Question about Denon AVR-684 6.1 Channels Receiver
AVR 684 was working normally then shut off with rapidly flashing red led. Have allowed to cool overnight, tried different power sources, disconnected speakers etc, etc. Any ideas?
  • jeff krus May 11, 2010
    I would try resetting the microprocessor. 1)turn off the . 2) press while simultaneously pressing and 3) once the dsplay stars flashing at intervals f about 1 second, release the wo buttons.
  • 506 Answers
The unit more than likely has a fault in the power supply or the output stage. Common switching power supply problems are the FETs used for switching fail or the PWM generator fails. Output circuits can be configured many different ways. The trend these days is to use integrated high power amplifiers for each channel instead of discrete push pull amplifier stages.
Posted on Feb 11, 2010
My rx 675 wont turn on. the red stand by light flashes and that is it.
Try holding the 'tone control' and 'info' buttons and pressing power. This should allow the unit to turn on. See what the front display says at that point. I tshould show some kind of protect code. If the unit turns on and stays on normally after that, then you may have had a temporary problem that was cleared by disconnecting everything. If it turns back off right away, then you will have to get it repaired as something internal has been damaged.
Jan 03, 2015 | Yamaha Audio Players & Recorders
How do i know if my jazzy power charger is working
Without the charger the batteries would go dead. You could put a voltmeter across the batteries and you should read more than 28 VDC while charging.
Nov 16, 2012 | Electric Jazzy 1115 Power Wheelchair
Panasonic PTL500 LCD HIDEF projector - Unit occasionally powered up briefly, lamp lit, then shut down, standby LED flashed orange/red. Sometimes lamp lit and sometimes not. Technician diagnosed bad ballast...
The bulb is a discharge type - it needs a very high tension to work. The role of the ballast board is to convert the low voltage DC current coming from the power source in a high tension DC current for the bulb. Unfortunately you were truly unlucky : when the ballast board died it sent a high tension surge thru the power source and from there at the other components on the mainboard - the processor couldn't handle it and got fried. So now when you try to start the projector this is what happens: the power source starts normally - the status light goes to green as it should; it functions normally so it powers the ballast board and the rest of the mainboard - the ballast works so the bulb lights up; the mainboard on the other hand remains dead because the processor is dead so no sustain signal is sent to the power source; without the sustain signal the power source goes, as it should , in an very normal stand-by - the status light goes to red.
The entire mainboard will have to be replaced - you can't replace just the processor, it's glued in there. This is going to be expensive so ask a quote before doing it.
Dec 23, 2010 | Televison & Video
AVR-1802 5.1 Channels Receiver: My Denon AVR-1802 LED is flashing rapidly. I have...
replace all the electrolytic capacitors in the power supply. i had the exact same problem with mine and once i replaced the capacitors it powered up and stayed on and worked perfect.
these capacitors tend to fail as they're of poor quality.
this fault is very common on denon receivers, especially the later models.
hope this helps?
May 16, 2010 | Denon AVR-1802 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
Power Button Flashing Red
Try unplugging the entire unit and letting it sit for 5 minutes. See if this helps. If not, you need to do a complete reboot, which will cause you to lose your settings, but will probably solve your problem. To do a complete reboot, you will need to hold down two of the front bottons on the front panel. I'm not sure which, so either consult your manual or see other posts here which describe the reboot process for Denons. Hope this helps.
Dec 14, 2008 | Denon AVR-1908
Flashing leds no picture
when You changed the bulb  you have to reset the bulb timer , that why the light is flashing red , look at your manual and reset the timer , and the picture , changed bulbs myself before i found what the problem was ,
Mar 25, 2008 | Sharp XR-10X Multimedia Projector
Power on problem
Time for a little repair here. It seems that one or more channels have developed an excessive drain on the supply, and has caused the threshold to trip and shut you down. It's more than likely shop time at this point....accordianman
Sep 03, 2007 | Denon AVR-2106 Receiver
Denon AVR-684 6.1 Channels Receiver Logo
135 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
