Question about Precor EFX 546i Elliptical Version 4
Error message "key depressed" and no resistance on elliptical.
We have a"key depressed" error message on EFX546 elliptical. How do we deal with this issue. Thank you
    President:
  • Precor Master
  • 832 Answers
You will need a keypad and overlay call National Gym Supply @ 1-800 496-7278 they will need M & S #
Posted on Mar 02, 2010
  • nuz3411 Jan 22, 2011
    i had the same problem and replaced both and still said "Key Depressed"
Key depressed
Precor Error 05, Key Depressed at Power Up
Probable Cause 1. A key is permanently depressed on the display.
2. An interface chip (IC) has failed in the upper PCA's keypad.
3. Liquid (cleaning solution or sweat) may be on the surface of a touch sensitive display.
Corrective Action
  1. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 is eliminated, the keypad is the cause and should be replaced.
  2. Disconnect the keypad cable from the upper PCA. Reset power to the machine. If the Error 05 still appears, the upper PCA* is the cause and should be replaced. *Upper PCA's most commonly do not come with software. Remove the software (chip) from the existing upper PCA prior to replacement and install into the new upper PCA.
  3. Wipe away all liquid from the touch sensitive display. Reset power to the unit. If the Error 05 is eliminated, the liquid was the cause.
Jan 30, 2014 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546i control display panel would not work. i.e, no resistance control, no level control, the panel would not hold a charge when I started to pedal. the battery was then replaced but the only...
Precor Error 05, Key Depressed at Power Up Probable Cause 1. A key is permanently depressed on the display.
Corrective Action
Precor Error Code 05
Feb 19, 2013 | Precor EFX 546i Elliptical Version 4
"stuck key" message on efx 546i, will not engage, already replaced batttery
Corrective Action
Feb 17, 2013 | Precor EFX 546i Elliptical Version 4
I get the message error 05 stuck key on my precor efx 546
Corrective Action
Dec 09, 2012 | Precor EFX 546i Elliptical Version 4
Key depressed error
Corrective Action
Nov 13, 2012 | Precor EFX 546i Elliptical Version 4
Efx546 error 32
Precor Error 30, 31, 32 and 33, Communications Error Probable Cause 1. Bad interconnect cable between upper PCA and lower PCA.
2. Interconnect cable is mistakenly plugged into the CSAFE connector at the upper PCA.
3. Elliptical 5.17 equipped with old software version 1.01 in upper and lower PCA.
4. Upper and lower PCAs have mismatched software.
5. Another component plugged onto the PCA is overloading the +5VDC power supply.
6. Bad lower PCA.
7. Bad upper PCA.
Corrective Action
  1. Test unit with a know good interconnect cable or test the interconnect cable for continuity. Replace interconnect cable if necessary.
  2. Disconnect the interconnect cable from the CSAFE connector and attach to the proper position on the upper PCA.3.
  3. Replace the upper and lower software of the 5.17 elliptical with the most current versions.4.
  4. If one of the PCAs is found to have software version 1.01, replace it with the most current software version.
  5. Disconnect all components from the upper and lower PCA leaving the data cable connecting between the upper and lower PCAs and the AC power going to the lower PCA. If the unit shows any error other than the error 3x, reconnect components one at a time. Reset power between each newly connected component until the error 3x reappears. Whichever component was last connected when the error 3x reappears, is the cause for the error. Replace the faulty component.
  6. Test unit with a known good lower PCA. Replace the lower PCA if necessary.
  7. Test unit with a known good upper PCA. Replace the upper PCA if necessary.
Precor Error Code 30 31 32 33
Feb 19, 2012 | Precor EFX 546i Elliptical Version 4
Display message reads - "key depressed"
Corrective Action
Jan 25, 2011 | Precor EFX 546i Elliptical Version 4
My Precor EFX 546 Elliptical machine has a "key depressed" error message.
Corrective Action
Aug 17, 2010 | Precor EFX 546i Elliptical Version 4
What is error 50 on the precor efx546
Error 50, Too Much Brake (Magnet) Current
The problem maybe lower board related or improper signal is being translated Call Precor @ 800-347-4404
May 11, 2010 | Precor EFX 546i Elliptical Version 4
Precor uses the same error codes for all of their units. Error code 50 is for excessive brake (eddy current magnet) current.
Mar 19, 2010 | Precor EFX 546i Elliptical Version 4
Precor EFX 546i Elliptical Version 4 Logo
743 people viewed this question
Top Precor Exercise & Fitness Experts
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Tom Chichester
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
