Screen blacksout screen blacks-out after a few minutes, if I tap the top of the tv the screen will usually come back, sometimes not
  • 1153 Answers
SOURCE: half black screen on projection tv
Sounds like the vertical area like Output, but I would look for bad caps first and resistors. In this area
Posted on Sep 14, 2007
SOURCE: Samsung HLR5067W
Faulty lamp could be, there is also a little blue switch behind the lamp door that needs to be in the down position.
Posted on Nov 19, 2007
  • 179 Answers
SOURCE: Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Posted on Nov 28, 2007
  • 395 Answers
SOURCE: 60" Mitsubishi Problems
1. NO VIDEO, BUT HAS VIDEO WITH PIP ON. CHECK C763 (1UF 50V) ON THE BASE OF Q715, LOCATED ON THE UCOM-PCB. 2. NO MAIN VIDEO, THERE IS VIDEO IN PIP ON EXT1 AND EXT2:-CHECK FOR 1VPP OF LUMINANCE ON PIN 1 OF IC7000, IF MISSING OR LOW CHECK THE VALUE OF C7001 (4.7UF 35V), LOCATED ON THE PIP-PCB. THIS CAP MAY LEAK ELECTROLYTE ONTO THE BOARD AND OPENED A FEED THROUGH IN THE PATH BETWEEN C7001 POSITIVE LEAD AND THE EMITTER OF Q7003 OR CAUSE INTERMITTENT COLOR. PART # 181P504090. (CHECK ALL 'SMD' ELECTROLYTICS AND TRACES ON PIP) 3. NO MAIN OR PIP VIDEO, CHECK C7014, 47 UFD 16V ON THE PIP PCB. PART # 181P502060 4. CHECK FOR 7.2V DC ON THE BASE OF Q7003, IF LOW OR MISSING. CHECK THE VALUE OF R7002 (150 OHM 1/10W).LOCATED ON THE PIP-PWB. PART # 103P401050 5. SUSPECT R2045/R2048 (6.8 OHM 3W) FOR OPEN/RAISED VALUE. LOCATED ON PCB-SIGNAL AT 5V REGULATOR IC2003 PIN 5.
Posted on Jan 21, 2008
SOURCE: LG 52SX4D turns off randomly.
My Lg 52"tv turn off and on
Posted on Aug 15, 2009
My tv blacksouts with no picture but has sound?
tried with resetting doesn't work?totally black screen or has a white screen display?
Sep 30, 2012 | Samsung PN50B430 50 in. TV
Picture keeps going out on Philips TV 47PFL3704D/F7, 2009 model. The sound stays on. It happens very randomly-may be fine for several hours, may happen every few minutes. Also happens when playing video...
I think that the connectors from the backlight inverter board that go to the LCD panel's backlight are a bit loose which explains why it comes back on when tapped. I am positive that unplugging and replugging the inverter cables should do the trick. WOuld like to do it yourself? It requires you to open up the tv ofcourse.
Jul 10, 2011 | Philips 47PFL3704D 47 in. LCD TV
Turn the TV on and a minute after the picture comes on the picture scrunches up to the top of the screen and colors are distorted. It the goes black. I turn the TV off and on and the picture is sometimes...
try to tap your tv slightly at the side if it go back to normal operation you have a weak solder commonly in the main board try to resolder parts that is slightly hung.
Oct 15, 2010 | Sony Televison & Video
Unwanted rectangular black area appears on screen blocking 40% of picture
This could be the result of a partly shorted vertical winding on the deflection yoak.Since the line is on an angle and not straight across.
Nov 07, 2008 | Durabrand DWT1304 13" TV
No picture, sound ok
I have a similar issue. Sometimes the entire screen goes black and sometimes only one-half - either the top or bottom half goes black. The only solution we have found is to gently tap the TV (usually the front side) and the picture will come back for awhile. It almost seems heat related as it only goes out after the first 10 minutes of use. There must be a fix to this.
Aug 25, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Trinitron kv-32FS100 Black screen periodically, with sound, light blinks 5 times
5 blinks means there is a short in hor.section or the power supply
about 200.00 --- 250.00
Jul 12, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Sometimes no picture on RCA tv
its nothing really, if your tv is new then it is normal but if it continued to do it then its broken
Oct 28, 2007 | Quasar SP-3233 TV
Half black screen on projection tv
Sep 14, 2007 | Televison & Video
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
