Question about Frigidaire Dishwashers
Top rack wheels on my Frigidaire FDB2410HIS0 come off and door won't latch at times
4 Suggested Answers
  • 1073 Answers
SOURCE: door won't latch
replace the door latch part number 8193830 it will fixya
Posted on Apr 22, 2008
  • 10865 Answers
SOURCE: GE dsd 6700 top rack glider wheels not turning,
remove the tray and look at the wheels to be sure they are completely attached to the tray itself. If they are spray them with PAM or another cooking spray product to lubricate them.
Posted on May 18, 2009
  • 1416 Answers
SOURCE: I have a Frigidaire FBD1250REQ0
hello,
what this simply mean is that there has been a lost or pastier connection on the power distributor from the panel to the control unit .what you are to do to solve this problem is to unscrew the washer from the screws then trace the wires (main power supply) down to the panel then also trace it to the door unit to see if there is any form of loose of wire if so it then need a fix up but if the answer is no then locate the wire down to the door switch unit but it all look to be okey then it then you will have to replace the hole of the control unit of the washer .
please note this if you can not carry out this assignment the you will have to invite a technician to visit the washer in order to avoid more damage on the washing system.
thank you .
Posted on Sep 27, 2010
Latch is not tight when closed
Something must be blocking the door from fully engaging. Pull the loading racks out and put them back after checking they are on track and roll freely. Good luck.
Mar 06, 2014 | Frigidaire Dishwashers
Frigidaire microwave won't start when door is closed. It looks like the door does not latch properly. It worked 20 minutes ago and last night. How do you troubleshoot and/or fix the switches.
Hello Scott Noble - If I was in your position, I personally will recommend consulting a certified technician first for an accurate diagnosis. Depending on what part(s) is damaged from the door, the microwave could possibly have faulty switches, door switches, or latch which only a professional can repair.
Feb 23, 2013 | Frigidaire FMV157GM Microwave Oven
FRIGIDAIRE dishwasher door won't latch
Check to see if the door is not aligned correctly anymore, or if the door sags underneath the latch plate and go from there. You may need to adjust the door or replace the latch itself.
Jul 21, 2012 | Frigidaire Dishwashers
Frigidaire Stackable model #FEX831CSO door won't open
Unplug the machine and where the lid is latched you can push a piece of wire wire in the same hole it latches through. The wire will bottom out after in the hole about a inch. Push it slightly farther and try raising lid as your pushing. All the lock is is a metal tab that pushes up and down. After time the enclosure it's attached to splits and makes it fail but it can be opened with whatever goes farther in that hole then the latch itself.
Jun 16, 2012 | Frigidaire FGX831CS Top Load Stacked...
Hi, we have a Frigidaire FBD1050REM diswasher that the soap door intermittantly won't open, leaving soap all over. Any ideals? Thanks, Christine
I have the same dishwasher and the same problem. What works for me 95% of the time is to push the soap door latch once before I load the soap and close the door. There seams to be two positions on this latch and one opens better. Also, make sure your top rack is pushed all the way to the back before closing the main door.
Personallly, I am looking for a replacement dishwasher!
Dec 22, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
I have to replace the handle / latch assembly on a GE Monogram Dishwasher Model #ZBD6600G03SS. For the love of me I can't see how to do it. Do I have to get at it from inside, outside, both sides...
Hi
If the dishwasher door will not latch on your GE Monogram dishwasher and it is a new appliance, check that the door is not hitting screws or cabinets underneath the counter. For a new dishwasher, you might also need to push in the top of the control panel as you latch the door. The new gaskets might not have had time to seat properly. It may be necessary to run up to 10 dishwasher cycles for the heat from the washer to seat the gasket, which becomes more flexible after it is used a few times. For older Monogram dishwashers, check the loading rack to be sure no dishes are protruding beyond the back or front of the racks and that no dishes have fallen through to the lower rack. If dishes are dangling down into the lower rack, they could stop the lower rack from completely rolling into the dishwasher and could also stop the spray arm from rotating. Check that no silverware is obstructing the door.
http://www.acmehowto.com/howto/appliance/dishwasher/check/doorlatch.php
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Aug 03, 2010 | Dishwashers
The top rack of my frigidaire FFU1724DW5 does not get as cold as the other racks.
prob is poor door sealing of low ref charge .. this would cause the prob . ck door seal first . then the ref charge .. ,, mm
Jul 03, 2010 | Frigidaire FRT15B3A Top Freezer...
My frigidaire dishwasher does not wash on the top
Insufficient water can cause your symptoms
Nov 02, 2017 | Frigidaire Dishwashers
Just installed new dishwasher top rack will not slide in
I had the same problem with my new GE. They installed 2 brand new upper racks.$$ it worked ok for about a month and then I had to force it in again. on the 7th repair call in as many months my repair guy walked in the door stating that he finally knew how to fix the problem. It is caused by poor design in the wheels. they are porous and the detergent breaks them down and they swell. new wheels from an older model fixed the problem. they have RND on the case.
May 30, 2009 | Frigidaire PLD4375RFC Dishwasher
Washing indicators light is flashing and dishwasher won`t start
try to start again while applying closing pressure {push in} at the top of door where latch mechanism is if it starts then it's an adjustment that needs to be done on the door latch
Feb 20, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwashers Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
