MY HOTPOINT W/DRYER WD420
MY HOTPOINT W/DRYER IS NOT DRYING IF THE DRYING ELEMENT IS OK.WOULD IT BE A THERMOSTAT OR WHAT IS THE HEAT REGULATER FOR OR IS THAT FOR THE WATER TEMPERATURE. PETER
  • 714 Answers
Yes test the thermostat for continnuity with a multimeter , about 25 bucks for a new 1 ,can order from Repairclinic.com
Posted on Feb 07, 2010
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
I have a Hotpoint Aquarius WD420 washer/dryer that is not heating the washing water, yet does heat when in drying mode. Does the machine use the same heating element for washing and drying, or are there...
There is a seperate element for the water heater. so likely to be a faulty heater or thermistor which is fastened toi the element
You really need a test meter to determine which part is faulty.
Dec 27, 2010 | Hotpoint Washing Machines
My hotpoint aqaurius WD420 is not drying.
Could be stat or heater .Remove the top cover, and you will see the heater manifold on the right side of washer drum.
The element and stat/s are located on the top of the manifold box.
You willneed a meter to test with, also check for broken wires.
Feb 05, 2010 | Hotpoint Aquarius WD640 Front Load...
Not drying , spins and makes all the right noises but no heat
The fault is probably due to thermostat or element not working.
Remove the top cover, and you will see the heater manifold on the top right of washer, this is where the stats and element are located.
Also check for broken wires.
Feb 01, 2010 | Hotpoint Ariston Aquarius WD420 Front Load...
WD420, drying high heat, time saver and ON/OFF buttons are flashing, no function out of machine at all
this usually means that the main pcb has a corrupted eprom or eprom memory has been wiped... you either need a new pcb with eprom or a new board pre-programmed.
hotpoints terms for error
Setup error: check eeprom
F09
Flash
OFF
OFF
Flash
OFF
Dec 18, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Wd420 does not dry washing.
Your dryer exhaust may be full of lint. You may have a defective thermostat. Sounds like you need to call a repair specialist if cleaning out the lint from the exhaust ductwork doesn't help.
Oct 08, 2009 | Hotpoint Dryers
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
The on/off button and saver time buttoon are flashing
Yes I have the same problem but the Drying High Heat is also flashing
Feb 22, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
No heat on drying cycle
If there is no heath at all , then the heating element must be checked for continuity.
If the element is fine, check the thermostat and the connection to the control board.
Feb 18, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
