Question about Bell Technology Techsolo Slick Stick MP3 Player
When i put a battery in the mp3 a blue screen come up and it just show waiting but no matter how long i wait it won't work and if i plug it into the computer the computer won't even detect the mp3 player and i didn't even have it for long
Then ******* fix it *****
Posted on Feb 08, 2010
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
After a bios update my screen gone blue and froze there and i had to turn it off by the power button. After that my netbook seems to turning on but neither the screen or the hd are working. The screen is...
Remove power supply and pull battery, press and hold the power button for 10 seconds. Then wait a minute, put battery back in, and plug in and try it again.
May 26, 2010 | Computers & Internet
Not sure if player is charging
QUESTION ONE:
Can you see it in "My Computer"? It will show under "Removable Drive/Storage"
QUESTION TWO:
Double click the removable drive to open the folders. Can you see your music, photo and movie folders?
QUESTION THREE:
Can you see the player in Coby Manager - under the "DEVICE" tab?
QUESTION FOUR:
When disconnected from the computer, how long can you listen to the Coby player before it goes off?
If not present in My Computer or in Coby Manager/Device Tab, then it is not plugged in correctly.
a. Disconnect the player from the computer.
b. Wait for it to cycle through "Please Wait" and "Updating Library" screens.
c. Make sure the player is TURNED OFF
d. With player TURNED OFF, reconnect wire to the player then to the computer.
e. You will see a USB connector icon on the player screen and the player charging.
It will appear to be charging all the while it is connected to the computer.
After it has been plugged into the computer for an hour, it should be well charged unless the battery is completely run down. In that case, you need to do an initial 8 hour charge - with the coby player OFF - through the computer. (This one got me when I first got my player!)
f. Use the Coby Manager to disconnect the player (Found HERE CobyMedia Manager fix for MP822 (Windows XP/2000/Vista)
1. Open Coby Manager
2. Go to the DEVICE TAB
3. CLICK on EJECT Button in lower right hand corner.
4. It will have a pop-up screen to ask "Do you want to eject?" Click YES.
5. The second pop-up screen will tell you "The device can now be safely removed from the system."
6. Disconnect the player from the computer.
7. The Coby will now show "Please Wait..."
8. It will take the Coby about 10 minutes on the "Please Wait" screen and then on the "UPDATE the Library" screen - Be PATIENT
You should now have enough battery power to use it. To check the battery level,
1. Turn on the player
2. The battery icon is in the upper right hand corner of the screen - it is ALWAYS RED until it starts to go down... I've not had mine down very far, but believe the red line gets shorter as the battery is wearing down.
Hope this helps.
Apr 07, 2010 | Coby MP-610 MP3 Player
Nothing but the blue ring lights up
ok..idk if this will work but it might...first turn off the sansa...then turn the hold switch on (it should turn red). hold down the record button on the side of the player..then while still holding that hold the power button down...but keep holding them untill a screen shows up saying something about recovory mode..itll say to plug in the usb..u could do that..idk it that will work..it it doesnt instead of plugging in tthe usb in the computer..wait about 15 seconds after the recovory mode screen shows up and then hold down the power button for about 15-20 sec...then itll go all black (including the blue light) press the power button again like u would to turn it on...and everything should be back to normal..hope this helps...:)
May 04, 2009 | SanDisk Sansa e250 MP3 Player
My imate mobile is not loading
I DID FIX THIS PROBLEM ON MY IMATE!!
1.) Remove the Battery
2.) Press at the same time Power Button and volume ( - ) at the same time then put the battery back while still holding the buttons.
3.) Wait for 3 secs., then let go.
it worked for me. hehehe.
Mar 25, 2009 | i-mate Jama 101 Smartphone
Screen won't show and no damage to it
you should wait after that hit it on the rug (not to hard) if it doesn't work srry that's how i got mines back on
Feb 03, 2009 | SanDisk Sansa e260 MP3 Player
Battery Problem???
Ok it takes a while but heres the solution. Slide the hold button to ON and hold down the REC button.While still holding the REC button,connect the USB port and wait for your PC to find it. Once it has found it type this link in to download Firm Ware. It may take a while but it is worth the wait.Once it is downloaded to your player EJECT!!! the player before disconnecting the USB port.Now just wait for it to format yor player and it should be working good as new again. =)
Mar 06, 2007 | SanDisk Sansa e260 MP3 Player
Sansa m230 freezed
Call suport at 1-866-ScanDisk. Choose MP3 and then option 3. Tell them your problem. They will have you try a few things and then send you to the retailer where you bought it for posible exchange. That is my story so far. I will be at Staples in the morning.
Dec 29, 2006 | SanDisk Sansa m230 MP3 Player
Bell Technology Techsolo Slick Stick MP3 Player Logo
109 people viewed this question
Top Bell Technology Audio Players & Recorders Experts
Computer Repairing
Computer Repairing
Are you a Bell Technology Audio Player and Recorder Expert? Answer questions, earn points and help others
