Question about Canon PIXMA™ iP4300 InkJet Photo Printer
Printer ip4300 not installing correctly
I have downloaded driver from canon website to vista. tells me that it has successfully installed. appears in printer list as default printer. when asking to print, then tells me that has not installed.!!!!!! vry frustrating have uninstalled and tried again several times always same problem. have ruled out usb and printer faults. printer works fine on windows me, (intalled from disk) please help. Have even bought another printer ip1800 from canon and get same problem.
  • edeldotto Feb 09, 2009
    any solutions yet?
    Scholar:
  • 41 Answers
Some folks have had good luck resolving issues like you have by deleting the INFCACHE.1 file, which can get corrupted with bad data and cause issues.
The file is located at C:\Windows\inf. There, scroll down to the INFCACHE.1 file and right click it and select delete.
To do this, you will likely have to give yourself permission to delete it, because of Windows built-in security.
Just right click the file, select Properties and then click on the security tab.
Let us know whether this procedure does anything. Sometimes it does and sometimes not.
MaggieB
Posted on Feb 21, 2008
Error code 311
The Error 311 indicates a communication error between the Mac and the printer. If you upgraded the Mac from Leopard to Snow Leopard, there could be older driver files for the iP4300 that are conflicting with the new driver. Therefore I would start your repair by trashing all of the Canon files.
The first step is to disconnect the USB cable between the printer and the Mac.
The next step is to delete the current printer queue for the iP4300. Open Print & Fax, select the iP4300 in the list and click the minus ( - ) button to remove the queue. You can now exit Print & Fax.
The third step is to remove the Canon files. These are located in HD > Library > Printer > Canon > BJPrinter. Select all the files inside this folder and trash them. Then empty the Trash and restart the Mac.
With the Mac restarted, you can now run the installer for the 10.6 driver you downloaded from the Canon web site. Ensure this driver is version 10.26.0.0.
Once the driver has been installed you can connect the iP4300 USB cable to the Mac again and open Print & Fax. If the install has worked, the printer should automatically appear in the Printers list (note that this can take several seconds). If the printer does not appear, click + to add and select the Default view. The iP4300 should appear in this view. Select it and click Add. You may get a prompt stating the printer is already installed. If so, cancel this install and try printing with the new iP4300 queue.
If the error message still occurs, then I would try another USB cable. They have been known to cause the 311 error.
Nov 09, 2015 | Office Equipment & Supplies
New ASUS PRO50Z laptop with Vista , trying to install new drivers for Canon PIXMA ip4500 printer. Have installed new drivers from Canon website, plugged in printer to USB port and turned on printer....
have you downloaded the right software? for vista. also try to print something from your notepad or wordpad or a website page see if it will print.
Aug 15, 2008 | Computers & Internet
Attempting to install Canon Pixma MP160 on Mac OS X 10.5.8. I have downloaded the driver from Canon's website, and it says it has installed successfully; however, when I go to System...
Im pretty sure you should add the printer before downloading the driver. Try uninstalling driver, install printer, the install driver. If it came with software it's better to use it.
Dec 29, 2017 | Canon PIXMA MP160 All-In-One InkJet...
I have lost the installation disc for my Canon IP4300 printer. Is there anything i can download that will do the same job, or do I have to try and get hold of a replacement disc? Any advice would be much...
You can download the installation driver and software from manufacturer's support website by clicking this link
On the page which opens, select the operating system of your computer (Windows Xp/ Vista..) from the drop-down menu. Then download the required drivers and software.
The list of available drivers will load only after selecting the operating system of the computer.
Hope this solves your problem. Thanks for using FixYa.
Aug 08, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
I need to install/update my Canon Pixma iP1700 driver but everytime I run the supposed correct driver/update it constantly fails. This printer worked perfectly on my old printer with Windows XP but I...
Did you do a upgrade to vista from xp? Or is the computer with vista a different computer? The reason why I ask is if you did an upgrade the old drivers and software for xp may still be in the system. The first thing I would do is go into the device manager and remove the printer and un-install any software for the printer. Re-boot the computer and windows vista should detect the new hardware. I would let vista check online for the driver and install it. If it cant't find one the choose the driver you downloaded online. After that then try installing the printer software. Also make sure that when you go to print something that your printer is set up as the default printer.
Sep 06, 2009 | Office Equipment & Supplies
Own a pixma ip4300 everything is in arabic need to transform it to english.
Hi there
Not sure what you what you not gave much info.
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Canon-iP1300-iP3300-iP4300-iP5300-iP6700D-iP90-MP160-MP180-MP460-MP510-MP600-MP960-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website are only there for a limited time.
May 09, 2010 | Canon PIXMA iP4300 InkJet Photo Printer
Ip4300 is printing everything orange!
It sounds like a driver problem, maybe caused by installing some new software that interferes with your printer settings.
Try downloading the latest drivers and software from the Canon website.
Before you install them, un-install all of your printer software then shut down your computer, even if the un-install program doesn't tell you to.
Switch off your printer, then unplug the usb cable from the printer (not the pc).
When the computer restarts, install the new software and drivers exactly the same way as in the original instructions that came with the printer.
Only turn the printer on and plug the usb cable in when the instructions tell you to.
If this doesn't work, the printer may be faulty. If you contact the dealer you bought it from, they may have a warranty running with Canon that lasts more than the guarantee period. It's worth a try, though you may have to pay for a courier to pick up and bring back your printer.
Nov 15, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
How to install printer to new laptop
You can find the drivers from this website:
http://www.digipro.co.uk/canon-products/printers/colour-printers/canon-ip4300/drivers.html (Click the Windows logo to start download)
Instructions are also there to help you install them.
The manuals you can request from canon (http://www.canon.co.uk/Support/User_Manuals/index.asp) but it looks like you need to pay for them.
Although I did manage to find the Quick Start Guide here: http://www.leoscamera.com/Digital/canon/ip4300_qsg_us_v1.pdf
Hope that helps.
Nov 11, 2008 | Office Equipment & Supplies
Installing Canon PIXMA iP5000
make sure you have the correct driver for your printer. go to the manufactures's website and search the rghtdriver. You must uninstall he previous driver before you reinstall the new driver.
After you hve install the driver to Start menu/printer and fax/add printer
Mar 01, 2008 | Canon PIXMA iP4300 InkJet Photo Printer
How do I connect my printer to my laptop if I haven't got the installation cd?
Go to the canon web site, look for the Support tad and go at it from there you will eventually find the place to download the drivers from.
Like HERE
Here is an example for a USA customer with a Windows based PC and an IP4300
Oct 14, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA™ iP4300 InkJet Photo Printer Logo
71 people viewed this question
old marine
old marine
