Question about Belkin F5D7234-4 Router
Phone interference i have one your routers and when it is hooked up it causes a buzzing on my phone line is there anyway to fix this
    Scholar:
  • 62 Answers
Try looking into the settings of your router and set the channel to 6. this way the interference shall disappear, or at least be reduced. this may be happening because both of your devices use the same frequency (generally 2.4GHz). the channels were made to avoid these interferences, since wireless networks may work on frequencies close to 2.7Ghz.
Posted on Feb 06, 2010
Testimonial: "thank you it worked "
How do I stop getting interference on my cordless phone due to the Belkin N Wireless Modem-Router F5D8633au4A ? Is there a way to change channels or frequency ?
These interference are caused by unfiltered telephone lines, electronic gadgets near the phone or router. Make sure your phones are all filtered and there are no electronic gadgets near the phone or router and keep the phone at least 3-5 feet away from the router.
Thank you for choosing FixYa! Your rating will help me succeed and continuously help a lot people.
Jan 28, 2011 | Belkin N Wireless Modem-Router F5D8633au4A
There is a buzzing sound on my end of the phone line, my computer is on DSL and sometimes it disconnects when the phone rings. I've checked the cords and the phone has a new battery.
You have interference due to the DSL overlapping your phone line its usually very common, make sure you have a DSL filter inline with your phone line , if not I would check out the RJ-45 jack in the wall, your phone jack and make sure that there isnt anything wrong with your Jack, you may have to call your phone company and have the phone tech's check out your wall Jack for any interference, they have special phone line meters to measure all this out.
Good luck,
Lex...
May 23, 2010 | Uniden Cordless Phone
Constant Buzzing sound on recipients end
it might be due to EMI(electromagnetic interference). if other phones or internet lines r nearby, u can hear the buzzing sound.. if EMI is the cause, then its best to keep the phones isolated from the devices causing them. Good luck!!
Oct 04, 2009 | Uniden Cordless Phone
I have a buzzing in my cellular phones. I took
Apparently, there was a problem with my phone line. Verizon began a fix to the problem, and it was fixed in about 24 hours. Now, I hae to somehow put the new phone system back in it's box for a return to Best Buy.
Jun 12, 2009 | Panasonic DECT 6.0 Expandable Cordless...
Signal strength keeps varying
if you arent in a clear line of sight, many things can affect the signal strength of your network including the thickness of the walls, the composition of them and anything else that may be in the way. if you use a 2.4 ghz router and you have a 2.4ghz cordless house phone, they can interfere and cause issues. A microwave oven that is located between the router and a device can cause interference as well.
Jun 10, 2009 | D-Link Xtreme N DIR-655 Wireless Router
I have buzzing on my phone when my Belkin n modem router is on . i have just brought new Uniden 5.8GHz phones i have 2 adsl line filters but stil the buzzing persists can you help
The frequencies of the phones and the modem are causing harmonics. You should have the ability to change channels on the phones, just turn the phone on and when you hear the buzzing start changing channels on the phone till it stops. You should have at least twenty five channels on the phones. Hope this helps.
May 17, 2009 | Belkin N1 Vision Wireless Router
GE Dect 6.0 Cordless - Loud Static
question is are you running a pc and router/ modem on the same land line
if so you will need the line filters to the phone base
the computer data is transferred by the same land line and there is every possibility that the different frequencies is what is causing the static
reference from a uniden trouble shooter ( will be common as the phones use the same medium)
lots of noise or static on the line === possible solutions --check for interference from appliances ( microwave , tv etc ) or wireless devices ( baby monitors wifi equipment etc)
move the handset base away from the source
if you have any device that uses the phone line , add a DSL or telephone line filter to the system
it is possible from the times you state that the interference could be coming form a neighbour or further down the line so the filter may be the option
available from phone shops or places like JAYCAR
Jul 11, 2017 | Uniden Cordless Phone
Wireless router and home phone
it is highly unlikely that your router would disable your phone. Although there is a possibility it may cause static on the line.
Feb 03, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Dsl light keeps flashing
Your router is not synchronized with the line. You should power cycle your router (i.e)disconnect power cable from the router waith for 30 seconds and then reconnect, check if the dsl cable is connected properly to the router, if yes remove it once and the reconnect it, this should fix the problem. Are there any electrical devices near the router that are only switched on at that time of day and then switched off again in the morning. What i'm thinking is that you are experiencing REI or Repetitive Electronic Interference. This is caused by EMP emmisions form devices nearby. Have you had anything fitted recently that may be hardwired into you master socket, this will bypass your filter and cause interference on the line. The only other thing I can think of is that there maybe some engineering works going on at the exchange or on the line.
Nov 20, 2007 | Zyxel Prestige 660R Router (91004397002)
Belkin F5D7234-4 Router Logo
66 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
