Question about Garden
I have poulan 2150. it will not start.get gas and spark.
  • 677 Answers
Has it been sitting around for a while not being used ?
If so I would dump the fuel out into an appropriate container and fill saw up with a fresh mix of fuel. I also ALWAYS put in about a cap full of SEA FOAM.
Make sure spark is nice bright blue, if not install a new plug.
Now pull on the choke, pull it once or twice, and shut off the choke.
Now does it start ?
If that does not start, I would pull the spark plug, drip a little fuel mix in, put plug back in torqued to mfg. specs. and see if it fires now ?
Please let me know what happens.
Posted on Feb 06, 2010
Poulan 2150 fuel line diagram
you can start by adjusting the air fuel intake by turning the adjustment screws in all the way then out 3 full turns then do half turn adjustments until its right
Jul 23, 2014 | Poulan 2150 Chainsaws
What is theair gap setting poulan 2150 2.1c i
.025" or .6MM is the spark plug gap I assume air gap is what you were referring to is spark plug?
May 16, 2014 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Poulan woodsman 2150 starts & runs for a few
This is fuel starvation, start by replacing the fuel filter inside the fuel tank, use a piece of bent wire to hook the fuel line and filter out of the tank, check the condition of the fuel hoses up to the carb, any signs of leakage and you will have to change the hose. See if this works before we go into the carb to locate the blockage.
Jun 09, 2013 | Garden
Poulan 2150 saw will not start.
Many saws today have a alluminium key moulded into the flywheel, if the key has sheared the timing will be out and it will never start, remove the flywheel and check the key.
Jun 05, 2012 | Poulan Garden
How do you re assembly brake handle poulan 2150
Hello Larsens;
A Poulan "2150 Predator Gas Type 6" IPL follows (may not be your saw)(the LE suffix is a Wood Shark) http://www.ordertree.com/modelinfo/PWE/2150-Predator-Gas-Saw-Type-6/75.2150-Predator-Gas-Saw-Type-6.1.59.1.html
There is no breakdown, they want you to order a new cover $20±. The cover appears on different print names with different models (Handle & External Assembly) above.
Poulan.com (all)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Do you have a friend with a cover you can look at? The brake will need to be lached open (enlarged) to refit the clutch cover on your saw.
Detail A here is a good representation of a Husky chain brake, they are all similar and this may be helpful.
http://weborder.husqvarna.com/order_static/doc/usa/2006/I06000/I0601077.pdf
If you have more questions or need additional help please reply below and I will get back to you. Good Luck. HTH
Lou
Thank You for using FixYa.
Apr 24, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Need a diagram of the fuel lines on a poulan 2150. what lines go where?
You can View a Diagram of the Chainsaw here http://hayward.arinet.com/scripts/EmpartISAPI.dll?MF&app=ASP⟨=EN&TF=Mainfram...
Select the Catalog Poulan/Weed Eater. Then Select Poulan. Then Select Gas. Then Select Saw. Then Scroll Down to your Model Saw i.e 2150.
Regards
Marc
Apr 17, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan 2150 will not start
take the muffler off and look inside.there is probbaly score marks on the piston.if there are the unit will need a piston and cylinder.starting fluid does nothing but burn pistons up,it drys the cylinder out so it has no lubercation
Feb 21, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
98 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
