Question about Compaq Evo N610C Notebook
How do i turn off the touchpad touch to click option?
    Scholar:
  • 62 Answers
Check your touchpad software, it should have an option for disabling the tap-click. generally this kind of software has an icon located at the system tray. right-click it and look for the setting or options. if you want to disable completly the touchpad hold the function key (Fn) and tap the key that has a drawing that resembles a touchpad. you computer should confirm that.
Posted on Feb 06, 2010
2 Suggested Answers
  • 53 Answers
SOURCE: toshiba touchpad double click problems
sounds like it's in settings, use ctrl + alt delete sequence, task manager, start new task, browse, go into control panel, select keyboard, and check settings there, and configuration....hope it helps you....good luck....shia
Posted on May 03, 2009
How do i disable touch pad when mouse is in use
      Click the "Start" button and click "Control Panel." Click "Hardware and Sound" and click the "Mouse" link under Devices and Printers to open the Mouse Properties box. Click the "Touchpad" or "Buttons" tab depending on your PC, then select the "Disable" option next to thetouchpad installed on your computer.
      How to Disable TouchPad While the USB Mouse Is Plugged in
      smallbusiness.chron.com/disable-touchpad-usb-mouse-plugged-52685.html
    Feedback
    How To Turn Off Touchpad When Mouse Is Connected In ...
    www.intowindows.com > Windows 10
    Dec 14, 2015 - How To Turn Off Touchpad When Mouse Is Connected In Windows 10/7/ ... who always use a mouse and don't want to use the built-in trackpad ...
    How to Disable Your Laptop Touchpad ' PCWorld
Jan 31, 2016 | Toshiba Satellite C655D-S5120 Notebook
The touch mouse will scroll and move but won't click.
you might have to reset it
Most modern laptops with touchpads offer vertical scrolling, horizontal scrolling or both. These features are located along the right-hand and bottom edges of the touchpad, respectively, and are activated when you swipe your finger along the touchpad edge. Scrolling functionality is nearly always enabled by default, but some users find the feature an annoyance and elect to turn it off. In most cases you can simply turn the feature back on using the Windows Control Panel.
Click the Windows Start button, select "Settings," and then click "Control Panel." Double-click the icon labeled "Mouse." Select the Touchpad properties tab. The labeling of this tab varies, depending on your computer manufacturer, operating system version and the device drivers installed on your machine. Common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see this option, you may not be able to turn on scrolling for your laptop; skip the remaining steps and refer to the "Warnings" section below. Click the "Settings" button within the Touchpad Properties menu and look for the section labeled "Scrolling Settings" or similar. Enable scrolling within this section and define other scroll settings, such as scroll zone width and scrolling speed. Click "OK" to confirm your changes, and then close the Control Panel windows opened in the previous steps. The scrollbar on your laptop is now enabled.
Scroll Is Not Working With Windows 7 b> Certain computer touchpads have a vertical section on the pad itself that is used to scroll through the page or program window that you are currently viewing on your computer. If the scroll functionality suddenly stops working but the actual touchpad is still fine, this means that the part of the software for the device that controls the ability to use the scroll has been disabled. You can enable it again in the Control Panel.
Click "Start." Click "Control Panel." Click "Mouse." Select the "Enable Scroll" option (or whatever similarly named option is available on your specific model of laptop computer). Click "Apply." The scroll bar on your touchpad will now work again.
b>
Feb 15, 2013 | HEWLETT-PACKARD Hewlett Packard HP 6730b...
Touch screen not working
The touchpad on the Acer Aspire is built into the notebook itself, which makes the device much harder to troubleshoot or replace. While you can connect a universal serial bus mouse to the notebook if the touchpad becomes unresponsive, attaching any external device reduces the notebook's portability. Although hardware failure can cause the touchpad to stop working, most device-related problems are due to software settings or other conflicts.
Hardware Conflict
Peripheral devices connected to the Aspire can interfere with the integrated touchpad. Disconnect all of the external devices, except for the power adapter, that are connected to the Aspire; then restart the computer. Test the touchpad after booting into Windows. If the touchpad responds, a hardware device is interfering with the pointing device. Reconnect each device one by one to the notebook, testing the touchpad throughout. If the pointing device stops responding after connecting a particular device, the component is interfering with the touchpad. Go to the device manufacturer's website and look up the product model. Check the bulletin board to see if the manufacturer has posted a notice or update addressing issues with device conflicts. If no such update is available, download the latest driver for the component and install it on the computer. b> Disabled Touchpad b> The Acer Aspire 5516 comes with a preset group of keyboard combinations, called hotkeys, that are used to enable or disable devices, configure sound volume and screen brightness, and control the notebook mode. The hotkeys "Fn" and "F7" turn the touchpad on and off. If the integrated mouse is unresponsive, hold down "Fn" and press "F7"; then test the touchpad to see if the device reactivates. If the touchpad still doesn't work, open Device Manager from within the Control Panel. Expand "Mice and Other Pointing Devices," then right-click the touchpad device. If the touchpad is disabled in Device Manager, you'll see the "Enable" option in the context menu. Click it to turn the touchpad back on; then restart the computer. Corrupt Driver b> Windows Vista talks to the touchpad through a program called a device driver. The driver enables Windows Vista to "see" the touchpad and send it instructions. Once the driver communicates these instructions to the touchpad, the touchpad informs the processor that it needs to perform a task, and a specific set of code is performed. If the driver for the touchpad is outdated or corrupt, or if the driver isn't compatible with the OS -- Acer offers touchpad drivers for Windows XP and Windows 7, but these drivers won't work with Windows Vista -- the touchpad becomes unresponsive. Expand the "Mouse and Other Pointing Devices" section from within Device Manager; if Windows detects a problem with the driver, it places a yellow exclamation point or red "X" next to the device. Double-click the touchpad driver to see the error message; then look up the message on the Microsoft Support website for further assistance. b> Touchpad Settings b> Mouse Properties, accessed through the Control Panel, contains several different configuration settings that can alter how the touchpad behaves on the Aspire 5516. On the "Device Settings" tab is the option "Disable Internal Pointing Device When External USB Pointing Device Is Attached." As the option states, if an external mouse is connected to the Aspire 5516, the touchpad will stop working; disable this option if you're using an external pointing device. Clicking the "Settings" button opens the "Properties for Synaptics Touchpad" window. On this screen are the "PalmCheck" and "Touch Sensitivity" options. If PalmCheck is set too high, or Touch Sensitivity too low, the touchpad won't respond to normal touch, making the device seem unresponsive. Hope this helps.
b>
Dec 31, 2012 | Acer Aspire Z3801 All-In-One Desktop Pc...
My touch pad on the Acer Aspire 5532 laptop doesn't work. how can i fix it?
Click "Start." Click "Control Panel" in the right panel.
Click "Accessibility Options."
Clear the boxes next to "Use Sticky Keys," "Use FilterKeys" and "Use ToggleKeys."
Click "OK" to unlock the keyboard, including the keypad.
Unlock Touchpad
Click "Start," then "Control Panel."
Click "hardware and Sound," then "Mouse."
Click the "Touchpad" tab. Click "Default" under the "Touchpad" tab to reset the touchpad to its original settings.
hope this helps
Aug 17, 2012 | Synaptics PS/2 Port TouchPad
How do i adjust the sensitivity of my touch pad for my Toshiba laptop PSLB8U-05202F
1.Turn on the computer and log into Windows as normal. Open the "Start" menu and click on the option labeled "Control Panel."
2.Double-click on the icon labeled "Mouse.". The "Mouse Properties" window will open. Navigate to the tab labeled "Device Settings." Click on the button labeled "Settings." A window labeled "Properties" will appear.
3.Examine the left panel of the "Properties" window and expand the option labeled "Sensitivity." Click on the option labeled "Touch Sensitivity."
4.Reduce the touch sensitivity setting by moving the slider to the right, towards the "Heavy Touch" label. Experiment with different levels of sensitivity until you find one suited to your needs.
5.Click on the button labeled "OK" to close the "Properties" window; repeat with the "Mouse" control panel. Your new touchpad sensitivity settings are now saved.
Sep 14, 2011 | Toshiba Satellite L305-S5908 Notebook
How can deactivate the pad?i dont want to click with a double touch...thanks
To turn the TouchPad on/off, quickly double-tap the TouchPad off indicator (the yellow LED) at the left top corner. If the touchpad is disabled it is indicated by a yellow LED on upper left corner of the touchpad and when the TouchPad is active, the light is off.
This would disable the touchpad completely. Also, if you wish to disable just the double-click through double-tap, you can do this by going to the mouse/touchpad options from the control panel.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 17, 2011 | HEWLETT-PACKARD Probook 4530S
How do different touch modes operate?
Hi Richard,
I assume you mean the gesturing options for the touchpad. If so, you need to go to device manager (in xp - right-click my computer-leftclick properties-click hardware tab at the top then device manager - in win7 - right-click computer in start menu, then click properties - then device manager.
Find the touchpad in the list of hardware (probably synaptics), then right click on it and left-click properties. From here you should be able to see the different touch options for the touchpad.
Please let me know if this helps.
Regards,
Joe
Jan 01, 2011 | Acer Aspire One Netbook 8.9" Notebook
I can not disable touchpad of INSPIRON 1545 of DELL Computers There is no option for disabling touch pad in the MOUSE option of Control Panel
Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
In the new window that appears, click 'Device Select'
Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
Good luck ! if your problem is solved don't forget to rate
Dec 30, 2010 | Computers & Internet
Touch pad possessed.
To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
Alternatively, you can permanently disable the touchpad of your laptop by clicking the "Disable Device" in the Touch Pad setting. Advanced users can disable the touchpad from the BIOS setup [press F2 when the computer is booting to enter BIOS settings]
For extra USB ports, purchase a USB hub($15 -$20). That way you can add at least 4 USB ports to your laptop.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 19, 2008 | Toshiba Satellite A135-S4527 Notebook
I have lost the ability to scroll using the right vertical edge of the touch pad. Otherwise the pad works fine but it is annoying not being able to scroll any more without moving the cursor to the 'scroll...
The option to enable or disable the scrolling option for the notebook touchpad is generally available by going to the Control Panel, then selecting Mouse. Within that area, go to Device Settings, select the touchpad from the list of available devices, then click Settings. There should be an option for "virtual scrolling" - click on it, and you should be given the options to turn on or off both horizontal and vertical scrolling for the touchpad control.
May 06, 2008 | Computers & Internet
Compaq Evo N610C Notebook Logo
346 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
