Question about Saitek Eclipse II
Space bar sticking on Saitek lighted keyboard
Is it possible to pop off the space bar key to see why it is sticking?
  • 3 more comments
  • wilrhy Mar 10, 2008
    I emailed Saitek about the problem---when I popped off the spacebar the plastic piece that holds the clip was broken. They mailed me a new one free of charge.
  • Anonymous Sep 04, 2008
    my spacebar is also now busted, crappy design
  • Anonymous Apr 03, 2009
    Anyone know how to pop off normal letter key of the keyboard?  My "d" key is hard to use cuz i have to slam me finger on it for it to make the "d" which is why try not to use many D's in my typing.  Anyway please reson on how to pop it off so i can fix it or how to just fix it.
  • Anonymous May 16, 2009
    Hey, I got a problem aswell. when I press down my space bar and i press to the left or right edge, and not in the middle it doesn't record that in the text im typing as a space. This problem started after I popped the space button out to check under it because I accidently got some ice cream under there.
  • Ethan Hull Sep 14, 2013
    If your space bar is sticking or seesawing (as mine was) you can either contact the company and they can send you another spacebar, or you can find out what is wrong with it and fix it yourself. One of the plastic bars on the back of my spacebar broke so the bar was seesawing and only if you pressed it in the middle would it work. I took it off the keyboard, coated one end of the metal bar with vaseline (the end that kept popping out due to the broken plastic bar) and then hot glued it to the spacebar. It was a 5 minute fix and I am typing on it right now. Works like a charm.
I had the plastic pieces holding the bar broken off when I got it, I just put some loctite over the broken pieces with the bar in it. Then kept moving the bar while the loctite dried. It recreated the plastic holdings and is more robust to abuse now.
-James
Posted on Oct 20, 2008
For me, I popped of the space bar, cleaned the junk underneath and fidgeted with the plastic push-button and all was better. Thanks for the suggestion!
Posted on Mar 10, 2008
Keyboard sticking
Clean the keyboard. Most of the keys can be safely "popped" out using a nail file or other thin lever. Don't pop out the larger keys, like the space bar, because they have a small wire spring in most models that can make them difficult to reinsert properly. Use canned air, a Swiffer, q-tips, or other methods (nothing wet, but a damp cloth that doesn't drip is OK) to get the obstructions cleaned away and then put your keys back.
Mar 01, 2011 | Logitech Cordless Desktop MX3200...
I have a IBM WW 1500 all the keyboard works but the spacebar, is this the function or keyboard or possible homming sensor failure?
If everything wirks but the space bar you probably have a keyboard problem. If someone had the space bar off it may not be properly installed. You can pop the space bar off and look for debris under it.
DickyO
Dec 02, 2010 | IBM Office Equipment & Supplies
The space bar has come off how do i fix it
Often with keyboard keys, they have several clips that hold the keyin place. Try gently prying the key off again, and see if there is any placewhere the plastic might have broken, or if there were other clips thatweren't quite in place. If the key is broken, though, you can either deal with it as it is, orprobably order a new key.
Jan 07, 2010 | Sony VAIO PCG-K23 Notebook
Trouble with keyboard/space bar sticking and few keys. how to solve
I would take a butter knife and pop off the keyboard, clean it out, make sure the two metal objects are aligned and pop it back in.
Thanks,
Brandonmxb
Dec 11, 2009 | Acer Aspire 3610 Notebook
How to reattach the space bar key on the SK-8110 Dell keyboard?
On dell's website there is a step by step instructions on how to attach it back on. I had to do the same thing on mine machine. Just go to dell's site and on the search bar on how to attach the keyboard.
Dec 10, 2009 | Dell SK8110 Keyboard
My key board fell off and the space bar came off Itried puttingit back but it doesnt work
You can easily fix your space bar. I fixed mine last month when my daughter pulled it out of the keyboard. I used this video tutorial guide to help install the space bar key back into place. Its really very simple. have a look:
http://www.laptopkey.com/installation_guides.php
Oct 10, 2009 | Dell 0Y3740 Keyboard
Saitek Eclipse Keyboard Keys stopped working
this could very well be your OS as much as your keyboard. Try another board for a few days and see if it still happens. IF not...you found your culprit. Replace the keyboard or look for updated drivers if they exist.
Jun 02, 2009 | Saitek Eclipse II
I have to press the space bar right in the middle for it to work.... any help?
Hi!
I had the same problem when i got the keyboard. In my case, it was because the tiny metal bar that is supposed to transfer the pressure from the right and left sides of the bar to the mittle was not attached correctly.
I removed all the screws from the back of the keyboard (note that there are screws underneath the rubber pads, but don't worry about them, they will stick to the keyboard again) and lifted off the top (including the keys). Then i could pop off the space bar from behind (didn't work for me otherwise... maybe it is possible to pop it off without removing all the screws) and correctly insert the metal bar into the mounting.
Hope this helps.
May 16, 2009 | Saitek Eclipse II
Saitek Eclipse II keys are sticking
You can remove the screws on the back and clean the keyboard. It's very easy task to do. Just remember components locations inside so you can reassemble.
Jan 16, 2009 | Saitek Eclipse II
Saitek Eclipse II Logo
1,391 people viewed this question
Top Saitek Computers & Internet Experts
micky dee
Ajay Virvan
Ajay Virvan
Are you a Saitek Computer and Internet Expert? Answer questions, earn points and help others
