Question about Kenmore 63942 Dryer
Kenmor dryer Series 80 110 668 14690
My dryer will start and run a couple of minutes ,drying normally, it will then shut down. It will restart, each time getting shorter, until it will not restart.
I can repeat after a period of say 10 minutes
  • mathenad3 Aug 11, 2008
    The dryer will start and run for a little while and shut off after ten minutes or so, being restarted after it shuts down gets about ten minutes of drying each time. I felt either something would be stopped up or the machine over heating due to some type of safety device. after opening the back I am not seeing any excess lint inside so I remain clueless.
  • 958 Answers
Based from your story, you are tiggering a thermal overheat protection device. as the device heats up, it would trip off the dryer, and comes back on again after a few minutes but as the heat increases, the device is being triggered faster until the device would no longer trips back because the dyer is so hot that it would take about 10 mins to cool down. i think this is just a secondary problem, your primary problem could be lack of air passing through the heating element. please check the stroller blade for dirt of flint and debri, check also the outlet duct, it could be clogged with flint also. i hope i was able to solve your problem.
Posted on Feb 23, 2008
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Maytag Centennial Gas Dryer: Only runs in "Air Fluff" setting. If any other setting (Normal Dry / Timed Dry) are used the dryer shuts down immediately. If I force the dryer to run by holding down the start...
Hello Kevin;
My name is Peter. I am a retired field service appliance technician.
When you run your dryer on fluff you are not using heat. The burning smell is when you use normal dry and the lint starts to burn. This will shut your unit down.
You just need a good cleaning. Nothing major. Send me your model number and I will help you.
Dec 11, 2014 | Maytag Dryers
Kenmore dryer runs only for a few minutes
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Aug 31, 2014 | Dryers
Kenmore 700 series Dryer shuts down after a few minutes in heated cycle, runs forever with no problem in Air Dry (no heat) mode, I disassembled the entire machine drum, motor, vents and removed every spec...
Brian, look inside your drum for some curved strips of metal that may be 6-8 inches in length. There may be two of them that run parallel to each other about half an inch apart. This is your moisture sensor. If you use dryer sheets like a lot of people do you may have an issue where there is a build up of residue from the dryer sheets on the sensors. Take some rubbing alcohol and some cotton balls or a rag and wipe down the sensor strips. If they come back blue in color there is build up on the strips. Keep wiping down until you no longer get any blue color. That build up can make the dryer think that the clothes are dry and shuts the dryer down. Hope this helps, I have done this on a couple of different dryers and it made a big difference.
Mar 18, 2014 | Kenmore Dryers
After starting dryer will run for a minute or so then shut off
there is a problem with your exhaust check the air duct or take off the exhaust hose it will be packed with lint this will keep the dryer from running correctly !!!
Nov 12, 2013 | Hotpoint NVL333EY Electric Dryer
Dryer starts fine after a couple of minutes shutts of, I have to restart it several times untill clothes are dry.
most dryers have a sensor that is supposed to shut off auto matic when clothes are dry look at your choises on the dry temperture. one of them usually have automatic whites auto colors etc. the sensor sounds like it went bad. most of them are near the exhaust pipe.it measures the moisture level to test it remove the wire or wires. then try running the dryer for a little while.
Dec 29, 2011 | Roper Dryers
Maytag LDG 712 shuts off before clothes are dry.
First, The most common part would be the over limit safety, it will be mounted to the element housing. Second, there is a thermal fuse usually a small disk with a little fuse inside. You can find these (with your model no.) at www.Repairclinic.com .Good luck.
Apr 20, 2009 | Whirlpool LER5636P Electric Dryer
Maytag gas dryer fires, then shuts down
may be the coils on the gas valve. there are 2. usually they need replacing when the ignitor glows but no flame
Nov 20, 2008 | Maytag Dryers
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit again.no tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Kenmore 63942 Dryer Logo
176 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
