Question about Dyson DCO3 Absolute Bagless Upright Cyclonic Vacuum
The hose does not pick up with the hand held brush, why?
  • 715 Answers
See if hose is clogged
Posted on Feb 06, 2010
Why won't my shark navigator cordless vacuum pick anything up?
Sometimes everything seems to be fine. The brushes turn, but if the brushes aren't cleaned of hair, rug tangles and so on, the brushes on the vaccum get filled and it won't puck up anything. ON THE OTHER HAND if the brushes are clean, did you check all your hoses from thr base of of vaccum where things get sucked up to the bin?
Jan 27, 2016 | Shark Vacuums
Belt not turning while motor is running therefore will not pick up
Possible belt is broken or stretched beyond use. Should replace also your brush ends could be seized.
If you can turn the brush by hand its you belt that's the problem.
Nov 05, 2015 | Vacuums
My vacuum isn't cleaning/suctioning very well. The hose attachment will work and pick up debris but the main part of the vacuum (where the brush is) doesn't pick up. The brush only spins but there...
Check to see if the brush is turning when you have the vac on and the handel down 'of course keep your hands from that area when doing this ,you might have to lean the vac ,to see the resaults.
Jul 09, 2011 | Panasonic MC-V7582 Bagless Upright Vacuum
I have full suction with the hose and when the brush is off of the vacuum. However, in the vacuuming position, there isn't enough suction to pick anything up. I checked for clogs and cleaned all the...
So I have exactly the opposite problem, it sucks in floor mode but the hand held has zero suction. My daughter and i just spent the last hour disassembling and diagnosing and found this: The way the suction tube is configured, you have two places to **** from, the floor and the hand held hose. If you look at the back of the machine, you can see the "y" where the two hoses join. just behind the beater bar there is a blast gate that closes when you stand the machine upright. This closes the blast gate and directs full sution to the hand hose. In floor mode as the handle tips back, a follower wheel and spring move the blast gate to open. THIS IS THE IMPORTANT PART...if the hose is not docked, there is a second place for the suction to go and you will get no suction at the floor. In my case, the center post where the spring mounts is broken and the blast gate flap does not close, so the hand hose gets no suction because it is like a straw with a hole in it, the air will seek the least resistance. In your case you either have not returned the hose to the docking port or your blast gate is stuck in the closed position. To check this remove the two screws and clamp that secure the lower hose to the suction manifold. Pull the hose stright an look inside to see if the blast gate is open or closed. Use the release pedal to cycle the machine between upright and floor mode and you should see the blast gate open and close. If you don't, well that's a whole other story. I'm off to see if I can find a replacement part at repairclinic.com. If not I will have to get some polyester epoxy and fix it myself.
Jan 02, 2010 | Hoover U6630-900 WindTunnel Bagless...
Have water at the hand held but none out the bottom
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
jhklui
Nov 16, 2009 | Bissell 1699 ProHeat Clear View Upright...
The cleaning solution stopped coming out of the rotating brush but still comes out of the hand held vacuum hose.
If you can check where the vacuum hose where it is connected their might have dirt in the opening to the rotating brush,or it is glogged,clean with a wire and it will be ok
Oct 10, 2009 | Bissell SpotBot Robotic Wet/Dry Vacuum
My Hoover upright vacuum runs but isn't picking up
Either it's clogged, has a broken belt, or the bag needs to be replaced.
Hope this helps.
Aug 19, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Suction only works using the hand held mode, there is no suction when try to use on carpet mode,
There must be a clog in either the hose, dirt inland by the brush roll, or bad filters. If you have suction at the end of the hose, then look lower all the way to the brush roll.
Mar 25, 2008 | Vacuums
Lint from the carpet not being picked up, why?
Either the brush roll is not turning, or you have a clog at the inlet by the brush roll or in the hose.
Feb 09, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Dyson DCO3 Absolute Bagless Upright Cyclonic Vacuum Logo
41 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
