Question about Swiss Army Wenger Alpenrose 70450 Wrist Watch
The hands fell off the watch while trying to get the loose insignia piece out.I don't know what to do.I can't get the "winder" knob off to get the inner part out of the housing so I can get the hands back on.HOW does the winder knob come off? Watch is a swiss army Alpenrose 70450
  • 6 Answers
SOURCE: Second Hand
it is the battery life indicater get the battery replaced it will fix the problem
Posted on Apr 16, 2007
  • 6 Answers
SOURCE: Swiss Army watch 70609 second hand pauses
Battery life indicater just warning to get that battery replaced so it wont stop at an inconveinient time
SOURCE: swiss army watch
Did you have the battery checked to see if it was bad a first? Take it to a Reputable watchrepair , and ask them to CHECK your battery NOT replace it. Alot of times your watch will have a mechanical problem which will make your watch look like it is o.k. once you replace the battery but, two weeks later the watch stops again because the battery has lost enough power to now stop the watch again. Also your watch may have a electrical problem which a battery will not solve the problem. The coil (the orange straight piece in the movement), or the curcit board could be bad. Always have the store check your battery because, if you ask them to change your battety they will no matter if your original battery is good or not.
Posted on Sep 09, 2008
  • 5 Answers
SOURCE: connect metal strap to watch
If it brok at the hinge where the strap connects to the watch itself, then you might just need to replace the clip that slides in. Its a little metal tube with a spring in it. You should be able to find them at any retail shop. If all else fails, take it to a shop or jeweler.
Posted on Mar 11, 2009
  • 65 Answers
SOURCE: swiss army stopped, im stressing..
If it's a quartz (battery powered) watch test the voltage of the battery. If below 1.5v then replace with new. Ensure battery contacts make good contact with the battery and are free of corrosion/rust/contamination of any sort. Check operating manual for any specifics regarding battery replacement proceedure.
Posted on Jul 27, 2009
How can I start it to run
if brand new , there will be a small piece of plastic holding the winder knob out
pull it out and push the knob all the way in
that plastic stops battery connection so that the battery is not flat when sold
any other problems , take it to a jeweller
May 06, 2016 | Timex Womens T2M828 Classic Two-Tone...
How to set time on m.z. berger wrist watch
Hi Hollywoo,
As far as I can see Berger watches all have what I would call a winder knob. You normally pull this out gently and then turn it to move the hands of the watch - ie: to set the time. When finished just push it back in.
Aug 08, 2015 | Watches
How do I re-wind the date on my Timex Easy Reader Woman's Watch?
mcdevito75 here, The stem (crown) on your timex shou;d have 2 positions, this allows you to set the date without haveing to turn the hands around so many times. Place a fingernail just under the crown (winder knob) and lift to it"s first position, it may take some practice so if you don"t get it the first time keep trying, Once you lift the crown to it:"s first position you shoulsd be able to set the date, set the date a day before the date you need, Now, push the stem back in all the way, now pull out the stem and set the date and time you want, you"ll have to go around the 24 hours once to set the correct date and time. Hope this helps. If you can"t do this adjustment, see a small watch repair shop in your area.
Jul 01, 2010 | Timex 27191 Wristwatch
Changed battery .A square piece of metal the size of match head fell out. No alarm or light, casio forester FT200
mcdevito75 here, Of couse without the watch and piece of metal that fell out it"s very hard to say. Most likely it was part of the lock-down tab to keep the battery in place, in any event don"t lose that piece of metal. If your casio is working ok don"t worry about it, just don"t lose that piece of metal that fell out.
Jul 05, 2010 | Casio Forester PAS400B-5V Wrist Watch
It is a new watch. How do i start it
mcdevito75 Here, If It"s brand new just out of the box, Check just under the stem knob (winder) for a piece of plastic, remove the piece of Plastic, this will allow the stem to fully seat and start the watch.
Jun 13, 2010 | Citizen Calibre 2100 AV0031-59A Wrist...
My watch is not working and it is brand new. do
Look very carefully just under the crown (winder knob) for a piece of plastic used to keep the stem from being all the way down to start the watch. Remove that small piece of plastic, press down the crown and the watch should start. mcdevito75
May 28, 2010 | Skagen Alarm Function Leather 519XLSL1...
Winder on Rotary watch
Open the watch and lay it on the table dial down and winder facing you.
Get the hard steel needle and push down the small metal piece next to the to the place where the stem is entering the movement (on the left side). Pull out the stem while holding that piece down.
If thhat piece looks like screw cap (with the groove), then you have to unscrew it in order to get the stem out.
Do not forget to rate, please.
Mar 01, 2009 | Watches
Help setting the time
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
Nov 06, 2008 | Tag Heuer WAF2110.BA0806 Aquaracer...
Need to get winder out from watch so as to remove watch face
Open the back of your watch. pull the stem ( winder) out and look for a small metal piece inside that moves as you do this. There should be a little dimple on the moving piece. The piece may be on then side next to the stem, or on the movement under the movement backing plate. Tale a tweezer or something like it and push in the dimple. DO NOT PUSH HARD!!! You want to try to pull the stem out while pushing down on the dimple( it's called the detent) as lightly as you can. If you push too hard you will mess up the whole stem assemly If you still have a problem please let me know..Good Luck!!
Jul 08, 2008 | Watches
Adjust the date and day on a festina 3 dial watch
I've just worked it out! Change month....depress inset button on side above hand winder. One push with cocktail stick or similar will advance month. Change date.....pull out hand winder half way, turn knob anti-clockwise until desired number is met. Change day...... pull out hand winder fully, turn clockwise passing midnight repeatedly until day is set, continue to set time, keeping an eye on 24 hour display for am/pm.
All the best, Bob
May 06, 2008 | La Crosse Technology E. Howard Ambassador...
Swiss Army Wenger Alpenrose 70450 Wrist Watch Logo
124 people viewed this question
Top Swiss Army Wenger Watches Experts
Michael Vincent Cruz
Geoff
Are you a Swiss Army Wenger Watch Expert? Answer questions, earn points and help others
