Xerox document center 430st
Unit has cycled into hard disk failure.... turned off ... unplugged ..... replugged.....turned back on ....was able to access admin screen also showed 4d23 error code .....now just showing hard disk failure ......please tell me what steps to do to make this pos work again.....I can't get any work done until this thing runs .......
  • bev4u Feb 21, 2008
    this unit started with hard disk failure comment and restart was what xerox said to do online .....if I have the disk would I be able to reinstall
    Genius:
  • 3,422 Answers
Please first try reseting it.This usually fixes the error code problem.
For that you have to refer some user guide.You can download it from HERE
If you want to try reinstalling the driver then go ahead.But first uninstall the previous driver then reinstall it.You can download the driver from HERE
Once you are at the site just click on Accept then the download will start..
Goodluck..
Posted on Feb 21, 2008
    Master:
  • 788 Answers
The hard drive needs to be replaced, have the unit serviced.
You could try reseating it's cables, remove the panels at the rear of the machine and you should see the hard drive mounted inside. Reseat the cables and cross your fingers. But most likely needs replacing. You can't just use any hard drive either since it needs to be properly formatted, that's why they can be expensive. You may find one on eBay, that may work. Good Luck!
    Scholar:
  • 110 Answers
Hi bev4u!
To get to the bottom of this issue we will need some more information about the error codes displayed by your system. 4d23 isn't helping much because it doesn't appear to turn up as a valid fault code for this model. If you can work back into the admin panel and report any other codes in the log, it would be great.
Additionally, is your machine owned or leased?
Lastly, please excuse the rude attitude and irrelevant posts by our other experts.
    Scholar:
  • 99 Answers
So....bev4u, is your problem solved?  If not, let me know what the status of your problem with teh xerox isso I can try to find a solution
  • 19,396 Answers
I will try to find a solution
  • 5 more comments
  • Ginko
    Ginko Feb 21, 2008
    First try doing an hard reset. Disconnecting the xerox from power socket for 30 minutes and connecting it back.
  • Ginko
    Ginko Feb 21, 2008
    Failure to leave at least 20 seconds between
    repeated power OFF /ON can result in damage to the
    DC440/432/420 hard drive. Probably this is what happened. The HD probably is not physically broken but the source software may need to be re installed by a xerox authorized centre.
  • Ginko
    Ginko Feb 21, 2008
    here is the link to all documentation regarding your unit made available online by xerox
    and Here is the contact number for USA and Canada. If you let me know your location I will find your Xerox service contact number.
  • Ginko
    Ginko Feb 21, 2008
    You can also trace the number from www.xerox.com selectin your region after clicking contact us
  • Ginko
    Ginko Feb 21, 2008
    The original code 4d23 was not HD failure. Was probably some code related to paper feeding (the ones staring with 4 in your model). You probably had HD failure after restaring the machine several times.
    Let me know if this had been helpful or if you need further help.
  • Ginko
    Ginko Feb 21, 2008
    WHICH DISK ??????!!!!!!
    You cannot install xerox pre installed software with a disk.
    Thanks for negative reting while troubleshooting!!!!!!!!!!!\
  • Ginko
    Ginko Feb 21, 2008
    In any case it seems you have the solution already.
    Goodbye
My Whirlpool Duet Front Load Washing Machine is showing a F28 error. What does that mean?
F28 is a communication error which usually means there is a connection that has come loose. Removing the top and unpplugging and replugging the connectors in will fix 75% of these codes. If the bottom toe panel is not on it will also give you an F28
  • Unplug or turn the circuit breaker off for 30 seconds.
  • Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
  • Press the Pause/Cancel/Stop button twice to clear the display.
  • Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation when our chat has concluded Thanks again Rick
  • Jan 16, 2011 | Whirlpool Duet GHW9150P Front Load Washer
    I need a list of erro codes and definations for xerox workcentre 7232 serie. and I want the solution to my xerox workcentre 7232 copier. when switched on it shows erro 093-311
    When a fault occurs, the touch screen displays a message on how to clear the fault. Some faults indicate customer maintenance, while others require the attention of the Key Operator and/or System Administrator. The following table represents some of the fault codes and their corresponding corrective actions. These may appear in the Print Queue or Faults List available in the Machine Status mode.
    002-770 The job template could not be processed due to insufficient hard disk space. Delete unnecessary data from the hard disk.
    003-750 No document was saved for the double-sided Booklet Creation feature. Check the setting of the double-sided Booklet Creation feature.
    003-751 The specified document area is too small. Select a higher resolution or a larger scan area.
    003-754
    003-755 An error occurred in the document scanner. Reset the document, and scan again.
    003-756 The fax document is completely white. Check that the original is not white, or that the front and back sides have been reversed.
    003-760 Incompatible features are selected in the document scan conditions. Check the selected options.
    003-761 The paper size in the tray selected by auto tray switching, differs from the paper size in the tray selected at the tray selection. Either change the paper size for the tray, or change the paper type priority setting.
    003-763 An error occurred when reading the Gradation Adjustment Chart. Place the chart properly on the document glass.
    003-780 Compression of scanned data was unsuccessful. Lower the resolution or reduction/enlargement ratio to reduce the data size, or send the document in
    smaller segments.
    003-795 The reduction/enlargement ratio exceeds the setting range when the scanned document is enlarged/reduced to the specified paper size. Directly enter the reduction/enlargement ratio, or change the paper size.
    003-981 Stapling mixed size documents is available only for documents with the same width. Cancel the staple feature or reset the documents with the same width.
    005-210
    005-275
    005-280
    005-283
    005-284
    005-285
    005-286 An error occurred in the document feeder. Contact the Xerox Welcome Center.
    Jan 16, 2011 | Xerox Office Equipment & Supplies
    1 red light on xbox 369
    hi, here follows a possible solution from Microsoft support:
    One light on the ring of light around the power button on your Xbox 360 console flashes red.
    You might also see the following error message on your television screen or monitor: System Error. Contact Xbox Customer Support. This message is followed by an error code in the format of "Exx," where xx is a two-digit number.
    Note If you see error code "E74" on your screen, click the following article number to view the article in the Microsoft Knowledge Base: 941377 E74 error appears when you use your Xbox 360 console Back to the top
    CAUSE A single flashing light might indicate a hardware failure on your Xbox 360 console. Back to the top
    THINGS TO TRY Step 1: Disconnect and reconnect all cables a. Turn off your Xbox 360 console. b. Unplug all memory units, controllers, and accessories from your console. c. Unplug everything from the back of your console, including power and video cables. d. Unplug your power supply from the wall, and then unplug the short cord from the power brick. e. Plug everything back in. Make sure that you make all connections firmly.
    f. Turn on your console. If the problem still occurs, go to step 2. Back to the top
    Step 2: Remove the hard drive To see whether the problem involves the Xbox 360 Hard Drive, temporarily remove the hard disk unit. If your Xbox 360 console does not have a hard disk, go to step 3. To remove the Xbox 360 Hard Drive, follow these steps: a. Turn off the console. b. Locate the hard disk on your console.
    c. Press the release button on the hard disk, and then lift the hard disk from the console.
    d. Turn on your console. If these steps resolve the issue, reattach the hard disk to verify that the error occurs only when your Xbox 360 Hard Drive is connected. If this is true, contact Xbox customer support to order a replacement hard disk. To contact Xbox customer support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 3. Back to the top
    Step 3: Disconnect any memory units a. Turn off your Xbox 360console. b. Unplug any memory units attached to your console. c. Turn on the console. If these steps resolve the issue, reattach the memory units to verify that the error occurs only when a memory unit is connected. If this is true, contact Xbox Customer Support to order a replacement memory unit. To contact Xbox Customer Support, visit the following Web site: http://www.xbox.com/support/contact If this does not resolve your issue, go to step 4. Back to the top
    Step 4: Request a repair If the previous steps do not resolve your single flashing light issue, there are no additional troubleshooting steps and your Xbox 360 console must be repaired at our service center. https://myservice.xbox.com/it-it/Pages/welcome.aspx
    Jul 31, 2010 | Microsoft Xbox 360 Console
    Bell pvr 9242 hard drive failure
    YOU NEED TO TAKE IT OUT AND PUT IT IN AGAIN BUT MAKE SURE ITS IN RIGHT
    Dec 30, 2009 | Televison & Video
    System error 39,012.40:49875
    If after cycling the power to the machine and this problem still exists you may need to replace the ADF assembly. Here's a video that shows you how
    Jun 26, 2009 | Xerox WorkCentre C2424DN All-In-One Laser...
    Document center 470 ST says network controller unavailable.
    Most likely the network hard drive has failed. The hard drive us located inside the network controller box .
    Feb 10, 2009 | Xerox Document Centre 265ST Printer
    Xerox phaser 6250 NVRAM Failure
    Cycle power, try cleaning the CTD (ADC) sensor and toner full sensor. This is what Xerox has to say about the NVRAM failure: On the front panel, press the key labeled i to view information about the error. Record the error code number. Turn off the printer. Reseat the fuser. Reseat the imaging unit. Reseat the toner cartridges. Turn on the printer. If the error continues to be displayed contact service. To be on the safe side you can follow the instructions here on the procedure to replace the transfer roler: http://office.support.xerox.com/SRVS/cgi-bin/webcgi.cgi Good luck
    Mar 25, 2006 | Xerox Phaser 6250DP Laser Printer
    737 people viewed this question
    jasbo
    jasbo
