Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
My futura CE-200 was working fine and then all of sudden it won't recognize the usb cord is attached and the machine is on. I have updated drivers and reinstalled the software. No help. What's wrong?
  • 1 more comment
  • sjwagner Feb 07, 2010
    I have tried replacing the usb cable.
    Explain "try another port"
    I only have one computer.
    When I go to Device Manager, under Network adapters there are the yellow warning signs with exclamation marks.
  • sjwagner Feb 08, 2010
    It's telling me that it can't install the driver because it is "unsigned"
  • sjwagner Feb 09, 2010
    Okay, I installed the software on another computer and it didn't work there either. So that means it's the software or the machine, right?
  • 6,993 Answers
test the futura with another computer and see if it will recognize it. If it recognizes it on another computer, then maybe you should use a different port on your computer.
But if it does not recognize another computer, then the fault should be from the usb cable and maybe that's why its not recognized by the computer.
Therefore, you will have to change the USB cable of the Futura.
Take care.
Posted on Feb 06, 2010
  • 1 more comment
  • Walesarumi
    Walesarumi Feb 07, 2010
    "another port" means another usb space on the computer. Or does your computer has just one usb port space.
    The exclamation mark, means that driver of the device with exclamation is not installed. So maybe you should re-install the drivers for your futura if you have any.
    Take care.
  • Walesarumi
    Walesarumi Feb 08, 2010
    try to test the futura on another computer and install the drivers on it.
    If the other computer accepts/installs the driver, then your computer is the one that is refusing to install the futura and maybe you should juts leave it for a while and try again later.
    But if the other computer still does not install the driver, then it will be clear that the driver might be corrupt or the problem is from the futura.
    Just try this and let me know what happens next.
    Will be expecting your response, hoping it would be positive.
    Best regards.
  • Walesarumi
    Walesarumi Feb 09, 2010
    right, its the machine/software.
    Is there any machine repair shop that will cost less in your vicinity? Because I think that's the next option since you have changed the cable and its still not working fine.
    Or what do you think?
    Best regards.
My Singer Futura CE 200 embroidery machine will not work. The part of the USB cord that attached to the actual machine is not working. When connected, the computer says it is not connected. I know it is...
USB ports are known to fail- try connecting another device to your computer to see if it is recognized and is functional.
If so, then the port of of the Singer has failed.
Oct 14, 2014 | Sewing Machines
USB cord for Singer CE 200 quantum Futura
I would suggest contacting the singer website customer service and ask them or contacting a singer dealer about the cord..
Jun 20, 2013 | Sewing Machines
My futura does not have button holds programmed into the machine so I cannot make a button hole with this CE-200 machine can it be downloaded and programmed into the machine? Thanks, jan
You can download the latest software from here.
Make sure you follow the procedure outlined in the manual carefully. The manual is located here.
If you still have problems, you might have better luck getting more specific answers by posting to a forum that is more sewing centric. Find such forums by searching google for: CE-200 futura forum
Feb 12, 2012 | Singer CE-200 Quantum Futura Computerized...
I have Dell Inspiron 1545. Bought Singer Futura CE-250. My computer can't find the driver and I've updated all drivers existing. When clicking on the program shortcut I get a notice that it can't find...
Make sure you're plugging the USB cable from the machine intoa USB port in the BACK of your computer, not one of the front ports or a porton a USB hub. The cable and machine need more power than most of those portsprovide, a technical detail that Singer doesn't realize. Good luck!
Dec 16, 2010 | Singer CE-200 Quantum Futura Computerized...
I am running vista and I click on futura symbol and get a message connection error. Both the usb cable is connected and machine turned on.
I believe that you will need to update your software in order for it to work properly with Vista. The drivers for machine communication were probably for XP. They are available online. Look in you help section of the software for procedures for updating.
Dec 12, 2010 | Singer CE-200 Quantum Futura Computerized...
NEED SOFTWERE OF SINGER FUTURA QUANTUM
Can find details about this upgrade in the Singer Link.
After you have downloaded the update patch, plug in the USB cable, turn on your machine and the drivers will finish installing.
Hope helps (remember rated this help).
May 26, 2010 | Singer CE-200 Quantum Futura Computerized...
My quantum futura CE-200 won't work on my new laptop which has windows 7..Anyway to correct this problem...
If you are using Futura 2.0.0.x software there is no update yet, but Windows 7 support has been already included into update for Futura 2.5.0.x. You may ask a closest Singer supplier about it.
Feb 21, 2010 | Singer CE-200 Quantum Futura Computerized...
My Singer Futura CE-250 keeps giving me an error
"PC" symbols on the machine panel if it is not connected to PC and switched on is a normal behaviour.
As for communication failure try to remember whether something on your pc has been changed: windows upgrade, machine got connected to another usb port etc. If any of such changes have been made try to reinstall Futura software. Otherwise launch troubleshooting utility and send its report to futura-support.
Nov 14, 2009 | Singer CE-200 Quantum Futura Computerized...
Singer CE0100 Futura connection error....
Hi I had the same problem sent question to Singer and this was their reply
"Do you have Vista 32-bit or Vista 64-bits? Unfortunately the CE-100/200 machine will not be compatible with either Vista 64-bit systems or the newest Windows 7 computers. The CE-100/200 will only be compatible with Windows 98 through Vista 32-bit operating systems.
This appears to be a hardware issue and not something that we will be able to create a patch to correct. Drivers necessary for 64-bit operating systems are not compatible with the CE-100/200 machines." so I guess we are SOL
Sep 27, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
69 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
