Question about Kenmore 24 in. 16032 Built-in Dishwasher
Dishwasher wont push water around inside tub correctly something is blocking water flow to pump i looked for filter could not find
  • 3 Answers
The units diosposal screen is probably clogged.
This is a relatively simple procedure that requires 2 tools. There is a screen behind the cutter in the built in disposal unit that gets clogged easily. You may want to order a new part before disassembly.
To disassemble:
You will need 2 sizes of torqs (star shaped) screw drivers and some patience in reassembly. Be sure to note how things are assembled before removing them. You do not need to unplug the unit to do this as you will be inside the unit and not around any exposed electrical components. Make sure the unit has been off for a while so that the heater element is cool.
  1. Remove the top rack by squeezing and sliding the plastic locks upward (on the ends of the rails) Then slide the rack out.
  2. Remove the bottom rack
  3. turn the center plastic retainer on top of the spray mast cclockwise (opposite most all other screws) and lift out main spray arm
  4. remove screw from back center water pipe (oblong flat 2 piece plastic unit on the back wall inside) and rotate it clockwise to release the tabs under the pump cover. Lift above a carefully move out of the way
  5. loosen and carefully remove 4 screws from the pump cover/ diverter/ screen unit and lift out exposing the top of the pump and motor housing (usually grey plastic)
  6. Locate the screw at the front left of the pump cover that holds down the disposal cover. remove the screw and note which groove the screen is in as well as the side of the screen the blade is on.
  7. Replace the blade/ screen unit or clean the old one (under a tap of warm water and with an old tooth brush) and reinstall it.
  8. Assembly is reverse of above. Note! Be sure locking tabs are under pump cover as before and you don’t drop the screw for the oblong water pipe!
Posted on Feb 12, 2010
DISHWASHER DOES NOT CIRCULATE WATER
It means the spray arm is not moving correctly. Or there is something blocking it. Make sure you don't load tall glass, large plate or cutting boards. There is no waste basket in a dishwasher, only mesh filters. Unfortuantely, all debris ends up in the motor/pump assy. They do have something called a macerator, which breaks-up large food particles. If this macerator is clogged, you will have to replace it.
Mar 10, 2014 | Dishwashers
WATER WILL NOT PUMP OUT OF MACHINE
Here are some solutions for GE built dishwasher when water will not pump out of machine:
During the wash and rinse modes of the cycle, soiled water falls down the back of the tub and into the filter area. The water comes through the filter and back into the tub. During the wash and rinse periods all ( we hope! ) the water will pass through the filter. The soil will settle into the collection chamber and is held there. When the dishwasher goes into the pump out mode the water in the sump is pumped through the collection chamber. This closes the piston valve to the inside of the tub. The pump flushes the collection chamber of all the food soil and pumps it down the drain. A check valve is located in the drain line port. This valve allows the water to flow in the drain direction only and prevents the water from coming back into the tub. The drain line check valve must close in the back flow direction or the piston valve in the collection chamber may not reopen into the tub after the pump out is complete. Water should "fall" through the filter and go back into the tub....the heavier food particles go down into the chamber and are collected.
Jun 10, 2011 | GE 24 in. GSD3960LSS Stainless Steel...
Hot tub keeps pulsating
Occasionally you will find that the jets pulsate rather than provide a steady flow of water. This is often the sign that the filters need to be cleaned or replaced. It could also mean that your water level has fallen so low that a mixture of air and water is being drawn form the tub. Top up the tub and see if that corrects the problem.
If the pump still doesn't provide a smooth flow of water you will have to check the filters. The best way is to turn the tub off and remove the filters. Run the tub for long enough to see if the flow from the pump has been smoothed out. If it has, clean or change the filters. Do not put the old filters back and continue using the tub-this could cause damage to the pump.
If the pump does not produce a smooth flow with the filters removed, there is the unlikely possibility of a blockage in the plumbing. Since the plumbing to be checked is around the pump it should not take too long to do.
With no blockage causing the problem the likely culprit is the pump itself or the electronics that control it. This is something that is best left to the experts.
Fortunately, most problems with hot tub jets are as easy to sort out as changing the filters or topping up the water level. A hard water problem should never arise in reality since a test of your water supply will have indicated that the tub required the water to be treated.
Dec 08, 2010 | Pool & Spa
GE Dishwasher - poor cleaning
I believe there is a screen/filter on the water line before or at the water fill valve. If that gets plugged it can restrict the flow. The fill valve can also fail/get plugged and restrict the flow.
Also, dishwashers usually have a level sensor to tell when there is enough water to do the wash. It may be a float inside the tub that operates a mechanical switch or it may have a hose to a pressure sensor. Either type can get greasy/dirty/plugged and as a result cause improper water levels.
Check both the water supply filter/fill valve and the level sensor. One or both of those may be involved.
Mar 10, 2017 | Kenmore Dishwashers
Dishwasher won't drain
I rethought your problem and will provide a generic answer that is common to your brand of DW....
GE dishwashers will have a sump entrance screen ( #4 ) that should be removed and checked for any gookus, see 1 or 2 screws on the cover top, which is behind the lower spray arm. Almost all ( some newer GE dishwashers have a separate drain pump and motor - but for our purpose, we will talk about the most common GE dishwashers ) GE dishwashers have a drain solenoid ( #1 ) that can fail and stop the draining. If the solenoid cannot pull in the silver plunger, the drain port will not open to allow the motor and pump assembly to drain the water out. The solenoid can be ohmed with an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GE dishwashers have a self clean filter ( #3 ) inside at the back. The draining water must pass through a plunger in the self clean filter body. This can get clogged up, or the plunger may twist and distort and not allow the draining water to get past. The filter can be removed from the inside and the plunger will twist out of the self cleaning body for testing/checking. Next obstacle for the draining water in the back flush valve ( #2 ). This valve can twist or distort and block the water flow as well. The drain port will need to be accessed to check this flapper valve, the drain port will untwist from the self clean filter body. All hoses in-between the items mentioned above and the drain hose itself all the way to the house plumbing should be checked for restrictions.
Some extra filter, draining tips and pictures....
Here is a link for you to check out...I have all this info in my data base but since it is in PDF format it does not translate well to this format...
http://www.applianceaid.com/gedishdrain.html
I hope this helps...good luck and good day...Thanks for rating my effort......thanks....The Fang.
Apr 01, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher will not drain
In order for you to see the diagrams..here is a great link...anyone can use....
http://www.applianceaid.com/gedishdrain.html..you may need to scroll down to get to where you need to be...but these issues are GE specific...and there are other related issues you can see here.
I have all this material in a vast data bank of my own but it is PDF format which does not translate well to these medium.
Good luck and good day...please rate my effort.....The Fang.
Hope this
Mar 28, 2009 | GE Nautilus 24" Built-in Dishwasher
My dishwasher will not drain it is a GE nautilus.
I hope this helps...good luck and ggod day...please rate my effort......thanks....The Fang.
Mar 24, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher stopped draining after cycle
Some water always remains in the bottom of the DW (al least with most DW) but here is some help....
Mar 14, 2009 | GE Nautilus 24" Built-in Dishwasher
Will not drain
Mar 10, 2009 | GE Nautilus 24" Built-in Dishwasher
Ariston dishwasher sticks on drain
hi you may have something in the sump there's a screen on the right side ofthe spray arm with 2 screws remove them and take screen off use yourfingers to probe the cavity be careful it could be glass. If there is something in here it will make a grinding noise and stay in drain cycle forever.
If it does not correct the problem
!.You may have an electric pump . and it could be a check valve at the pump and hose assembly...where the check valve is...see below . so it could be a bad pump but I doubt it.
GE dishwashers will have a sumpentrance screen ( #4 ) that should beremoved and checked for any gookus, see 1 or 2 screws on the cover top, which isbehind the lower spray arm. Almost all ( some newer GE dishwashers have a separatedrain pump and motor - but for our purpose, we will talk about the mostcommon GE dishwashers ) GE dishwashers have a drainsolenoid ( #1 ) that can fail and stopthe draining. If the solenoid cannot pull in the silver plunger, the drain portwill not open to allow the motor and pump assembly to drain the water out. Thesolenoid can be ohmedwith an ohm meter for continuity, or tested to see if it is receiving 110-120 volts AC. Many GEdishwashers have a selfclean filter ( #3 ) inside at the back.The draining water must pass through a plunger in the self clean filter body.This can get clogged up, or the plunger may twist and distort and not allow thedraining water to get past. The filter can be removed from the inside and theplunger will twist out of the self cleaning body for testing/checking. Next obstaclefor the draining water in the backflush valve ( #2 ). This valve can twistor distort and block the water flow as well. The drain port will need to beaccessed to check this flapper valve, the drain port will untwist from the selfclean filter body. All hoses in-between the items mentioned above and the drainhose itself all the way to the house plumbing should be checked forrestrictions.
During the wash and rinse modes of the cycle, soiled waterfalls down the back of the tub and into the filter area. The water comes throughthe filter and back into the tub. During the wash and rinse periods all ( wehope! ) the water will pass through the filter. The soil will settle into thecollection chamber and is held there. When the dishwasher goes into the pump outmode the water in the sump is pumped through the collection chamber. This closesthe piston valve to the inside of the tub. The pump flushes the collectionchamber of all the food soil and pumps it down the drain. A check valve islocated in the drain line port. This valve allows the water to flow in the draindirection only and prevents the water from coming back into the tub. The drainline check valve must close in the back flow direction or the piston valve inthe collection chamber may not reopen into the tub after the pump out iscomplete. Water should "fall" through the filter and go back into thetub....the heavier food particles go down into the chamber and are collected.
Hereis a link for you to check out...I have all this info in my data basebut since it is in PDF format it does not translate well to thisformat...
I hope this helps...good luck and good day...please rate my effort......thanks....The Fang.
Feb 21, 2009 | GE Nautilus 24" Built-in Dishwasher
Kenmore 24 in. 16032 Built-in Dishwasher Logo
455 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
