Question about Danze Fairmont Double Handle Roman Tub Faucet with Valve and Lever Handles
I need an adapter for a roman tub filler the aerator is about an inch and one sixteenth round with fine threads i would like to install a diverter for a handshower thanks
    Problem Solver:
  • 15 Answers
i need an adapter for a roman tub filler the - c51b8b5.jpgPersonal Shower Adapter Fitting
Remove the aerator from the spout and take it with you to your local hardware store or home center (for sizing purposes). These are usually sold with an aerator thread adapter, which allows it to connect to most faucets in the marketplace.
Posted on Feb 09, 2010
The aerator on my new kitchen sink, model no. A1461LMWSPN-2, spits water out at an angle in several streams and soaks everything in the surrounding area. What can go wrong with something as simple as an...
Either remove the plastic aerator and soak it in vinegar for a minimum of 30 minutes and blow high water pressure (garden hose) to clean it out or call ROHL Customer Service 800.777.9762 fro a replacement aerator.
Aug 12, 2013 | Rohl A1414LMIB Country Bath Roman Tub...
Shower/Tub Diverter Value Low Water Pressure
I had the same problem. I discovered that an O ring was missing (or I lost it without noticing) from a new diverter that I installed. Just got an O ring that fits on the threaded part of the collar where it meets the pipe. Worked fine. Amazing how a little plastic piece could make such a difference.
Jan 25, 2010 | Eljer Arlington Non-Jetted Acrylic Bath...
Moen Tub Filler Can't Remove Spout
It should lift off gently twist as you lift maybe tap spout lightly back and forth with a rubber mallet
Oct 14, 2009 | Moen Kingsley Two Handle Roman Tub Faucet...
Danze sonora roman tub personal shower stopped spraying, no kink in hose, no plug in sprayer
I had the same problem and just now fixed it.  Remove the faucet head - the tub filler - and pull out the diverter tube insert.  It's the valve at the bottom that's sticking - probably because of calcium or mineral deposits.  I washed mine with white vinegar and pushed a wooden spoon handle down the tub to unstick the valve, scrubbed it with vinegar and a toothbrush and re-installed.  Works perfectly now.
Jun 27, 2009 | Danze D303754CSN Sonora Roman Tub Faucet...
Hand held shower in Jacuzzi tub not working
you may have something in the line,take it off and check both the line and the handheld.
Jun 08, 2009 | Price Pfister Roman Tub Hand-held Shower...
Leaking valves in new roman tub faucet installation
take the valves out and check the valve seats use flashlight if they look good then very carefully put your finger in and feel for any burrs when in doubt just replace the seats this is always a good practice when replacing valves
Mar 26, 2009 | Plumbing
Diverter valve does not work correctly.
the connections are reversed,just change them over and this will fix the problem.
Feb 18, 2009 | Grohe Eurosmart, 3-hole Roman Tub Filler...
Shower spout
There is a threaded stem that passes through the spout and attaches to the white plastic diveter valve. If you are starting from scratch (everything apart), you can put it back together in this order:
1) Place the white plastic diverter inside the spout. the circular side with the black round washer should face the the wall side of the shower (mating up against the threads for the water pipe).
2) The stem can now be inserted from the top and into the notched section of the white plastic diverter valve. The threaded end of the stem shoud be outside of the spout (from the top side).
3) A round black washer fits over the threads. It should sit right where the threads end. Dont push it all the way on to the unthreaded portion of the stem.
4) Screw the threaded knob onto the threads.
Should be ready to install now. Including the spout itself, there are 5 parts and are configured in this order from top to bottom.
1) Female threaded knob (the knob for operating the spout)
2) Threaded stem (threads on top)
3) Round black washer
4) Spout
5) Whit plastic diverter valve.
Mine leaks when I turn on the shower, thus reducing shower pressure. I looks like a poor design to me. The stem is not a tight fit in the spout and this allows the diverter to "wobble". The washer on the diverter valve does not seat tightly and allows water to leak out the tub spout when showering. I would replace the spout.
Jan 30, 2009 | Price Pfister 01-311 Shower Head, Tub...
Ghroe Seabury 25502 roman tub filler leaking at liftrod control
It can be repaired.
You can see an exploded diagram here
I can post more if you need more specific instructions.
Nov 22, 2008 | Grohe 19.045.000 Seabury Thermostatic...
Danze Fairmont Double Handle Roman Tub Faucet with Valve and Lever Handles Logo
872 people viewed this question
Top Danze Plumbing Experts
Donni Steen
john h
Andrew Bugbee
Are you a Danze Plumbing Expert? Answer questions, earn points and help others
