make some quartz so-called Accutrons in '77. If it's a '60 thru '76, and SOME '77s, it has value beyond the scrap gold price. SOME Accutrons are even worth thousands of dollars. White gold Accutrons, compared o yellow gold or stainless, are rarer. Next, WHICH Accutron is it? is it a 214, a 218, a 219, a 220, a 224, or a 230? If it's a man's watch, it is very unlikely to be a 220 or 230 series, If it does not have a winding stem on the side, it is a 214. 214s are the most valuable. If it has a setting stem at 3 o'clock or 4 o'clock, it is either a 218 or 219 (I'd have to open the back and look at the movement to say which ine). If it says "Accuquartz" on the face, it's a 224 (NOT a quartz - the 224 Accuquartz is a hybrid of tuning fork and quartz crystal). Once we know the movement series, we need the case type. Certain cases are much more valuable than others. Then there are the Spaceview, the Astronaut, and the Deep Sea, 3 specific models they made, which are more valuable than most (but not all) of the other cases. The best I can say right now is that, being white gold, there's a good chance it's one of the more desireable specific models. If it's a 214, ESPECIALLY if it's a 1960 (M0), it's worth quite a bit more than just the gold content. To be more specific, I'd have to see a picture of the watch, which I don't think can be posted here. Try looking up "Accutron" on Ebay and see if you can find one that, if yours has a stem, has it in the same place as yours, with the exact same case - same shape, and exact same lugs (the things on either end where the band or strap is attached). Read the description. The description will probably say the movement (214, 218, etc - in fact, the movement may even be in the listing title) and if it is niot just a plain round case, probbly will say the case type (Alpha, Asymmetric, Butterfly, etc.). If it's an Astronaut, a Spaceview, or a Deep Sea, it will certainly say that. Also, look at the Accutron section of the Bulova entry in Wikipedia. (Yeah, I wrote it, but it has info that just might help you pin down exactly what you have) When you find out more about which Accutron it is, post another question under Axcutron watches here. I'll check every couple of days for the next week or so, and if I see your post, I'll narrow down the value some more.
Sep 17, 2013 | Accutron Swiss Watch by Bulova 26B44
I have antique womans gold nugget bulova watch with 014ko and 890643 on the back of the watch should I throw this away
Don't throw it away! Bulova have a good reputation. It ma not be worth much, but you have the serial number and the 14k probably means it's 14 carat gold. 14 carat old is the highest quality used for watches (18 carat is too soft for everyday wear) I used to work for Shackman and we made watch cases and bracelets for the major brands such as Omega.
Trysearching for Bulova watches on eBay then looking at 'completed listings' under 'advanced' after you search for some idea of value.
Regards, Andy
Dec 21, 2012 | Bulova Watches
BULOVA ACCUTRONE E66831 M8 14KT WIND STEM AT 4 OCLOCK NEED TO KNOW IF IT IS WORTH MORE THAN THE GOLD CASE THANKS
The M8 indicates this watch was produced in 1968 and probably sold for 250-350,this is a tuning fork watch and they are highly collectible and worth up to twice the value of the gold or more depending on the model and condition
Nov 20, 2011 | Accutron Swiss Watch by Bulova 26B44
I have a Bulova Watch that was given to a Clark Candy employee with a Serial Number of 523791. Looking for what year it was made and is it worth anything
The value of your watch depends greatly on the model / style, age, and case composition. It goes without saying, but watches (of any mechanical quality) that have real gold cases right now are worth quite a bit more than watches with gold plated, gold filled, gold-tone, or stainless steel cases. Presentation watches like those given to employees upon retirement were often gold or gold-filled--but there's a world of difference in value between those two types of watches.
In terms of age, it's much easier to date vintage Bulova watches by their "year code" than by their serial number. If you look carefully, usually above or below the serial number, you'll see a little alphanumeric code, like L5, N3, or P6. These can be translated as follows:
Lx = 195x Mx = 196x Nx = 197x Px = 198x Tx = 199x
Pre-1947 Bulova watches used little symbols to show the year of manufacture. A picture of those codes can be found here, as well as elsewhere on the Internet:
http://www.manleyhorlogerie.com/Watch_History/bulova.htm#Bulova%20Date%20Codes
Jul 24, 2011 | Bulova Watches
Bulova Millenia 100 m,stops running,move it to wind,starts up
When you say "wave wind" do you mean you're waving it around to wind it with the self-winding mechanism? If so, that will only keep it running briefly as you're experiencing. Manually wind the crown about 40 turns clockwise to "fill the tank" and wearing it daily will keep it topped off. Anytime you don't wear it for a day, manually wind it again. As for the cleaning, the inside of the watch doesn't get real dirty but over time the lubricants wear out and thicken which makes the watch run slowly or not as long as it has to work harder to move the gears through the thickened lubricant. A watchmaker can disassemble and clean the old lube out with solvents and then reassemble the watch with fresh lubricants.
Apr 27, 2010 | Watches
Wondering what a mid 1940s womens gold boluva watch is worth serial number c-632162
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get age of conan gold with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Jan 07, 2010 | Bulova Vintage/Antique watch: Gold Filled...
Vintage Caravelle runs fast
A quick look at ebay shows plenty of Bulova watches and only a few looking for a worthwhile price.
I think if you have it repaired for sale it probably won't be worth the effort or expense. If the watch has sentimental or nostalgia value to you I think that is what would make it worth getting a good watchmaker to look at it.
Sep 19, 2017 | Caravell Bulova Caravelle watch
BULOVA U.S.A. MOVEMENT CALIBER 10AK, 21 JEWELS, HANDWIND.
Do not wind it more that about 8-10 turns at a time, do this at bed time and mid day it will give you years of reliable service. If I can be of fiurther assistance do not hesitate,.... ask
Sep 08, 2008 | Bulova Men's Watch
Rolex runs down
sounds like you need a new watchmaker, Your watch is designed to be worn 16 hours a day an rested for 8 while you sleep and this should keep it running. there are several different mainsprings that can be installed depending on the age and your activity level. I would be happy to take a look at it for you.
Donald McPherson
Certified Watchmaker AWCI
www.finewatchmaking.com
Oct 09, 2007 | Bulova Watch
Watches Logo
29 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
