Question about Logitech Webcam
Internet audio output becomes input echoing back out thru PC
Scenario: Using Teamspeak 3 to converse with other game players. Using Plantronics headset. XP Pro; RealTek HD Audio Manager.
Problem: other players are being echoed back through my system when they speak. I don't echo to them when I speak. Have unplugged headset with no other mic on and it still happens. Changed settings to mute all mic's to no avail. Watching Teamspeak's user "indicator light" that shows when someone else is talking, my user id shows I'm talking when if fact they are actually talking. It's also on when I actually speak which is correct. 3 of us spent a lot of time pouring through possible configuration settings, and came up empty handed.
I don't think it's Teamspeak causing it, but rather some setting on my system that alludes me. Any help would be appreciated.
Crevice Dog
  • crevice_dog Feb 06, 2010
    Thanks for your prompt reply T-Bone. I tried finding the "listen to" option, but couldn't locate it. Can you be a bit more specific?
    I went to Control Panel / Sounds and Audio Devices / Audio(tab) and went through everything I could to find it, but was unable to. Thanks.
    Scholar:
  • 62 Answers
Try unmarking the "listen to" option on your sound devices panel. it should remove the echo
Posted on Feb 06, 2010
  • Hudson Ribeiro
    Hudson Ribeiro Feb 06, 2010
    ok, let me be more specific. if you're using windows 7, try to right-click your audio system tray icon, then, select "recording devices" right-click your default microphone and select "properties". go to the tab "Listen" and unmark the checkbox "listen to this device". if it doesn't solve your problem, try to adjust the mic boost and recording volume levels. you also should check your teamspeak software if the problem persists. i'm not familiar with the teamspeak 3 software but it may have some options that may help you.
    Glad if I could Help! :D
Echo Windows 7
Turn down volume / input. If unsolved, then uncheck
"listen to this device" under audio input. On Win7:
R-Click on Speaker in taskbar, click 'Recording devices'
& select earphone properties.
Mar 29, 2014 | Plantronics Radio Communications
Tip
RF Modulators and cable connections
RF MODULATOR HOOKUP
For a TV with only a RF input jack, a RF Modulator can be used to hookup DVD players, DVD recorders and other devices which output RCA composite video and audio. For example, analog cable TV can be connected using a RG-6 type coaxial cable to a VCR or older DVD recorder's analog cable ready tuner RF input. Then as shown above, the output can be connected to the TV thru the RF modulator. The modulator outputs on channel 3 or 4 for the older TV so the TV is set to channel 3 or 4. Some RF modulators are built-in to Audio/Video switch boxes. These allow multiple RCA inputs along with RF input.
RF MODULATOR CLOSE-UP
The modulator converts signals to channel 3 or 4 so older TVs can tune them on their analog tuners channel 3 or 4.
RF Modulator - buy online
http://sewelldirect.com/belkin-rf-modulator.asp
on Aug 23, 2010 | Audio Players & Recorders
Have Sony KDL-40EX400 LCD TV, Sony STR-DH510 AV reciever, Sony DVP-NS57P dvd player. When connected to reciever using component connections the TV does not show a picture. I have seen this problem in a...
  • If I understand your question correctly you want to watch your DVD on your TV thru your receiver,
  • you need to connect either composite connections "Audio/Video Output " red/white/yellow RCA jacks or "Optic cable output" of your receiver
  • ( pls note that component to composite conversion is not possible on receiver ..use one type connection thru all the way )
  • to "Audio/Video input " red/white/yellow RCA jacks or "Optic Cable input" of your TV
  • than just switch to DVD mode on corresponding your RCA or Optic connection...
There you go..Your DVD sound and video both are on the TV..
  • Hope this helps!
Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :)
Feb 06, 2011 | Sony DVP-NS57P
I have a Sanyo DWM-390 DVD player and I can't get the video on my TV. I have the DVD player going directly to my TV versus my cable box. I have the video and audio chord in the corresponding audio and...
3 possible solutions to your problem starting with the easiest:
1. The audio/video cable is bad. It is possible the video side of the cable has a short.
2. Inputs on the back of the TV are mislabeled or aren't matching up with how you are connecting or using the inputs. Feel free to post a picture of the back of the unit with your cords attached and I can tell you for sure.
3. Some dvd players require you to select which video output mode to use. Most of the newer ones come defaulted to hdmi output and might need a menu selection changed to output using component or composite outputs (whichever you are using). Composite will just have the red and white connector for audio and a single yellow connector for video. Component uses the same 2 audio connectors and then red, green, blue conectors for the video.
Let us know more detail and I can help further.
Jun 14, 2017 | Sanyo DWM-390 DVD Player
Connecting audio from pc to receiver.
What does your sound card have for audio outputs? Mine (M7250N Media Center) has all the expected 7.1 analog audio outputs AND a digital S/PDIF audio output that I run to my receiver's coaxial digital input.
Even if you have just 2-channel audio on your PC the headphone output can be used with an adapter that makes it conenct to a standard RCA audio cable. Run it to any available Linme Level input on the Denon. Get into your sound controls on the PC and make sure your Master Volume is unmuted and adjust whatever else applies to your machine that may affect the audio.
Your monitor is not really a player in this scenario.
Apr 29, 2010 | Denon AVR2310CI 71 Channels Receiver
TeamSpeak 3 echos
most occasion its that in your configuration for sound output you have your microphone turned on which causes your outbound to have an audio loop of both inbound and outbound sound causing an echo going into the setting and looking specifically at your inbound audio options and muting your microphone will fix this
Mar 28, 2010 | Gateway 506GR PC Desktop
Cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
Denon AVR-488 , problems routing cable box through receiver to tv
If you don't have one, the manual is available online: http://static.highspeedbackbone.net/pdf/AVR-488-OM-E_101.pdf
Suggestions:
1. Reset to default values. Per page 36 of manual: 1. Turn off Power. 2. Press Power while simultaneously pressing Speaker A and Speaker B. 3. Once the display starts flashing at intervals of about 1 second, release the two buttons.
2. Make sure you have AM or FM radio reception. This makes sure your speakers, amps, etc are connected and working correctly.
3. Connect DVD player to HDMI 1 in and TV to HDMI Monitor Out.
Play a known good DVD that works when you connected the DVD directly to the TV via HDMI.
Select the DVD/HDP input on the receiver and play the DVD. You should not have to perform any input assignments, etc. It should just work, as HDMI1 is the default system setting for DVD.
4. If possible, obtain a STB with HDMI out & repeat step 3 using the HDMI2 TV/CBL input. Keeping the signal path all digital (HDMI) will give you a better picture quality than forcing several analog to digital conversions (component video is analog).
4A. To use the component connection, first test by connecting the STB directly to the TV via component video/audio if possible. This tests that the component video output of the STB is working correctly.
Next, remove direct connection and connect via receiver. Connect STB to receiver as shown on page 13 in manual. Connect component video output from STB to component video input #2 (tv/cbl) on receiver. Connect the STB audio output to the corresponding tv/cbl audio inputs.
Make sure nothing is connected to the HDMI2 input or to any other TV/CBL inputs (composite video, s-video, digital coax audio).
Now select the TV/CBL input and turn on the STB. You should have both audio & video.
Mar 08, 2017 | Electronics - Others
Teamspeak Won't Work with Vista
Look at TeamSpeak overlay with PlayClaw. The main task of PlayClaw is to record game video but it have ability to show Teamspeak & Ventrilo overlays. Works fine with Vista/W7, but only one restriction - voip client must be 32 native (not 64) app. Windows may be in any bits: 32 or 64
Nov 21, 2008 | Computers & Internet
Sound hook up
if u have a pair of rca connectors, connect audio out of your dvd dvd receiver to audio in of your tv. they are usually red and white,, for right and left speaker.
Nov 05, 2008 | Kenwood HTB-204 System
Logitech Webcam Logo
248 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
