Question about Toshiba 55H70 55" Rear Projection Television
Toshiba rear projection tv has broken/blurry picture. All menu items come up clear on the picture. Any ideas on how to fix it?
SOURCE: toshiba 50"rear projection hometheater picture shut off on/off light flashing
take the back off and change the fuse
Posted on Jan 31, 2008
  • 74 Answers
SOURCE: toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Posted on Mar 24, 2008
ahhsoo69
  • 167 Answers
SOURCE: Rear projection tv picture blurry
HELLO sounds like you need to adjust the focus pod on the fly back transformer. not the screens but the focus on the fly back transformer to see if that clears up the picture. hope this helps. "GOOD LUCK"
Posted on Aug 09, 2008
  • 4 Answers
SOURCE: Sony rear projestion TV has blurry picture.
sounds as if your convergence needs to be set. either through the menu on the tv or remote you need to get to the convergence set screen and you need to line up the crosshairs. this usually happens when the tv is moved or bumped.
Posted on Dec 31, 2008
egadgetguy
  • 258 Answers
SOURCE: picture off center on Toshiba 46" rear projection HDTV
On some models there is a picture position setting. One for horizontal and one for vertical. Don't mess with convergence, that probably won't help. Older models use knobs; new ones use the menu. Either way, you are looking for position adjustment.
Older sets, for each there should be size, hold, and position. Same for menus but it may have a picture that looks like one square offset on top of another.
Good luck. and if you need more help, please state the model #
Ken
Posted on Jan 01, 2009
Blurry Picture on Toshiba 65HX81
yes the tv has convergence problem u will need a tech to reposition it
Jul 11, 2013 | Toshiba 65HX81 65" Rear Projection...
My tv overall is blurry, but when I click menu to mess with the settings, only the picture of what I'm watching, and the highlighted word is blurry, but everything else is clear, video games and movies n...
Some of your electronics parts were worn out. Like capacitors may have leaks that need to be replace
as use stated that the word focus were very clear it means that your tube is still okay. or you adjust the focus knob on the compartment. To tune in the 3 colors.
Jan 01, 2011 | Toshiba 57H82 57" Rear Projection...
I have a Toshiba 65H82 and at first the picture was blurry but would clear up after about 10 mins now the picture just stays blurry. Can you tell me what the problem could be and if it is worth fixing it?...
Try adjusting the focus block this requires opening the back and front bezel of the TV. If it doesn't clear up after adjustment attempts then the liquid coolant inside each of the tubes need to be emptied and refilled with new coolant. Over time the coolant gets cloudy and can cause a blurry image with a white sheen. Contact me at the link below so I can help you further.....if this helps please rate:-)
Thank you:-)
http://tvtechwork.webs.com/
Oct 21, 2010 | Toshiba 65H82 65" Rear Projection...
Picture looks 3d and a little blurry
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
•Screen looks 3D
•Colors don't line up
•One or more colors can't be adjusted when using the convergence menu.
•Screen is bowed or warped.
•TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems
fcabb43.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya - CLICK HERE
Aug 17, 2010 | Hitachi 51F500 51" Rear Projection...
Sony rear projection tv is blurry and looks like 3D. Picture also will go black for a second or two now and then. Any ideas?
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 13, 2010 | Sony KP-61HS10 61" Rear Projection...
Toshiba 50H82 rear projection TV adjustment
The ser needs to be converged in the factory service mode
Jan 14, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba Rear Projection Screen Problem
It's a DLP right?
I think ur TV's bulb is dying...check the running hours of the bulb in the menu.
Rifaa
Nov 19, 2008 | Toshiba 62HMX84 62" Rear Projection HDTV
Picture blurry
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
try doing a magic focus
Dec 10, 2007 | Toshiba 43H71 43" Rear Projection...
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Blurry Screen
The bottom is blurry because some of the anti-freeze (clear ethelyne glycol) has leaked out. This anit freeze needs to be replaced or the CRT will get too hot and break. It will also clear up the picture.
Dec 05, 2006 | GE 46GW947 46" Rear Projection Television
Toshiba 55H70 55" Rear Projection Television Logo
81 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
