Question about FixYa Computers & Internet
2001 dodge caravan transmission problem. It's almost as if it's a bad or loose connection or moisture. The following problems are intermittant. speedometer and rpm gauge go out of control. Transmission selector led shows all ranges lit by the squares, e.g. park neutral drive ranges and reverse. Transmission wont shift through gear ranges. Its as if the computer misses abeat. electrical cutout. Is there somekind of sensor or module that might be going???? Help please
I have the same problem and it was fixed by replacing both speed sensors on the tranny, but it's now back again after 2 weeks. Let me know if you got yours fixed.
Posted on Mar 26, 2010
Dash indicators intermittent
Hi there
Either loose connection under dash or bad connection on earth on battery or chassis or loose term on alt/ engine /chassis etc
Feb 12, 2015 | 2000 Dodge Caravan
Transmission problem on my 2001 dodge caravan
Not good if it makes a grinding noise. Needs a tech or replacement as something most likely has come loose inside the transmission.
Sep 01, 2012 | 2001 Dodge Caravan
2002 dodge caravan - transmission slips out of gear, then back in, scan code P0884
trans control module signal intermittent loose connection or frayed wire
Mar 03, 2010 | 2002 Dodge Caravan
2001 dodge sport caravan do not come out of 2nd gear, fluids are good. What can be the problem?
transmission speed sensor is bad. Dealer charged me 186 bucks to replace.
Aug 27, 2009 | 2001 Dodge Caravan
Our 2001 Dodge Caravan seems to be leaking oil around drive shaft
Yes it's a bad seal and most likely the side bearing to the trans axle is bad too. Once the bearing has play, it vibrates and causes the oil to leak though the seal. Note: if one side went bad the other side is soon to follow since they have the same amount of miles on them. Might as well change both side. Good luck and hope this helps. Keep an eye on the transmission fluid level, don't want to burn out the transmission.
Jun 04, 2009 | 2001 Dodge Grand Caravan
2004 dodge caravan
It seems like bad,dirty or loose wire harness connection somewhere in electrical circuit. This is very difficult to find if engine has problem intermittently. One method may resolve is to unplug wire contacts one by one inspect clean and re-plug. Inspect also all fuses if any loose seated, nad fuse case connections and support.
Aug 22, 2008 | 2004 Dodge Caravan
Computers & Internet Logo
276 people viewed this question
Top FixYa Computers & Internet Experts
Mark Magill
Mark Magill
Are you a FixYa Computer and Internet Expert? Answer questions, earn points and help others
