Question about Casio Parts Cash Register PC Desktop
I get a beep and E (only an E without an error number)when I press the Subtotal after using the keypad.
You might have the "compulsory amount tend" turned on. Click on the link below to view steps to correct this problem:
http://www.fixya.com/support/t1137817-casio_ce_t100_cash_register
Posted on Feb 07, 2010
I have a sharp ER-A450T it is frozen and I have followed all the trouble shooting things in the manual and nothing seems to work...please help
Hi Renee. The first thing to check with this model is whether it beeps when you press clear (The C button near the number 9 button). If it does not make a beep sound, you are right, it is frozen and the problem is usually either a faulty keyboard or printer (but you usually have an error code or dashes on the display if printer problem). Take it to be repaired.
If it does beep, it is not frozen and it is probably just waiting for you to finish something you started. Try pressing clear (C button near the number 9 button) in each mode and then press subtotal and then cash. So turn key to REG mode, press C SUBTOTAL CASH. Turn key to MGR mode, press C SUBTOTAL CASH and so on for each mode. If it shows an error message, please let me know which one and we can check further
May 09, 2017 | Retail Supplies
When turning on our sharp XE-A42S cash register in REG mode it lets us enter in a price, but when we go to push the department key, it beeps and displays misoperation...
Firstly, press subtotal (ST) button. If a price appears, you are in a sale and it is waiting for you to finish (try another method like credit). If it gives an error or beep when you press ST button and the drawer does not open when pressing CA/AT/NS, you probably haven't signed on. Try signing on using a PIN number (see clerk sign on in your manual)
Jan 11, 2017 | Sharp XE-A42S Cash Register
How to fix E1 error on samsung ER 5140
E1 is just operator error, it normally occurs when the wrong keys are pressed or the machine has got itself into a bit of a loop. At exactly which point does the message appear? is it when you press a certain key?
The first thing to try is an initial clear:
Turn the key to P
Press and hold SUBTOTAL
Whilst continuing to hold SUBTOTAL turn the power off... then back on
Continue to hold SUBTOTAL until the receipt stops printing
Turn the key to R and give it a test.
Nov 13, 2010 | Samsung Office Equipment & Supplies
Till drawer opens after ringing one item and manual says to solve this programme the dept as a normal dept. How do you do that? I also want to programme the +1 key for some items and the -2 key for...
to fix the drawer opening problem...
1. turn the key to program
2. press 3 subtotal
3. press 0 then the department in question
4. press subtotal to exit programming and turn key back to reg.1
for the adding two new departments question...
1. if the 1 and 2 buttons are to the right of the number keypad 1-9 you can use them by following the same instructions entered above.
2. If you are referring to the 1 and 2 that are left of the number keypad you can not use them, they are only enabled in the calculator mode of the cash register. :>
Nov 08, 2010 | Casio Parts Cash Register PC Desktop
Hi Flexion. You are right since the problem of not working ERR. CORR/CANCEL and X multiplication buttons existed since before (only noticed now) but the amount limitation error happens right after...
To change the keyboard, Turn key to program 4 SUBTOTAL 082 Now press the position where you want the X multiply button 034 Now press the position where you want ERR CORR button SUBTOTAL
as for the amount limitation, try it on the item that you set as 0 last time (3 SUBTOTAL 0 item SUBTOTAL). I need to know if it affects all items or whether any items you set as 0 above will work at less than $1.00. I don't think it has anything to do with training mode. Probably has a limit set from previous owner
Sep 16, 2010 | Casio Parts Cash Register PC Desktop
Flexion1, Many thanks for getting back to me. I guess better not to use the trainee instead. The solution did not solve the problem. Still the message E026 ENTER CONDIMENT/PREPARATION PLU appears on the...
Oh right. sorry, the last part of your question was cut off, so I didn't see all of it. It looks like you have accidentally set limitations and preparation status on a PLU.
Firstly, you need to jump out of preparation status. Follow this carefully:
Turn key to PROGRAM mode. (don't worry if error/ beeping) Turn power off at wall. Hold RECEIPT FEED down - keep your finger on it. Turn power on at wall. Wait 5 seconds, then let go of RECEIPT FEED. You should see "FFFFFFFFFF" on display. Press SUBTOTAL and wait for printout. 3 SUBTOTAL (if you see error 8, you need to sign back on) 0 Now press the item button that gave you the error SUBTOTAL
Now go to REG mode and try that PLU (item). If it is doing it on any item or only when you press a payment, let me know
Sep 14, 2010 | Casio Parts Cash Register PC Desktop
Casio 240 Cash Register: Error 01
The reason it went into error is due to someone turning the key to another mode without finishing the current transaction. Turn the key to each mode until you find the mode that doesn't give error 1. If that mode is X or Z, then press SUBTOTAL. If that mode is REG, then press SUBTOTAL to see the amount due, then type that amount and press CASH
Need a manual for a Casio 240CR? Try here:
http://the-checkout-tech.com/manuals/cashregisters/Casio1.php
Many others at http://the-checkout-tech.com
Mar 26, 2010 | Casio Parts Cash Register PC Desktop
CE-7000 Program Departmental Names and program post receipt print
Hi.
Turn key to program.
3 SUBTOTAL
100000000000
RECEIPT
SUBTOTAL
That should allow you a post receipt.
To set dept names:
2 SUBTOTAL
Department number
05
SUBTOTAL
Type new name
CASH
SUBTOTAL
If it gives an error when pressing CASH, then repeat, but press 00 button before CASH (some models need this).
Jan 23, 2009 | Casio Parts Cash Register PC Desktop
E026 error message Casio TK-7000
find out what plu it is then re pgm it
turn the key to PGM
enter 3 & press Subtotal
enter 0166 & press Subtotal
enter 0 and press the faulty PLU
now press Subtotal
enter 1066 & press Subtotal
now press Subtotal
turn the key back to Reg
Dec 23, 2008 | Casio Parts Cash Register PC Desktop
Casio TE4500F Programming Departments & linking to PLU's
Hi.
To link a PLU to a dept:
Turn key to program mode.
3 SUBTOTAL
1166 SUBTOTAL
Now type the PLU number and press the 'PLU' button (eg 1 PLU for the first plu)
Now type the dept number to link to. Use two digits eg 01
Now press 00 (double zero)
CASH
SUBTOTAL
To set a dept name:
2 SUBTOTAL
Type dept no in 2 digits eg 01
Type 05
SUBTOTAL
Type new dept name using character sheet
00 (double zero)
CASH
SUBTOTAL
That should do it.
Let me know if you have problems.
Mark
Dec 18, 2008 | Casio Parts Cash Register PC Desktop
Casio Parts Cash Register PC Desktop Logo
19 people viewed this question
Top Casio Retail Supplies Experts
Electroboy
Electroboy
Gareth Cockram
Gareth Cockram
Are you a Casio Retail Supply Expert? Answer questions, earn points and help others
