Anyone know about the AKG E-1000 microphone? Directionality? Know what the B/M/S switch is for? How will this mic do with being plugged straight into the input of a guitar amplifier?
    Champion:
  • 211 Answers
Isn't a AKG C-1000 ?
If you Google that model you'll find all the info you need.
Regards,
Gerard
Posted on Feb 06, 2010
Testimonial: "turns out it was for an akg d- 1000! the ebay seller mis-labeled it. thanks for your help."
Im looking for a used wireless AKG Microphone HT81. We have a SR81 receiver. Do you know where to find one?
I supect your best bet would be Ebay. be sure to check the frequency your receiver operates on and get a mic that matches it.
Sep 01, 2015 | AKG Audio Players & Recorders
Akg repair
spray it with contact cleaner or wd40 and work it back and forth a few times
Jul 26, 2014 | AKG SolidTube Professional Microphone
I have recently bought an AKG Perception 120 microphone and plan on recording through GarageBand on my Macbook Pro, but no sound is coming through. please help!
You say you have a XLR to USB adapter....so the version of the 120 you have is the regular XLR version, right? Well if it is, it needs what's called "phantom power" to work. It looks like they have a straight USB version of this mic, and that's what you should have gotten if you didn't want to use anything else. If you still want to use this mic as is, I would recommend a Focusrite Scarlett 2i2. I have one and it's great. I do have a pc though and I'm not sure about Mac. But it's a usb powered preamp that gives you two mic pre's along with headphone amp, and a volume control for your speakers and has phantom power built in. Great unit and around $120. NFI.
May 14, 2014 | AKG Perception 120 Microphone
Hum which is made worse on touching top half of mic. clearly an earthing matter. engineer has checked bottom half but does not know how to get into top half.
I have the same mic, same problem. I disassemled the mic, put it back together, and the problem fixed itself. I can't explain exactly why.
To disassemble the top part of mic, turn the 2 plastic posts inside the mic clockwise.
http://www.akg.com/mediendatenbank2/psfile/datei/96/C4000b4055d1f13eb44.pdf
Mar 18, 2011 | AKG C4000B Professional Microphone
What is the switch for on the Phantom power unit at the end of my AKG C747?
Hi,the switch for the phantom power on the microphone is to activation of the mic.Without the phantom being activated, the mic will not work.
It can only be activated with a mixer console that has a phantom activation on it. After connecting the mic to the mixer,activate the phantompoweronthe mixer and switch on the phantom power on the mic,and problem solved.
Note: Mic will not work if no phantom activated on the mixer.
Oct 20, 2010 | AKG C747 Professional Microphone
My akg perception 200 is not responding
Have you tried using a another XLR cable..,or are the other mics phantom powered condensers..ie try to locate if its a mic problem or the cable..2 other points are 1 - XLR leads for phantom mics need to be XLR to XLR male to Female plugs[ends] 2- is that often an XLR to XLR cable will be not soldered or wired right,so that the power [phantom power is not getting to the mic] so ensure you have a proper cable for that job...Sorry i can't be more specific but from reading your problem all these issues come to mind..If you have ruled all these things out,then it could be the capsule or loose joint or component in the mic which means contact AKG,pro audio services or find a DIY mic person to help..G luck!!
Jan 11, 2010 | AKG Perception 200 Microphone
AKG Perception 200 Mic stopped working. I use it
The simple thing to check would be to see if your 48V phantom power switch on your mixer is turned on. Sometimes there is an individual button to turn it on and off for each channel strip. Good Luck
Oct 06, 2009 | AKG Perception 200 Microphone
C 518 ML Isnt Working
Make sure that you are supplying phantom power. This mic requires it. Without phantom power, the mic will appear to be dead.
Let me know if that resolves the problem.
Dan
Mar 19, 2009 | AKG C 518 ML Microphone
AKG Perception 100 not working, at all
The problem is that your amp probably doesn't have phantom power. This mic requires phantom power to be supplied to it via the XLR connector. Most mixers and mic pres have that feature, but most guitar amps do not, I believe. Hope that helps...
Jun 08, 2007 | AKG Perception 100 Microphone
97 people viewed this question
 Grubhead
Grubhead
