Question about RCA D52W19 52" Rear Projection Television
Turns on but turns rite off D52w14 - RCA D52W19 52" Rear Projection Television
Pool pump turns on, starts clicking then turns off
It appears that the motor is overheating, and then it turns off. There is a thermal overload switch that will turn off the heater, and when it cools back down, the motor will turn back on.
A few things to check:
  • Debris in the impeller
    • If so, remove it, this is causing the motor to overwork
  • Was motor / impeller recently changed?
    • if motor was downsized from the one prior, it is overworking, because the impeller is still sized larger.
    • if impeller was upsized with an undersized motor, the motor is overworking
  • Is the motor louder than normal?
    • The bearings are probably failing and the creating the motor to labor.
Good luck
Mar 11, 2015 | Sta Rite Sta - Rite 1hp Dura - Glas...
Buttons won't turn temperature up or down
sounds like you need a new control board did mice nest under it that happens frequently
Mar 20, 2014 | Sta Rite Sta-Rite Max-E-Therm High...
I have a sta rite heater when pool turns on the heater lights go on threw its cycle but when i go to turn on its like there is no power
does the blower come on? if not, make sure you have the proper voltage plug installed. or the voltage plug may be loose
Aug 23, 2013 | Sta Rite Sta-Rite Max-E-Therm High...
My raditor fan turns rite on rite after i turn on
This could be caused by a faulty relay. What your describing indicates that there is power going to the relay all of the time the key is on. There may also be a problem with a shorted wire in the system. You will need to figure out what is puting power to the relay to make the fan turn on.
Hope this helps narrow it down a little...
Nov 07, 2009 | 2007 Ford Fusion I4 SEL Sedan
Television issue
Check the area around the flyback for bad solder. Thats a common issue for that chassis RCA.
Jul 04, 2008 | RCA Televison & Video
RCA D52W19 52" Rear Projection Television Logo
42 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
