Question about Pinnacle Computers & Internet
Pinnacle Studio 12 Movie Making - My movie gets to a certain point and then it says "Export Failure - Rendering error - Help
  • 590 Answers
The reason for your problem may be with the media file which you are trying to convert/render. This may also happen due to improper installation of Pinnacle studio. Try the solution mentioned in the following link http://answers.yahoo.com/question/index?qid=20090702131629AAomBtu
When I analyzed your problem, this problem is a most common one faced by all the pinnacle studio 12 users. one of the user's comment about this is as below:
To start, when the program would be rendering a file, it would show an export error message and lock up. If I rebooted the computer, I could then try to render again only to get the same error message at a different spot in the process. After about 10 hours corresponding with Live Chat support, and following their recommendations, uninstalled and reinstalled the product twice. After this did not correct the problem, they provided a key code to unlock MPEG-4. Now the rendering issue occurs rarely.
Pinnacle have also released a latest patch for pinnacle studio 12 users, which may fix your problem. you can download the patch fix from here
Please read the instructions provided in the download page before installing the patch.
I hope this is helpful for you in resolving the issue
Thanks
Posted on Feb 07, 2010
I am getting the Export failure (render error) 0/3518@00:00:00 just trying to export my movie on pinnacle 14. can you help?
I had this error too. I homed in on the error by putting markers along the timeline (using the M key) and then trying to render between different markers (e.g. between begining and 01 works, but beginning and 02 fails, therefore issue is between 01 and 02). I eventually found the problem was having a stabilise effect combined with a cross fade. Removing the stabilise effect fixed it. It's annoying that the error message (at frame 0) was not where the problem was. Note that copying and pasting the entire timeline didn't work for me. Good luck with this
Mar 06, 2011 | Pinnacle Studio Ultimate 14 for PC
Export:error:real time c:\users\owner\appdata\local\microsfolder\render\my movie 848e009f\alternate\render\my movie 848e009f\dvd\studiosequence\temp' Help - what does this mean? What should I do?
Hi and Welcome,
If you are experiencing Export Errors using Studio, the following FAQ should help:
1. UPDATE TO THE LATEST PATCH:
Click here for the latest Studio 12 patch
There is no patch available at this time for Studio 14
2. ENSURE BACKGROUND RENDERING COMPLETES:
Allow the green bars that appear over clips that have had filters, transitions or other effects added to complete before going to the Make Movie stage.
3. ALWAYS REINCODE ENTIRE MOVIE
If after installing the latest version of Studio, the Export Error persists and you are attempting to create a DVD, then in Studio click on the Setup pull-down menu and select Make Disc. On the top portion of the Make Disc tab make sure there is a check in the box for the setting "Always re-encode entire movie", then click the OK button. Create the DVD again.
4. DELETE AUXILIARY FILES
Delete the auxiliary files before rendering. To do this, go to File >> Delete Auxiliary Files. This will bring up a window to chose which auxiliary files will be deleted. Select the option to delete the files for the current project. Once this is done, try to output the project.
Oct 12, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle stops when computer goes to sleep and stops rendering and making the movie
Just go to your power options in control panel, and set it so the computer doesn't go to sleep. Depending on your operating system just go to Start>Control Panel>Power options and then change system standby and hard disks to never turn off.
Thank you and take care,
Lee
Aug 20, 2010 | Pinnacle Studio Ultimate Collection 14...
I have pinnacle studio 12 plus when i am publishing the movie it gives a export failure rendor error so i took out all the transitions and then only published half. I checked off the background thing...
Hi
In pinnacle studio as the movie is being rendered, the cursor moves along with it, this way you can find out at what point in the rendering process, the program stopped.
when you get the Pinnacle 14 Export Error; Real Time at some frame, then you know that, that frame may be damaged, so cut a few frames before and after where the cursor stopped, and try again.
if the rendering process stops a few times during the compilation, keep cutting those pieces and try again.
i hope that helps
Thanks
Jason
Az Audio Visual Services
Video Conversion Service - Free Shipping North America Wide
http://www.azaudiovisualservices.com
Aug 17, 2010 | Pinnacle Studio Plus 12 for PC
Pinnacle won't accept mpeg videos how do I convert so that it will support it.
I will recommend to use the windows movie maker to convert the video.
Import the video to the m=program that I mentioned. Then export it to avi or mpeg 2 format. Once your done, Import the video to the pinnacle studio program.
Jun 19, 2010 | Pinnacle Studio Ultimate 12 for PC
Pinnacle 14 crashes at the same point when making movie.
Hi
My pinacle 14 crashes when I try to make a disc, if I make a disc from other movies i have edited it works just the current project we are working on , I have deleted the Aux files
Cant move
Peter
Apr 28, 2010 | Pinnacle Studio Ultimate 12 for PC
Make movie keeps timing out, render error
I have also been running into an MPEGENCODER.DLL error about 1/2 way through my 20 minute movie. I am able to Make Movie with a 6 minute version, but hitting this error time and time again. I have removed Virus protection and all unessential system tray loads; defragged drive; downloaded newest Windows drivers; downloaded newest NVIDIA drivers; running Win XP Pro SP3, Intel 3GHZ, 1GB RAM, 76GB/10K spin drive.
Jul 01, 2009 | Pinnacle Studio Plus 12 for PC
Pinnacle 10 dvd burning
have you tried rendering as an AVI file ... then burning???
also, check the drop down tab to make sure in the "make a disc" section that
there are not 2 listings for the dvd choice ... if there are... then select the second
dvd.. and tell it to burn...
or make the AVI and use Nero 8 or 9 to make the DVD.
my version 10.8 is whacked...
upgraded to 12... it's working fine... finally.
bbell
Dec 14, 2008 | Pinnacle Studio Plus 10 Full Version for...
File/Folder Permission Message in Pinnacle Studio 11 Plus
Hello welcome to FIxya!
Here you can check this procedure on how to open your files again.
"1) Check your Recycle Bin
2) Do a Folder/File Search for each of the Grey Folder Project names. This will display all Folders & Files with that Project Name. You are looking for an .stx File. If it's there, right-Click on Project Name / Open Containing Folder & Copy it to your My Projects Folder. Then you should have both the Grey Folder & .stx File for the same Project name, showing in your My Projects Folder.
If the Search doesn't display a .stx File, you can create a new one, by Opening a New empty Project, which will create a My Movie Grey Folder & a My Movie .stx File, Save to your My Projects Folder. Delete the My Movie Grey Folder & Rename the My Movie .stx File to the same name as your original Grey Folder."
So ...after finding my "lost" movie file, with its file name, under Documents\Pinnacle Studio\My Projects i then went through the following procedures using your great advice Colour;
  1. Make a copy of your found "lost" movie grey film icon file by right mouse clicking on your lost file and choosing "copy". Paste the copy into another folder in Documents where you can find it if need be
  2. Then go back to Documents\Pinnacle Studio\My Projects and right mouse click onto your grey film icon. Choose "rename". Then rename your "lost" grey film icon to a new file name but do not put .stc at the end of the file name, if you are operating VISTA and Pinnacle 12. This is important because Pinnacle 12 won't recognise the file later if you have .stc in the file name
  3. Open Pinnacle and go to the File Menu
  4. Click on New Project
  5. Open File Menu again and click on Save File as
  6. Give the file a name such as "Movie 7" and save it
  7. Close out of Pinnacle
  8. Open up Documents\Pinnacle Studio\My Projects and observe that you now have 2 new files there ...a grey film icon file saying Movie 7 AND a coloured Pinnacle icon file saying Movie 7
  9. Delete the grey icon file with the file name Movie 7
  10. Now give your coloured Pinnacle icon file the exact same rename as your precious "lost" renamed grey movie icon file, using the right mouse click on rename proceedure as explained in No.2 above.
  11. Close out of Documents file
  12. Now open up Pinnacle again
  13. Go to Menu and choose Open Project
  14. There you will see the coloured Pinnacle icon file with the new name of your "lost" movie file.
  15. Click onto its coloured Pinnacle icon, and watch your "lost" movie come into view again
Nov 16, 2008 | Pinnacle Studio Plus Version 11
I CANNOT BURN MOVIE TO A DVD
I have had similar messages with Pinnacle 9 (dives you mad :() The solution is to download the latest upgrade version from Pinnacle's website. Pinnacle 11 seems to be bug free.
Jun 30, 2008 | Pinnacle Studio AV/DV version 8...
Computers & Internet Logo
303 people viewed this question
Top Pinnacle Computers & Internet Experts
AL Schehr
AL Schehr
Level 1 Expert
 Ian Kayhan
Ian Kayhan
Pavel Pranovich
Pavel Pranovich
Are you a Pinnacle Computer and Internet Expert? Answer questions, earn points and help others
