Question about GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket
I need a tech sheet for a ge profile harmoy gas dryer, model dpgt750gc1pl
    Brigadier General:
  • 7,191 Answers
You can download the Quick Specs guide in PDF format by clicking this link
To download the Installation Instructions , click on this link
You'll require Adobe PDF Reader installed on your PC to view this manual. If it is not already installed on your PC, download it free from:
http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa
Posted on Feb 06, 2010
  • AliTech110
    AliTech110 Feb 06, 2010
    For more details and specifications, click on this link
    Thanks
I have a GE profile Harmony gas dryer model #DPGT750GC1PL. the dryer runs but there is no heat or air coming out of the vent. diagnostics do not indicate anything wrong
see this causes and fix it. God bless you
There's no heat dot_lineone.gif 1. Gas valve coils
Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
2. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Note: It is recommended by most dryer manufacturers to replace a hi-limit thermostat when replacing a thermal fuse.
3. Igniter
Igniter may burn out or break. Replace the igniter if found defective.
Note: Igniters are very fragile and break easily. It is recommended to handle the igniter only touching the ceramic part of it (usually white in color).
4. Flame sensor (or radiant heat sensor)
Replace the sensor (located near the igniter) if found defective.
Oct 02, 2012 | GE Profile Harmony DPGT750GC Gas Dryer
My GE Profile Gas Dryer DPGT750GC1PL is giving me a message to contact a technician. I discovered a bird's nest in the outside vent which had it totally clogged, so cleared that, then cleaned out the...
typically the code and be cleared(if you havent already done this) is to unplug the dryer for 5 minutes and plug back in and temporary memory such as error codes are cleared. IF a problem persist after clearing the error code will return.
Gene
Aug 05, 2011 | GE Profile Harmony DPGT750EC Electric...
The dampness sensor on the ge profile gas dryer is off - is it possilbe to reset and turn back on?
The dampness sensor is just the two curved metal strips (about 5 inches long, and about an inch apart) located very close to the lint filter. (stick your head in the drum and look back down to your right) These strips can become coated with a waxy substance from fabric softener sheets which prevents them from detecting the moisture correctly. Just clean them off with a little soap solution.
Nov 04, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Purchased a damaged GE dryer. Model and Serial number removed.
Model tag is inside door frame or at the bottom corner on the side. It may have been removed or not replaced if the front panel was replaced, Eric
Jul 07, 2009 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
Ge profile dryer dpgt750gc1pl
Is your dryer gas or electric? I think based on your model number, it possibly looks like your dryer is gas. Regardless, you need to look at what the service mode troubleshooter tells you. To access it:
1. Press the POWER key to turn the dryer on.
2. Press HELP. The main help screen is displayed.
3. Press and hold MY CYCLES and BACK simultaneously for 3 seconds. Press EXIT to return to the HOME screen.
Let me know what it tells you and I can help you further from there.
jeryflores@hotmail.com
Apr 08, 2009 | GE Profile Harmony DPGT750EC Electric...
Dryer model#DPGT750GC1PL
Huuum At your service!
With an error code.
This can reset the system.
First unplug the washer and wait a 5 minutes then restart it.
If you can't reach the plug, use the breakerto cut the power for 5 minutes.
It's like rebooting your computer when its acting strange!
Usually it corrects some error problems if they are not serious.
Or they are sometimes just a glitch.
Let me know how it works out.
How old is the appliance?
Please remember to leave a rating before you sign off.
Sep 02, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony Gas Dryer DPGT750GC1PL not heating
post your email i will send you the book there are too many things to check via posting here
Mar 09, 2008 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony DPGT750EC Electric Dryer STOPS without pattern
You didn't state whether or not you were getting an error code. On this model if the blower motor exceeds 3000 rpms for one minute the dryer will stop. Usually this is caused by a clogged or pinched vent hose or vent itself. Check this out first. You can find the tech sheet under the consol. I believe it unscrews from the back and lifts up. This will give you detailed info on how to enter the diagnostic mode. If you cannot find the tech sheet, post back and the cat here will walk you through it. Catriver..post back.
Oct 24, 2006 | GE Profile Harmony DPGT750EC Electric...
GE Profile Harmony WPGT9360E 4.0 Cu. Ft. King-Size Washer with Stainless Steel Basket Logo
66 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
