Question about Dell Latitude D800 Notebook
Cannot access internet
Cannot view local area connections, reformatting computer's operating system
  • Dell Master
  • 1,183 Answers
If i understand the issue correctly. You reinstalled the windows on your computer and the system is not connecting to the network . Most likely reason is you need to reinstall the network driver for the internet .
http://tinyurl.com/ykh8h73
Thanks
proton
Posted on Feb 06, 2010
Can access lan internet
lan stands for local area network so if your connected to the internet your already accessing lan network.
Sep 30, 2012 | Microsoft Windows XP Home Edition
My i pod is connect to my wi fi but will not connect to internet
Wifi allows connectivity for device to device as local area networks. Where connecting the ipod to the computer is a local area network. Also, the computer can use wifi to capture worl wide web connectivity of the internet. The computer requires to have subscription to an internet provider server to make wifi make full capacity observeble beyond device to devcie captures. It is possible to have local and networking across distance with the the wifi.
Feb 08, 2011 | Computers & Internet
I had 1 modem and router with 4 pc and shared the internet connection. but now i need to add another broadband router so that i can use the internet. how can use another router and share the internet...
  • 1Unplug one of the network connections from your old router.
    Ads by Google
    '; for(i = 0; i '+ '' + google_ads[i].line1 + ' ' + google_ads[i].line2 + ' ' + google_ads[i].line3 + '
    ' + '' + google_ads[i].visible_url + ''; } s += ""; document.write(s); return; } google_ad_channel = '+7733764704+1640266093+5860073694+9911500640+7416705818+8388126455+8941458308+6876289738+7122150828' + xchannels + gchans; google_ad_client = "pub-9543332082073187"; google_ad_output = 'js'; google_ad_type = 'text'; google_feedback = 'on'; google_ad_region = "test"; google_ad_format = '250x250_as'; //-->
  • 2Use this open port to connect the old router to the new routers WAN(wide area network) port. If your old router has an uplink port, use this instead of the last LAN(local area network) port and keep the last LAN port open.
  • 3Connect the computers to the ports on the new router.
  • 4Configure the new router settings to match the old router settings.
  • 5Use IPConfig to check you current IP address
  • 6Use this information to create a static IP on the computers connected to your network.
  • 7Set the Default Gateway to the IP address of the router in which the computer connects.
  • 8Check that all computers can access the internet and "see" each other on the network.
  • Oct 24, 2010 | Computers & Internet
    Reformat computer
    you have to format the system and reinstall the windows. i hope you will be find the solution.
    Feb 02, 2010 | Computers & Internet
    Windows server 2003 routing
    i would say use your server as dhcp or set your pcs with a default gateway that is your server.
    Dec 28, 2009 | Microsoft Windows Server 2003 Enterprise...
    Sitecom WL-330 range extender with dlink dir-615- unable to use
    I am guessing you have XP or vista. here are the instructions for both.
    XP 1. Click ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Double-click Network and Dial-up Connections icon, double click Local Area Connection, and Local Area Connection Properties window will appear. Select ‘Internet Protocol (TCP/IP)’, then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
    Vista 1. Click the ‘Start’ button (it should be located at lower-left corner of your computer), then click control panel. Click View Network Status and Tasks, then click Manage Network Connections. Right-click Local Area Network, then select ‘Properties’. The Local Area Connection Properties window will appear, select ‘Internet Protocol Version 4 (TCP / IPv4)’, and then click ‘Properties’ 2. Select ‘Use the following IP address’, then input the following settings in respective field: IP address: 192.168.0.2 Subnet Mask: 255.255.255.0 Click ‘OK’ when finish.
    Next step for both All functions and settings of this access point must be configured via the web management interface. Please start your web browser, and input ‘192.168.0.234’ in the address bar, and press the ‘Enter’ key. The following dialog should be shown: Please input user name and password in the field respectively. The default user name is ‘admin’, and the default password is ‘admin’. Press the ‘OK’ button to see the web management interface of this access point: NOTE: If you can’t see the web management interface, and you’re being prompted to input user name and password again, it means you didn’t input username and password correctly. Please retype user name and password again. After you connected to the access point by web browser, the first thing you see is ‘Status and Information’ page. All system and network related information of this access point will be displayed here. The information is very helpful when you want to know the detailed information of your access point, and when you try to fix the communication problem between this access point and other wired / wireless computer / devices. You can click ‘Home’ on the left, This access point can be operated in different modes; you can click ‘Basic Setting’ to select an operating mode you want to meet for different needs: You can click ‘Mode’ dropdown menu to select operating mode, and there are 3 operating modes available: AP Access point mode, allows wireless clients to connect to access point and exchange data with the devices connected to the wired network. Station- Infrastructure Enable the Ethernet device such us TV and Game player connected to the access point to a wireless client. Universal Repeater This product can act as a wireless range extender that will help you to extend the networking wirelessly. The access point can act as Station and AP at the same time. It can use Station function to connect to a Root AP and use AP function to service all wireless clients within its coverage. You can hopefully figure it out from there.
    Sep 13, 2009 | D-Link DIR-615 Wireless Router
    What is a local Area connection? My laptop doesn't work, but my desktop does?
    Local area connection is the wired network interface card on the computer. On a laptop you'll see the port on the side or back. If you have a internet cable conencted to the port you'll be able to access internet on a wired conenction. Most likely you are conencted wirelessly on the laptop so it shows the local area connection disconnected.
    Jul 28, 2009 | Computers & Internet
    No net connectivity
    If you encounter difficulties accessing computers that are visible on the network map, make sure the computer being accessed has an account with the same name/password as the system connecting to it uses to login.
    To set up Network Sharing between XP and Windows Vista, please note that File and Printer Sharing is different in Windows Vista than from the setup in Windows XP.
    On a computer running Windows XP, click Start, click Control Panel, and then click Network Connections.
    Click Local Area Network Connection, click Properties, and then view the list of items used by the network connection.
    Ensure that the Link-Layer Topology Discovery Responder check box is selected.
    Jul 02, 2009 | Microsoft Windows Vista Ultimate Edition
    Cannot find local area connection to access internet
    IF YOU HAVE A ICON OF A COMPUTER AT THE BOTTOM OF THE SCREEN IN THE BOTTOM BAR CLICK IT AND YOU SHOULD KNOW WHERE TO GO FROM THERE
    Dec 22, 2008 | WiFlyer - Portable, shareable WiFi base...
    Have just bought a computer second hand and have just got internet running with 100% signal but cannot connect because we cannot find local area connection to access files
    As dragoness1 says, you don't need a LAN to connect. Right click wireless icon in system tray (bottom right of screen), select "show available Wireless networks". Select one and click connect. If they're not from your own Internet service, they may be protected by a password.
    Dell Latitude D800 Notebook Logo
    59 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
