Question about RC Remote Control Helicopter Ready To Fly
My Yiboo CH-47 has flying problem. It lifts up off the ground, but then the front end points downward and back (red) end lifts higher so it ends up crashing back into the floor. How do I fix this
3 Suggested Answers
  • 2973 Answers
SOURCE: Yiboo ch-47 rc helicopter: Rear
If you twist its rotors a little more then the lift can increase. But try to twist then only if they could be else you may become minus them and I would hate it.
Posted on Feb 27, 2010
SOURCE: Yiboo UJ4708 will not lift even after being fully
i had the same problem.. one of the gears isn't fully engaged.. if you look at the internal mechanism, you'll see two small gears on opposite sides, each engages a larger gear... during impact, these gears can slide and become not fully engaged. That is the strange sound you are hearing. this also prevents the propellers from spinning up fast enough to get fully off the ground. I used a small jewelers screwdriver to reach in and push the problem gear back into place.
Posted on Dec 27, 2010
Yiboo uj422 helicopter won't charge
Sounds like your batteries have gone bad.
Nov 10, 2014 | Toys
Why does the Water valve keep running water when bowl is full?
Because the shut off point is above the overflow tube. You will need to either adjust the arm or bend the float end of the arm downward to make the arm end swing higher to reach the shut off point prior to water overflowing into the tube.
Apr 27, 2014 | Korky Waterwise Toilet Fill Valve 528Z
My yiboo heliocopter uj4702 wants to fly backwards.
you have stuck up controller and receiver contact points, means you need to check both on the controller and the copter where the stuck up sensors are, or you may recalibrate your controller, reason why you push throttle forward but will not fly forward.
Dec 27, 2013 | YIBOO Toys
Hi, I just bought your product SYMA s107. I took it out of it's box and I started flying it. At first it was flying great but after a couple of minutes it started to not even lift of the ground. I charged...
you should have charged your heli BEFORE 1st flight.......anyway,,plug computer end of usb charge
cord into computer......turn heli OFF....before you plug cord into heli look at computer end of cord,,
should be bright red light inside......now plug other end of cord into heli.....bright red light goes out!
when heli is fully charged bright light on computer end of cord comes back on......disconnect
heli right away.....if left on charge your battery could wear out....it takes about 50-60 minutes
Feb 25, 2011 | SYMA Toys industrial New Syma S107 Radio...
Hi...I bought a syma s018 rc mini helicopter a week ago and it was working great but now, when i fully charge it, it doesn't have enough power to lift off the ground. Is my battery defective? It seems to...
I believe the Syma S018 is the same as my Yiboo UJ417.
Mine never got off the ground out after charging for an hour.
It just skitters along the ground. Must be a bad battery. Returning it if I can.
Nov 13, 2010 | SYMA Toys industrial Syma S018 Air Wolf...
Yiboo UJ4708 will not lift even after being fully charged. It will just hover an inch off the ground. It doesn't sound right to me either when its running.
Sep 28, 2010 | RC Remote Control Helicopter Ready To Fly
Yiboo ch-47 rc helicopter: Rear rotor has reduced lift, does backflip when attempting liftoff. Rear rotor turns more slowly when tapping the "collective" on the RC. Took skins off, all 4 shafts turn...
Feb 26, 2010 | RC Remote Control Helicopter Ready To Fly
MY YIBOO CHINOOK HAS A BROKEN MAIN BLADE HUB. WHERE CAN I FIND REPLACEMENT FOR MAIN BLADE AND SHAFT?
I found this on xheli.com. Syma S022 big CH-47 chinook.
Looks like the same heli as Yiboo. Lists all spare parts.
Good Luck. Please post results if you order from this site.
I also have the Yiboo CH-47, have not needed parts yet, just got it for xmas from my wife.
Sep 15, 2009 | RC Toys
How to put toner in the printer
Open the front cover .You will see a green leaver pointing downwards , lif te leaver to the upwards position on the left side underneath the toner you wil see a little green pin ,push it downwards to release the toner pull towards you , move the old bottel little bit backwards and lift , it will come out , remove the black turn off screw from the new toner and insert it with the end were you unscrewed the cap pointing towards you.push back the holder until it clicks , move the green handle downwards again and close the cover .
Nov 11, 2007 | Gestetner DSm735sp Printer
RC Remote Control Helicopter Ready To Fly Logo
401 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
