Question about Kitchen Ranges
Dacor oven model: CPO 230B Rotary control, part number 86068
Factory says part no longer made; looking for part and / or a company that can fix it. Only problem with entire oven is this rotary switch. Is there a company that has salvage ovens or ability to fix. Facing the need to spend $5,000 for new oven because of $300 part.
  • 1 more comment
  • Jim222 Feb 21, 2008
    Part number is Dacor 82811
  • foodmeister1 Nov 10, 2008
    I need Dacor rotary switch # 82811
    Bob
  • Gary Davd
    Gary Davd May 11, 2010
    looking i will get back to ya
CG Industries will remanufacture the part for you for 112.00. Here is the web site.
http://www.cgiltd.com/www/cgiweb.nsf/PublishedTopic/Major%20Appliances?OpenDocument
Posted on Oct 16, 2008
Thanks for your help
Posted on Feb 23, 2008
Dacor Oven model # CPS127 - part # 13158B - discontinued. How to find
More than likely your not going to be able to find a part once its been discontinued, especially if its been that way for a while, but there is an alternative though. There are companies that specialize in rebuilding control boards, etc that have been discontinued and are no longer available. I would contact a company like appliance parts depot or another major distributor because they will have the numbers you'll need to contact those companies, but remember, whatever the cost of the part was is nothing compared to the cost they charge to remake the part.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Jun 21, 2012 | Dacor Ovens
Dacor Preference RSD30 Gas Range My wife put the
I don't see the make and model number of your unit. I only see part of your post. Please post the make and model number. It should be a simple fix. From what I do see in your post, it sounds like the control board will need to be replaced.
Regards,Richard
Oct 17, 2011 | Dacor Ovens
When oven is heating up a massive bang occurs. Sounds a bit like a gun shot. Also hinge on glass top are broken - where can we purchase parts to fix this.
The loud noise is either from sheet metal expanding under stress or an electrical arc. I recommend unplugging the oven, taking the back off, and inspecting the wiring to the oven heating element and the sheet metal near the wiring. Also inspect the plug and socket, oven control and the oven heater element itself for similar problems. If you see signs that arcing has occurred (burn marks, especially with melted metal), repair the wiring and reroute it if necessary to prevent arcing.
If you don't find anything, first make sure the oven rests firmly and levelly on all four feet to eliminate any twisting stress. If there is a problem here, the noise should go away after one or two more cycles once you fix it. A twist in the oven could have something to do with the broken hinges. In the worst case, you may have to loosen and tighten a lot of sheet metal screws to relieve stress in the assembly. It would best if you could locate where in the oven the noise is produced before doing this.
I was unable to find any reference to parts for your model. Please look for the model label either on the doorframe or inside the drawer under the main oven door and verify the complete model number. Also look at the hinges for a part number stamped on them. There are a number of on-line appliance parts stores that carry Dacor parts; you should be able to find something with a search for "Dacor" and the part or model number.
Jan 17, 2011 | Dacor ECS130 Epicure Electric Single Oven
HAve an older model dacor oven model w305. bottom heating element went out. REpair man said that type of element is no longer manufactured. It has a ceramic plug, just plugs in new ones are wired. Do I...
I just found 3 on Ebay. put in search dacor element. You will need the part number or you can email them if it will fit yours. goodluck
Oct 16, 2009 | Ovens
The display panel for the oven control of our Dacor Model RSD308 Duel Fuel Range suddenly stopped displaying correctly. The display panel shows parts of numbers and letters so you cn't read temperatures or...
Once the display board stops showing the numbers and functions, you have to replace it. You could try and turn the breaker off to it. Sometimes this will reset the main board unit.
Feb 26, 2009 | Dacor Preference RSD30 Gas Kitchen Range
Dacor Double Oven
HI - I just had the same problem - repairman came and reset the breaker in the oven which "tripped" (even tho I havent used the lower oven in months).  Read posts here on other Dacor ovens which explain how to get to the reset switch to avoid having $150 in repair costs - I have not tried that myself tho but good luck!
Nov 08, 2008 | Dacor ECD230 Epicure Electric Double Oven
How to find discontinued Dacor oven part?
Here's a link with a pdf file that lists your part #82810 for $202.31. http://ww1.dacorservice.com/PartsCatalog/docs/Links/2.pdf. The date on the pdf is 6/12/08. You can also locate a dealer or authorized service providor for Dacor applicances at: http://www.dacor.com/Customer-Care/Locate-A-Servicer.aspx. Good luck!
Jul 20, 2008 | Ovens
Kitchen Ranges Logo
207 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
