Question about Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1
Rheem power vent 2 has light flashing 4 times and no hot water. How to fix this?
4 Suggested Answers
  • 13 Answers
SOURCE: rheem model 41vrp40n power vent water heater won't
"Pres sw open" means there is insufficient air flow. either the vent if blocked, or the blower turns too slow/ or died.
Posted on Feb 12, 2010
  • 409 Answers
SOURCE: Rheem power vent 2 water heater keeps shutting off
you need to replace the upper thermostat, it has the overtemp switch made to it. Also make sure that the thermostat is pushed up tight to the tank with no space or object between them.
Posted on Mar 13, 2010
  • 494 Answers
SOURCE: Rheem Power Vent 2 water heater is flashing 4
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
Posted on May 15, 2010
RichmondG40PVpower vent gas water heater
1) Type and brand water heater unknown.
Copy following link for Rheem-Richmond tankless error codes:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Question posted under Richmond tank-type power vent.
Error code 24 appears to be Rheem-Richmond tankless water heater.
3) Add a comment with more information about type, brand, age of water heater including what you have tried so far.
4) Call service technician to catch up on required yearly maintenance.
Dec 28, 2012 | Audiovox Richmond 6G40-36F 6-Year Tall Gas...
I'M LOOKING FOR THE PART # FOR THE CONTROL ON MY RHEEM HOT WATER HEATER MODEL# 41VRP50N
1) How to replace gas control.
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
2) Identification number for gas control valve appears on side of control. Could be SP12556 Wiper for Natural gas Rheem power vents
http://bostonheatingsupply.com/sp20161a.aspx
3) Copy following link to identify type of gas control valve, and download related troubleshoot manuals:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Dec 05, 2012 | Rheem Water Heaters
Rheem Water Heater and the LED light is flashing 4 times which according to the manual states the the "Vacuum Safety Switch is open and fails to close to sequence, how can i fix this
Rheem does not post service manuals:
Here are resources that can help solve problem:
1) Troubleshoot by type of gas control valve using other water heater manufacturer's service manuals: Service manuals are very large pdf files.
2) Scroll up on same page and on right side is heading 'Pressure Switch' with 2 related pdf files.
http://waterheatertimer.org/pdf/Air-pressure-switch-testing.pdf
3) Post question on pro water heater forum
http://www.thetankatwaterheaterrescue.com/forums/forum3/
Oct 06, 2012 | Rheem Tankless Hot Water Heater...
Are water heater runs for about a minute then the code C7 13 Code flashes and we lose our hot water?
Call Rheem for a new unit. They problem will never be fixed. They have redesigned the unit. It is now RTG-95DVN a self contained venting unit. Mine was worked on several times over two years and much frustration before they finally replaced it.
Sep 05, 2010 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
Rheem Power Vent 2 water heater is flashing 4 times and there is no hot water. Model # 41VRP50NT What can I do to fix this? Do I need to call a plumber?
May 15, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Mar 12, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
There was a bird nest in the blower outlet pipe causing my Rheem Power Vent 2 to stop working. I cleaned out the nest but now it won't restart. I have tried turning it off then back on. The indicator...
you will need to take the vent off and blow it out to make sure noe of the nest is still in also look inside the blower and make sure there are no dead birds, or debris in the blower, it is vary hot air and would not be the first time an animal got freid inside the vent,,,,
Jun 27, 2009 | Water Heaters
Rheem 50 Gallon FVR NATGAS Water Heater 6YR 22V50F1 Logo
594 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
