Question about RCA HD52W59 HDTV Projection Television
No sound on RCA HD52W59YX39 HDTV with the ITC222A
I have a RCA HD52W59YX39 HDTV with the ITC222A chassis. I Recently fixed the flyback and capacitor problem, now I have no sound. Any help thanks!!
Slinteriors
  • 8617 Answers
SOURCE: Service Manual
You can get the service manual emailed to you at the following link. The manual is listed under Thomson the ITC222 chassis is a thomson which is RCA It cost 12.99 but they provide free on line tech support to help you with your diagnosis and repair and they also sell parts with free installation instructions.
http://servicemanuals.vstore.ca/
Posted on Apr 13, 2008
  • 208 Answers
SOURCE: part?
Go to Tritronics or Union or Andrews electronics for RCA parts. They all have websites.
Posted on Jun 10, 2008
Slinteriors
  • 8617 Answers
SOURCE: RCA R52WH74 (ITC222A Chassis)
no the board that has the FL231 on is the ITC222 deflection board. The other board is above the chassis in a seperate frame that runs across the set the convergence power supply is the board on the left above the board where the fL231 is. Yes the ITC222 and ITC222A are the same chassis. As for the service manual that site should have the service manual under the thomson category as the ITC 222 chassis is actually a thomson chassis made for RCA.
Posted on Sep 11, 2008
freetek
  • 5568 Answers
SOURCE: rca 61" televison comes on for a few mins, get turns off
Sounds a lot like a thermal effect.
Buy a can (or maybe two) of freeze spray from an electronics supply company; figure on $5-6 per can.
Open the back of your set and look for a board with larger components on it and fewer small parts; this should be the power supply board. Either enlist a helper or (I prefer) use a mirror so you can see the screen. When the streak appears, hustle behind the set and spray selectively individual components on that board. If you can influence the line, repeat the treatment in a smaller area until you are fairly sure which one is temperature sensitive.
If the component is marked with text, record it. If it is color-coded right down the colors starting from the end closest to the first band.
If you don't want to learn a new skill, namely soldering, you could remove the board and bring it to a repair shop and let them know what to replace.
If you don't find anything sensitive on that board, the problem is going to cost more. You will have to repeat the same procedure using the spray on other boards until you have isolated the trouble area. If you can't single out a specific component, it will have to be sent to one of those 'factory authorised' repair places since failures of parts on the main board will have to be sorted out and then the board will have to be tested in operation and only that kind of repair facility will have the right hardware to do it.
Posted on Dec 04, 2008
SOURCE: RCA HDTV #D61W20, CHASSIS ITC222, PUSH & TWIST CAP ON HV CABLE
do you have the part number for the flyback ? I need it if you would please. send it to
swampbiker@hotmail.com
thank you
Posted on Jul 20, 2009
The picture looks 3D and when you select the menu all writing is in a U shape. The TV is a RCA HDTV and the model # R52WH74YX51. Serial #G402C10DZ, chassis #ITC222A, and was manufactured Oct. 2006.
Its more than likely the FL231 fuse has blown due to carcked solder joints on the flyback. very famous issue with that model if the auto convergence feature is no longer listed under the setup menu then you will need the convergence option missing repair kit from www.tvrepairworld.com
Aug 16, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My big screen won't turn on, but it's plugged in
That model is famous for having capacitor issue and bad flybacks both items are all on the deflection board. You can get replacement deflection boards for the RCA ITC222A TV( which is what your model is) from www.tvrepairworld.com they also include instructions how to remove the old board.
May 25, 2010 | RCA HD52W59 HDTV Projection Television
Is rca r52wh74 and rca d52w14 flyback interchangeable??
No you will need the 270125 Flyback for the R52WH74 as thats a ITC222A chassis. The D52W14 is the ITC222 and uses the 259296 flyback.they are not interchangeable
Jan 22, 2010 | Televison & Video
I have 3d on my 52 inch rca and go to set up convergence isnt there now.is this something i can fix?
Yes its a easy an inexspensive repair. www.tvrepairworld.com has the ITC222 and ITC222A convergence option missing repair kit. The kit contains the parts and CD with instructions.
Sep 24, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA R52WH77 ITC222A chassis convergence problem - FL231 changed!
did you hear an arch before it went if so , one of your crts is arching
and sorry they are not avail anymore
Sep 20, 2009 | RCA Televison & Video
Power wont come back on TV
the most common component to fail with that sympton is the flyback. If the chassis is a ITC222A the flyback will be 259296 or 265409 as they were both used in that chassis and model number. If you need more assistance let me know the Chassis number from the tag in the back.
Mar 13, 2009 | RCA R52WM24 52" HDTV Projection Television
Part?
Jun 08, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
82 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
