Question about Dell PowerEdge 4400 Server
My poweredge 6400/700 server unable to boot on CD and Floppy even I change the boot sequence on bios and add different cd drive or floppy
  • 542 Answers
Try clean the CD drive using CD lens cleaner and then boot with OS CD and recover your OS.
Revert back for more assistance and give your valuable feedback/rating for the solution provided.
Thank you for using Fixya.
Posted on Feb 15, 2010
Dell poweredge 830 cd-rom unknown bios
Enter the set up (BIOS) menu by tapping the F2 key. Hold down the <Alt> key and depress the <E> then the <F> keys in succession. This will force the motherboard to load default settings and also force the motherboard to redetect all IDE devices. Note: The selection for the floppy drive will be set to ON. If you do not have one then you must disable floppy in set up (BIOS) menu.
Apr 13, 2012 | Dell PowerEdge 830 Server
How should the BIOS be set up?
This is the recommended way to do it.Turn on your computer and press F2 to enter the system setup. If you have problems with the Bios you have to get a Bios upgrade by getting software from dell then you can do the following.Reset the boot sequence to boot first from the floppy drive or the CD drive (depending on whether your flash BIOS update is supplied on floppy disk or CD).Insert the flash BIOS update floppy disk or CD, and reboot the computer. The computer updates the BIOS and then automatically reboots. mmediately press F2 to enter the system setup program, and reset the boot sequence to the normal setting. Then exit the system setup program.
Jan 09, 2012 | Dell Latitude C640 Notebook
It doesnt reconize my cd rom at boot and is not listed in bios
Jun 27, 2011 | Dell POWEREDGE 2400 Server
DELL POWEREDGE 6400 IS NOT BOOTING FROM THE CD
Go to your BIOS and change the boot sequence so that the system boots to the CD 1st. (You should see a tab or label that says Boot Order or Boot Device.)
Good Luck
C2S
Aug 13, 2010 | Dell PowerEdge 6400 Server
Unable to boot from cd
change the boot sequence first priority to cd and next to harsddisk.....
Feb 06, 2010 | Dell PowerEdge 700 Server
Trying to boot from external dvd drive
u must either have one of the foll...to boot and install OS...also the seq in BIOS must be availabe and enabled
1 Floppy
2 CD Rom Drive - internal
3 CD Rim Drive - External connected thru USB
4 You can also try to connect a USB pen drive having the OS install program and try - I have not tried that so not sure if this option works...sorry
5 If u can open the machine then u can connect another internal HD(this can contain ur OS install files) to the cable (connector points in the flat cable) that connect your internal HD to the Motherboard.
if i can think of anything else i will post
all the best
Dec 31, 2009 | Dell PowerEdge 2600 Server
Unable to boot to anything external.
Save yourself some trouble. Pull a CD/DVD drive out of another computer or just buy one. They are very cheap. Connect the CD/DVD drive to the server and install the OS as usual.
If you are lucky WS2008 will already have a compatible SCSI/RAID driver. Otherwise, you will need to press F6 and install the driver from the floppy.
If this helps please vote for my solution.
Sep 07, 2009 | Dell PowerEdge 2600 Server
Does Dell PowerEdge 4600 Server support DVD ROM
I am working on one of these now and yes, it should boot from DVDROM. Be aware that it is a notebook style drive and there are no onboard IDE or SATA controllers, so once the drive dies you're in for a wallet hit. Same goes for the floppy drive which is integrated with the DVDROM. Even worse, the presence of the broken floppy usually means a USB floppy drive won't help when loading windows drivers at install time.
Jun 05, 2009 | Dell PowerEdge 4600 Server
Compaq armada e500
you can safely install up to a 80 GB HDD in that compaq. When getting into the bios go to the boot sequence section and change the boot squence to be CD=>HDD=>FLOPPY or FLOPPY=>CD=>HDD
Jun 02, 2009 | Compaq Armada E500 Notebook
Boot from CD is not recognizing the Windows 2003 Server CD
hv u tried booting from other CDs .
if u can boot from other CDs , then this 2003 CD is botched , change it.
Jan 05, 2009 | Dell PowerEdge 1600SC Server
Dell PowerEdge 4400 Server Logo
103 people viewed this question
Alun Cox
