Monitor LG Flatron 1960TQ flickering problem
Lg flatron 1960tq flickering problem on Windows XP SP2 and EVGA Nvidia 6200 Video card.
Fix-4U
  • 293 Answers
SOURCE: how to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
Posted on Dec 06, 2008
SOURCE: LG Flatron Monitor-adjust height and color
https://support.dell.com/support/edocs/monitors/1908FP/en/ug/stand.htm#Using%20the%20Tilt,%20Swivel,%20and%20Vertical%20Extension
4:29:29 If locked in the down position, 1. Push the monitor down, 2. Press the Lock down / release button on the bottom rear of stand to unlock the monitor. 3. Lift the monitor up and extend the stand to the desired height.
Posted on Apr 12, 2009
mjcarrasquil
SOURCE: I have a L194WT LG Flatron monitor. One day it
Same problem started happening two days ago and ever since. I called LG and the product falls under a 3yr product warranty according to them (from my original purchase date of January 20, 2007). They will send packing slips to me so I can send the defective unit back to LG. I was told I am eligible for a replacement monitor - which will be shipped to me within 10 to 14 days (consecutive days, not business) - although I'm not sure what I'm being sent in return. My suspicion is that this monitor issue is a known issue by LG and they are quietly replacing the unit to those who follow through by calling CS.
Tips: Have your original purchase date on hand (in the form of a receipt) just in case they want proof of purchase.
Posted on Apr 27, 2009
wagyp
  • 86 Answers
SOURCE: lg flatron won't turn on
have u checked the internal fuse take the back off and look for a glass fuse
Posted on Jul 26, 2009
SOURCE: LG Flatron W2234S Monitor Monitor goes black
Ahh the same thing has happened to my monitor! Mine unfortunately is 1 month over warranty. Apparently this is a common problem with this model!
Posted on Nov 02, 2009
Testimonial: "Excellent advise and many thanks. But it seems that this model does suffer some problems with this fault and LG knows it."
HOW TO FIX LG FLATRON 1750HQ OUT OF RANGE WITH WINDOWS XP?HOW TO START THE MONITOR ON A WINDOWS XP IT WORKS ON VISTA HOWEVER ON XP WINDOWS IT SAYS OUT OF RANGE WHAT ARE THE CORRECT SETTINGS FOR WINDOWS XP...
your refresh rate is set too high. boot into safe mode set to 640 x 480 then reboot. once it is up try adjusting the refresh rate to around 60 or lower. or buy a newer monitor.
May 20, 2014 | LG Flatron 563LE 15.1" LCD Monitor
MY MONITOR MODEL IS LG FLATRON T705SH I CANNOT ADJUST MY SCREEN RESOLUTION I WANT TO KNOW THE VALUES SUCH AS POSITION: SIZE: SHAPE: PLEASE HELP ME OUT SIR AS SOON AS POSSIBLE
Your monitor supports a maximum resolution of 1280 x 1024. If windows fails to give you the option of changing to this resolution and those below it then please follow these suggestions:
Update your video card drivers, if you don't know the manufacturer of your video card try windows update.
Install the latest drivers for your monitor as well.
Your monitors driver click HERE
May 04, 2011 | LG Flatron F700B 17" CRT Monitor
Not able to use full screen
This sounds like bad resolution is set on your computer. The LG 22" FLATRON monitor has a native resolution of 1680 x 1050. However, your video card may not support this so you can also try any other 16:10 resolution like 1440 x 900.
To change your resolution in Windows XP:
1. Access the Control Panel.
2. Choose "Display".
3. Click the "Settings" tab.
4. Under "Screen resolution" move the slider to a 16:10 resolution like 1680 x 1050 or 1440 x 900.
If you computer does not support higher resolutions, you may consider replacing your video card to take full advantage of your nice 22" Flatron monitor.
If I can further assist you, please let me know.
Regards,
KYTechnology
Mar 01, 2011 | LG 22" FLATRON LCD Monitor
Screen flickers and goes off
maybe its the video card. or the monitor...one tips: try ur monitor to other system unit.. if its still flickering.. monitor needs replacement or call your dealer..
hope this can help,
JABEMS
Dec 02, 2009 | LG Flatron L1750S 17" LCD Monitor
LG L1940HR screen blinks for 1 min. when turning monitor on
some monitors blinks when you have a start up. this usually happens on an outdated video cards. so if it works fine then its ok then. but try checking if you have the latest update for your video card. this happens on an outdated nvidia geforce 7300 go on a laptop runing on windows vista 32 bit. once i updated the videocard, it doesnt blink anymore at start ups.
Feb 06, 2009 | LG FLATRON L1970HR LCD Monitor
LG FLatron W2252TQ Not working properley in DIgital mode.
Fixing power problems with your LG Flatron Monitor (LG1753S) ' Just ...
blog.lopau.com/fixing-power-problems-with-your-lg-flatron-monitor-lg1753s/
Fixing power problems with your LG Flatron Monitor (LG1753S) ... So after checking the power isproperly plugged, I shut down my pc again. .... I can start a game and then change the resolution, Popp of "energy saving mode digital" led goes ..
Mar 21, 2017 | Computers & Internet
G Flatron L1515S 15" LCD
monitor display center line problem
Aug 14, 2008 | LG Flatron L1515S 15" LCD Monitor
My LG Flatron L1515S Lcd moniter is Flickering
i am having also same problem...
Reddy - 9700704407
EVGA GeForce 6200LE halt the system
in my opinion it's a hardware malfunction, try reinstall the graphic card and before that wipe the cards contacts with pure ethilic alcool (96% vol) then put it back in.
And by the way try using a set of diferent drivers both mobo and graphic
Regards :)
Nov 14, 2007 | Evga e-GeForce 6200 GeForce 6200, (256 MB)...
Computers & Internet Logo
411 people viewed this question
David Payne
David Payne
