Question about Goodman GMS90703BXA Heater
Is there a warranty on the Inducer draft blower assembly
    Guru:
  • 415 Answers
Many Goodman products carry a 5 to 10 year parts warranty; however, they have to be replaced by a qualified contractor. The labor may not be included in the warranty. Your best bet is to contact your local distributor. Have your model and serial number ready when you call. They should be able to provide the installing contractor's name and offer some warranty information.
I hope you find this helpful. Good Luck!!!!
Posted on Feb 07, 2010
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
How do I replace draft inducer fan
Its Best to replace the whole assembly due to most of the hubs on the inducer blower wheel are rusted on to the shaft. the whole assembly has 3 to 5 nuts or screws that mount to the heat exchanger shroud. Pull the wire harness molex plug & pressure hose, then install new assembly.
Feb 28, 2015 | Tools & Hardware - Others
Bryant Furnace 350MAV code 31
Probably a failure of the draft inducer fan motor, draft inducer blower, or the pressure switch that senses the operation of the draft inducer.
Oct 25, 2013 | Heating & Cooling
I removed my Fasco 7021-11577S when the bearings went bad and ordered the A225 OEM replacement. I notice that when mounted this new draft inducer it whistles really loud .Is the hole in the back of the...
There should be a gasket between the mounting flange of the inducer motor and the furnace. If you do not have that you can use a small bead of blue or red silicone caulking to seal it. Hope this helps you. Thanks
Mar 29, 2011 | York Furnace Draft Inducer Blower Fasco #...
I have a furnace that has a draft inducer blower that will start and shut down, it will re-start and shut down again or it may run through the entire cycle and run fine. I had a heating tech take a look at...
Certainly wouldn't rule out the blockage as your friend suggests. Perhaps pulling it out, and a flashlight and if necessary a mirror to get a good look in there. May have to head up to top for a look as well. As long as blower sounds like it's running good speed wise.
Nov 21, 2010 | York Furnace Draft Inducer Blower Fasco #...
How does a draft inducer blower work
A draft inducer blower is used to create a proper draft in a chimney or exaust pipe from your water heater or furnace. In a high efficiency furnace or water heater, there is not enough heat expelled from the unit to the chimney to create a proper draft. The toxic carbon monoxide gas which is expelled through the chimney from your appliance is normally carried upward due to the rising hot air in the chimney. When appliances got more efficient (putting more heat into the water tank and less going out the chimney), manufacturers had to add this blower to help get the gases out the chimney since there wasn't enough hot air to create a draft.
Hope this helps.
Dec 10, 2009 | Fasco GSW Hot Water Heater Exhaust Draft...
How do i replace the inducer motor myself?? Is it hard or dangerous??? the technichian said i need a new draft inducer motor. I was wondering if it was hard to replace it myself, and if someone can give me...
Most draft motors are easy toreplace but get the intire draft assembly. Most of the time you damage the blower wheel getting it off. Let me know rus
Nov 18, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
88 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
