Question about Kitchen Ranges
My oven makes a gasping for air noise
When using my oven, it makes a gasping for air type of noise about every 30 seconds to a minute. It sounds like it is struggling to get air, so I will open the door to the house to let air in. However, this does not work, and it continues toa make that gasping type noise. Can you help? I will greatly appreciate any advice. Thanks, Scott
  • 80 Answers
Does it sound like a blow torch? if so yuo have a delayed burner iginition and flame is actually burning inside your burner, I like to know more info to help you, is it propane? natural gas? what is the air shutter on burner set at, this will depend on gas used..
Posted on Feb 06, 2010
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Kenmore Gas Range. Top burners work fine. Oven is slow to preheat. Igniter has a yellow glow and the burner lights within about 20-30 seconds later. However, the burner has a very small flame and it takes...
the ignitor should glow bright orange.it sounds like you have a weak ignitor but if the flame lites within 20 to 30 seconds it sounds like it's ok,it could be braking down though when it gets hot,it doesn't matter if it glows,it has to be putting out 3.2 amps,if you have an amp meter with a clamp on it you can read out the amps,if the broiler works ok i would change out the ignitor,then follow the tube down to the bottom and stick a paper clip in the orifice hole where the gas comes out and make sure that's clear,also there's a shutter on the tube to adjust the air flow,see if it's closed,it's usually almost wide open,check the tube to make sure the ignitor didn't burn a hole through it.i've found tubes with holes in them from a lazy ignitor,most of the time if there's a problem it will be the ignitor
Jan 23, 2011 | Ovens
I have an Ingersoll Rand T30 10 HP compressor that runs OK and will bulid up 150 psi without any problems. But when the pressure drops enough to kick the pressure switch, the motor won't start. just tries...
When the compressor comes up to pressure and kicks off, you should normally hear a gasp of air escaping. That gasp is the release of pressure from the compressor itself - not the tank, and it is supposed to get released so that the compressor can restart without being preloaded with compressed air. My guess is that the gasp is not happening. It is probably some debris or a gummy mechanism. The mechanism is supposed to be triggered by the same mechanism that shuts off the motor.
Aug 30, 2010 | Ingersoll Rand Type 30 Reciprocating Air...
Yesterday my GE JE1390WA, stopped working. After being dead for about 30 minutes it came back on, but sounds like a fan is continuosly running and says RESET. If I do nothing it makes fan noise for a while...
Please disconnect the set, open the cover of the oven , then the front panel assembly. Inspect carefully for any signs of insect/ coakroaches within the set, if so use a good blower to clean the inside, use a hot air dryer to warm for any insect dirt. once you have finished checking for any loose connections and the clean status, close the cover back and check on the set. If it does not work well try settting the clock and test. Hope this helps. Good day.
Jul 04, 2010 | GE JE1390 Microwave Oven
I cannot use the oven
F1-E1 - EEPROM Checksum Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 29, 2010 | Kenmore 47712 / 47714 / 47719 Electric...
High pitch winding noise on cold start up.
Sounds like a constricted IAC Idle air control valve passsage. Fairly simple to fix. Remove air filter trunking all the way to the throttle body to allow access. The IAC allows air passed the throttle when closed at idle. Just on the inside of the throttle body in front of the throttle flap there is an opening in the throttle wall. This is the air inlet to the IAC; there is an outlet similar on the other side of the throttle. Use carb cleaner and cloth to shift the grime from this tubing and get it like new. Hold the throttle flap open to get at both ends of the IAC tubing. The IAC can be detached and cleaned to a shine. Reinstall the IAC and replace all air pipe ducting. Leave for about 20 minutes to allow any cleaner residue to dry out. When you restart you might experience a bit of uneven running but this will disappear very quickly as the last of the cleaner dries out
May 04, 2010 | 2004 Chevrolet TrailBlazer
What kind of sound does the species/animal fox make?
i have had the pleasure of watching foxes at play many times and they make a lovely sound when calling to each other its a thoaty sound imaginge gasping in fear then put a or sound in to it or a ow ow sound but if you do it right it will hurt your thoat a littleits not a bark.. it travels very well over the air. i know try making a door creaking noise then do it with the ow sound and pull the sound back into your throat by gasping in not spaeking it out,,, hope that helps my little boys are looking at me as if im mad makeing these sounds on my sofa...
Jan 30, 2010 | 3d Rose Wild animals - Red Fox - Light...
Our kitchen Aid Superba Double Oven makes noises when we turn it on and also as it cools down. It sounds like a fan-type noise. How can we fix it?
We had the same problem. It is the fan in one or both of the ovens. we had a repairman come out because the ovens have to come out of the wall. It was a quick fix.
Oct 04, 2009 | Jenn-Air Electric Double Oven
Kitchen Ranges Logo
184 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
