Question about Hotpoint Refrigerators
Freezer on my hotpoint refrigde is freezing up while the other side is warming up,have already replaced the defost timer 4 weeks ago.
    President:
  • 1,218 Answers
Good day,
New parts can fail, but to test your timer, turn the shaft on the timer clockwise until the machine shuts off. Leave it like that. The timer can be many different time cycles, so just wait up thru 45 minutes.
It should turn the machine back on. If so, the timer is O.K.
There are 2 other parts to the defrost system. The main heater/heaters, and the defrost limit thermostat.
If one heater system, it will be mounted on the bottom of the evaporator coil, behind the rear panel in the freezer section.
If it's a two heater model, there will be one heater on the bottom, and the second half way up.
You will need an ohm meter to test them. They should not exceed 35 ohms. If they read infinity (no resistance) then replace.
The last part is a defrost thermostat. It is a round about an inch in diameter mounted on the top of the coil.
It should read zero ohms resistance, but can only be tested if the machine has been running and the thermostat no warmer than 20 degrees.
If the heater/heaters are bad, replace them but also replace the limit thermostat as a package.
If the limit thermostat is the only bad part, replace it only.
Thank you for using FixYa
Posted on Feb 06, 2010
I have a Hotpoint side by side refrigerator model number hsm25gfra sa and the fridge keeps getting warm. after about a week or so I have to unplug it and let it sit for a day or two, than I plug it back in...
The coils in the freezer are probably freezing up. Do you have ice buildup in the back of the freezer? I would replace the "defrost limiter thermostat". Here is a link to the part you need.
Here is a video to show you how to replace it. This is a different model but the process is the same.
Oct 17, 2012 | Hotpoint HSS25GFP Side by Side...
I have a HTS 18 GBMCRCC ,the freezer constantly freezes up no matter what setting its on the fridge then gets warm and we have to take the freezer panels off and defrost its supposed to be frost free? we...
Could be one of three things going on, first the defrost heater is burned out, it can be checked by ohm meter, the thermostat needs replaced check with ohm meter while still cold(open),or the defrost advance needs replaced.
Oct 03, 2010 | Hotpoint Refrigerators
Freezer side stops defrosting.
has the defrost timer been replaced? if not, that'd be the next step. there are only a few parts in that line: the power, the sensor, the timer, and the heating element. also, if the condesate drain is plugged, water stays pooled under the coils and freezes again.
Aug 27, 2009 | Refrigerators
The freezer freezes up
replace the defrost timer if you haven't allready and make sure the drain line is cleared.
Jan 15, 2009 | Refrigerators
HOTPOINT/GE REFRIGERATOR NOT DEFROSTING
I have the same problem. A lot of people in forums are telling me it could be the defrost heater. Anyone know how to test it?
Jul 28, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Frig side by side problem
yes it could. you again have a defrosting problem. do you noticed frost at the back side of the freezer section? the repairman could have replaced your heating element and your defost timer.
Dec 28, 2007 | GE GSH25JFR Side by Side Refrigerator
Hotpoint 25.3 cu. ft. not cooling
When the freon as been recharged, did the dryer been replaced?
Nov 25, 2007 | Hotpoint 6.67 cu. ft. / 189 liter Chest...
Refrigerators Logo
57 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
