Question about Dryers
Tumbler doesn't rotate for Kenmore 76722 Gas Dryer
My dryer stopped working yesterday. It get shot and seems to be working but the tumbler doesn't rotate. I can rotate it with hand. Its Kenmore 76722 Gas Dryer. Do you think its a problem with the motor or the belt. How to fix it? Your help would be greatly appreciated.
    President:
  • Dryers Master
  • 2,651 Answers
Soulnds like the belt pooped, or broke, remove top you should see the belt wrapped around the drum, if not you need a new one
Posted on Feb 23, 2008
Dryer making loud vibrating noise
In all likelihood, the belt that runs the tumbler is loose, causing the tumbler to rotate off center. While it takes a few minutes, the front of the dryer should be removable and you can take the tumbler out and replace the belt.
Oct 11, 2014 | Amana Dryers
Hi i went into my dryer and pushed the tumbler the wrong way and heard something pop and now the tumbler doesnt rotate how do i get to the belt this dryer is very old but looks like this one .thank you oh...
You broke the belt. To replace it, pop the top ... use a screw driver. Remove the screws at the top of the front, remove the front, the drum will fall free. Take Pictures.
Feb 14, 2011 | Kenmore 65924 Electric Dryer
Tumbler not working
Please check to see if motor is okay or if the belt broke.
Nov 12, 2009 | Washing Machines
How do I check the fuse for my Kenmore dryer?
The 'thermal fuse' is down in the back near the exhaust vent and looks like a small fuse.
Nov 05, 2009 | Kenmore 63942 Dryer
Grinding noise from under tumbler
One of the retaining rings on the motor clamp/drum bearing assembly had probably broken, the machine must be taken apart to access to the motor/bearing assembly and fix the part.
The job should be done by a technician.
Using the machine in this condition can cause more damage to motor/ drum bearings.
Here is the diagram.
here you can buy the parts.
Feb 01, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore 90 series
possible burned out heat element
Jan 25, 2009 | Kenmore 73932 Gas Dryer
Dryer runs then stops.
IF LESS THAN 10-YEARS OLD/CHECK THE TUMBLER BELT AND BAND.IF 10-YEARS+ REPLACE YOUR MOTOR OR BUY A NEW DRYER.***ALSO UNPLUG THE DRYER AND MAKE SURE ALL YOUR WIRES ARE TIGHT.
Jan 17, 2009 | Kenmore 74602 Gas Dryer
Drum problem
While I don't know about your specific dryer, most dryers are set up the same. I just replaced the belt on my Maytag LDE8404ACE. It was easy. The hard part was cleaning out 14 years worth of lint and fuzz that coated everything inside. Here's the instructions:
1. Unplug the dryer or disconnect power.
2. Remove the front panel. There are two screws, each is about 4 inches up from the bottom of the front panel. Unscrew them. Then hold the front panel along the bottom edge and pull it away from the dryer. Once it's away enough, the clamps along the top will pop and disengage from the dryer. Be sure to note the wires connected to the door switch are connected to the dryer. Disconnect them if you need to move the panel away from the dryer.
3. With the front panel off, you should be able to reach inside the dryer to remove the old, broken belt.
4. Remove the tumbler from the dryer. It's held in place by the tumbler front which is secured by 4 screws, 2 on each side. That piece will pull straight out toward you. With the tumbler front out of the way, the tumbler itself will come straight out as well. I recommend taking it out and cleaning the inside of your dryer while it's open. A vacuum hose works great. Also, check the pulley and the back two wheels that the tumbler rests on to make sure they turn easily. If not, you may want to grease them. Also, it's normal for the idler pulley to appear to be loose and wiggle in place. Once a new belt is installed, it's under tension from the spring so any play that exists shouldn't be a problem.
5. put the new belt around the tumbler with the smooth side of the belt against the tumbler. Use the old belt marks on the tumbler to align the new belt. It's easier to hook the belt to the idler pulley and motor pulley from the back. So we'll get to that part in a minute. Just let the belt hang loose for now.
6. Reinstall the tumbler front and secure with the 4 screws you removed earlier.
7. Reconnect the wires to the door switch, if you removed them earlier.
8. Reinstall the front panel, reversing the steps you took to remove it in #2 above.
9. Go to the back of the dryer and remove the access panel along the bottom right hand side.
10. From there, reach in pull the dryer belt around the idler pulley. Then take the belt on the left side of the pulley and move both the belt and the idler pulley to the right, until you can get the grooved side of the belt onto the motor pulley. I've attached a diagram with instructions.
11. Once connected, manually turn the tumbler so that the belt will align and make sure the tumbler turns as easily as it did when you first removed it.
12. If the belt looks good and you've manually turned the tumbler at least one full revolution (to ensure the belt didn't get twisted), then plug the dryer in and turn it on to make sure it works correctly. If so, then re-attach the access panel on the back of the dryer. You're done!
Aug 28, 2008 | Kenmore 73952 Gas Dryer
Changing tumbler belt on a Kenmore gas dryer
you have to unscrew the screws in the lent trap and pull up on the top piece it has platic snaps the pop up then unscrew the front two on the front piece then the tumbler will pop out thats it.
Jan 12, 2008 | Kenmore 75944 Gas Dryer
Dryers Logo
269 people viewed this question
Top Dryers Experts
