Question about Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound
Fixing a Polaris Indy 400 snowmobile pull cord - I took it apart and cant get it back together
    Scholar:
  • 105 Answers
Hello usually on any pull start, you have to wind the spring inside,the cover, on my atv i put the rope on the pulley burn the end of the rope and make a point on the end of the rope. put the pulley back in the case, turn the pulley backwards untill you get a lot of tension on pulley and turn the case up wright where you can see hole where rope comes out, turn pulley untill you see end of rope through hole. fish rope out with a pair of tweezers or a pair of themostats
Posted on Feb 06, 2010
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
I reringed a polaris indy sport with a indy 500 engine in it, now the gas will shoot out of the spark plug holes. Is the fuel pump diaphram bad? Or are BOTH needels stuck? Or?????
SOUNDS LIKE THE ENGINE IS BADLY FLOODED, SHUT YOUR GASS OFF AND REMOVE THE PLUGS, THAN PULL IT OVER UNTIL IT IS UNFLOODED. IT SOUNDS LIKE THE NEEDLES ARE STUCK IN YOUR CARBS
Dec 10, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
92 250 polaris indy lite snowmobile that back fires when pulling over
I have the same problem.....I believe it is a result of low compression. I have also noticed the problem to be worse in warm climate. Check compresion on both cylinders would be a good place to start.
Jan 24, 2010 | Polaris New Genuine Polaris Snowmobile...
How to put a recoil spring back in i took apart a recoil starter for a 97 polaris snowmobile and the spring popped out and i cant put it back in
HAhaha, oh this is so funny to me cause i suffered with the same problem, you have to grip the spring with needle nose pliers and wrap it tightly back arround, gripping the new layer every revolution, it sucks i know, then VERY CAREFULLY place it back it the spring retainer
Jan 18, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Polaris New Genuine Polaris Snowmobile Accessories / X Treme Sidecut / Out of Bound Logo
1,017 people viewed this question
Top Polaris Winter Sports Experts
Todd Arndt
Todd Arndt
Lawrence Oravetz
Are you a Polaris Winter Sport Expert? Answer questions, earn points and help others
