Question about Weiser Lock POWERBOLT ELEC DEADBOLT
I programed the lock. It beeped in recognition of the code, but the lock doesn't turn. The batteries are okay. How do I get the door to lock/unlock using the keyless pad?
    President:
  • 2,030 Answers
If the batteries are new and good, sounds like a problem with the lock motor..is it a new unit? if so exchange it. try another set of batteries.
Posted on Feb 06, 2010
Need a video how to program my keyless entry deadbolt lock
Which manufacturer made the keyless deadbolt lock? Make sure that the batteries are good in the unit.
I have an older Weiser Powerbolt deadbolt lock that is programmed by taking off the cover on the inside of the door. This model has handheld remotes and the keypad. Inside there are three yellow buttons. Two match the cover's lock and unlock buttons. Press and hold the third button (in the center of the set of buttons). Then enter program in the code within a few seconds and press the enter button to set the code. If the unit beeps again, the code is set. If the unit doesn't beep, retry from the press and hold the Program button step.
Another model of the Weiser Powerbolt lock has the Program button either on the top left or lower right hand side of the board (depending on the way the door opens) under the cover. Press the Program button once and then enter the 4-8 digit code. Press the Lock button to set the code. If you hear a long beep, the code was accepted; otherwise try to program your code again.
Kwikset Powerbolt locks are programmed the same way as the second Weiser Powerbolt described above.
Kwikset SmartCode locks have their Program button in the center of the bottom of the control board. Otherwise the programming is the same as that given above for the second version of Weiser Powerbolt locks.
MiLocks have three buttons in a horizontal line. The left-most button is the Set button. Press this then enter the code followed by the Unlock button. The code must be entered within 5 seconds of pressing set.
Baldwin Hardware's Boulder series of keyless entry deadbolts are programmed just like the Kwikset SmartCode units.
I don't know of any videos. Most manufacturers do have PDF files with the programming instructions.
I hope this helps. Please add more information about your deadbolt for extra assistance.
(I end up replacing the batteries often on the lock I have; it seems like they last 6 months or less.)
Oct 20, 2013 | Deadbolt ELECTRONIC DEADBOLT KEYLESS ENTRY...
I have a larson storm door with an electronic lock its an intevia model 6101LM it is locked and I cant get it to unlock with the code outside, interior push button, or the manual overide. It just beeps...
I have reviewed the programming & installation instructions and nowhere is your particular situation described. For your convenience, here is the link to online instructions:
http://www.larsondoors.com/files/etouch-user-guide.pdf
Notice that the above is a .pdf filetype. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Note what the instructions have to say about the batteries:
"4 AAA Energizer Lithium batteries are required to
maximize battery life and performance at temperature
extremes. AAA alkaline batteries
are not recommended and should not be used."
So, I recommend contacting Larson Door Customer Service and allow them to help you with this problem.
Homeowner Helpline:
1-800-352-3360
Monday - Friday
7:30am - 4:30pm CST
Good luck--and please provide feedback if this helps!
Sep 04, 2011 | Locks & Locksmithing
The lock is sounding off like an alarm when we close the door to leave. What does this mean?
I downloaded the PDF file for this lock to find out about the beeps. I had to use Internet Explorer; Firefox wouldn't work. This is what I found:
Single, Short Beep - Indicates that any operations sequence has
begun OR that the door has been successfully locked or unlocked
OR that the sliding cover has been left open for more than ten
seconds.
Single, Long Beep - Indicates that programming operation was
successful
Short, Double Beep - Indicates that individual fingerprint user
deletion sequence has begun.
Long Double Beep - Indicates that Delete All programming was
successful
Four Beeps - Indicates unsuccessful enrollment/unsuccessful
verification attempt OR BioAxxis® BD1 was improperly installed
(see Installation Guide).
Six, Short Beeps - Low battery alert, change batteries
The link to download this file is here:
http://www.axxisbiometrics.com/images/upload/File/pdfs/BD1_Complete_User_Manual.pdf
This is a PFD file, requiring that you have Adobe Reader installed on your computer to view it.
This is a link to AxxisBiometrics webpage, which has a toll-free help number blasted across it, if all else fails:
For a $250 lock, if you the beep codes I supplied you doesn't answer your question, I wouldn't hesitate to call them up. Good luck!
Jul 24, 2011 | Deadbolt Bioaxxis Bd1 Biometric...
The alarm is setting off an alarm with in the lock itself? what does that mean?
seconds.
successful
successful
For a $250 lock, if you the beep codes I supplied you doesn't answer your question, I wouldn't hesitate to call them up. Good luck! (duplicated to clear both requests for help)
I used csorb's instructions to reprogram a master key for my 2000 Lexus RX300. The ignition works perfectly, but the doors don't lock or unlock.
Hi!!
I believe your alarm is in the PASSIVE MODE, here is how it works.
PASSIVE MODE Setting (Arming) Anti-Theft System The system will automatically set 30 seconds after following methods are performed: Remove ignition key from ignition switch. Exit vehicle, and close all doors. After performing this, anti-theft indicator on left side of instrument panel will light continuously for about 30 seconds. After 30 seconds, anti-theft indicator will blink once per second. When system is set, doors cannot be locked or unlocked using door lock control switch.
CANCELING THE ALARM AND REPROGRAMING MAY SOLVE YOUR PROBLEM.
Canceling Anti-Theft System Setting (No Alarm) When system is set (armed), but alarm is not sounding, use one of following methods to cancel system setting:
  • Unlock left or right front door using key.
  • Unlock all doors using remote keyless entry system.
  • Insert key in ignition switch and turn to ON position (this is operative only when anti-theft system has not been triggered).
HERE IS HOW TO REPROGRAM THE ALARM IN CASE YOU NEED TO RESET IT.
PROGRAMMING
PASSIVE MODE NOTE:Initial mode is passive mode off. If there is a different signal in middle of programming, signal is invalid.
Programming Passive Mode Off
  • Remove ignition key from ignition key cylinder. Ensure all doors (including back door) and engine hood are closed and unlocked. Perform all of following methods within 30 seconds:
  • Lock or unlock any door with key or remote keyless entry system.
  • Open driver door.
  • Lock and unlock driver door lock knob 3 times.
  • After performing this, system should start force lock after 2 seconds. Perform all of following methods within 20 seconds:
  • Unlock driver door lock knob.
  • Close and open driver door 2 times.
  • Lock and unlock driver door lock knob.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be off.
Programming Passive Mode On
  • Remove ignition key from key cylinder. Ensure all doors, engine hood and luggage compartment door are closed and unlocked. Perform all of following methods within 30 seconds:
  • Open driver door.
  • Close and open driver door 4 times.
  • After performing this, system should start force lock after 2 seconds. Passive mode should now be on.
If you need further assistance, please provide an email address to send more info on your security system
Good Luck!! A 4 THUMBS UP rating would be greatly appreciated for this solution. Thank you for using FixYa!!
Mar 01, 2011 | Lexus RX 300 Cars & Trucks
I changed battery and now it dosnt work
You lost your program of the key module follow these instructions.
To Program a Remote for a VW
Put your good key in the ignition and turn to "ON", do not start the engine. Make sure all the remotes you want to use are present because they have to be programmed at the same time.
- Close the door and insert key #2 into the driver's side lock. Lock the door.
-Within 5 seconds of locking the door, press unlock 2 times on the new remote, key #2.
-(if this is remote #3, press unlock 3 times. if this is remote #4, press unlock 4 times).
-If there's a chirp or beep do not press it again. This means that the car has recognized the new keyless entry remote.
- Repeat with other remote or unlock the car and turn off - done.
Mar 23, 2010 | 1996 Jaguar Vanden Plas
How do I reprogram the 2004 Pontiac Vibe key fob?
To begin programming, follow the procedure.
  1. Set the following conditions: • Ignition off and ignition key out of cylinder. • All doors closed except drivers door. • Drivers door is unlocked.
  2. Insert and remove the key from the ignition switch twice within 5 seconds.
  3. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and remove it.
  4. After the above operations, close and open the driver door twice within 40 seconds. Then insert the key into the ignition key cylinder and close the door.
  5. Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1to5 times to select desired mode. • 1 time for add mode • 2 times for rewrite mode • 3 times for confirmation mode • 5 times for prohibition mode
  6. Remove the ignition key from the key cylinder.
  7. After selecting a mode, the integration relay automatically performs the power door LOCK to UNLOCK operation within 3 seconds to inform the selected mode. • In the confirmation mode, when the operation is performed twice, it directs that 2 types of recognition codes have been registered. • In the confirmation mode, if the number of the registration code is 0 the LOCK to UNLOCK operation is automatically performed 5 times. • If the prohibition mode or confirmation mode is selected, registration procedure is completed. • If the add or rewrite mode has been selected, the doors will lock-unlock once or twice at 1 second intervals, once for add mode or twice for rewrite mode. • If the confirmation mode is selected, the doors will lock-unlock 0 to 2 times at 2 second intervals to inform the technician of the number of transmitters programmed. • If the prohibition mode is selected, the doors will lock-unlock 0 to 5 times at 1 second intervals.
  8. Registering new recognition codes for the add mode or rewrite mode. • Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and UNLOCK buttons on the transmitter simultaneously for 1.0 to 1.5 seconds. Within 3 seconds after the previous operation, press either one of the buttons for more than 1.0 seconds. • Within 3 seconds after the transmitter has been turned off, the LOCK and UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly. In case the LOCK and UNLOCK operation is performed twice, the registration of recognition code has failed. Perform the registration procedure from the beginning once again.
  9. Press a transmitter button for 2 seconds. The doors will lock-unlock once at a 1 second interval to inform the technician that the signal has been received from the transmitter. • If the doors lock-unlock once, the transmitter programming has been completed. Go to step 8 to continue programming for additional transmitters. • If the doors lock-unlock twice, the transmitter programming is not complete. Go to step 8 to begin the transmitter programming again.
If any of the following conditions occur during programming, the remote control door lock receiver will return to normal operation:
Jun 11, 2009 | 2003 Pontiac Vibe
Keyless control not work
here ya go follow the steps exactly and it will work and dont forget to rate me please,
* Remote programming
Start with drivers door open, unlocked, and no key in the ignition.
Close and open the driver door twice within 40 seconds.
Turn the ignition switch from LOCK to ON and back once and remove key
Locks should cycle once.
Within 40 seconds press the LOCK and UNLOCK switches on the transmitter switch simultaneously for 1.0 – 1.5 seconds.
Within 3 seconds after the previous operation, press either one of the switches for more than 1.0 seconds.
Within 3 seconds after the transmitter switch has been turned OFF, the LOCK–UNLOCK operation will be automatically performed once if the registration of the recognition code of the transmitter is completed correctly.
In case the LOCK–UNLOCK operation is performed twice, the registration of recognition code has failed.
Feb 03, 2009 | 2005 Toyota Camry Solara
Why does my key fob only open drivers door
this how a dealer does it:
DOOR CONTROL TRANSMITTER
REGISTRATION
1. REGISTRATION OF RECOGNITION CODE
HINT:
 The add mode is used to retain the already registered codes while registering a new recognition code.
This mode is used when adding a transmitter. If the number of the registered codes exceeds 4, the previously
registered code will be correspondingly erased in order, starting from the first registered code.
 The rewrite mode is used to erase all the previously registered codes and register only new recognition
codes. This mode is used when exchanging the transmitter or the door control receiver for new one.
 The prohibition mode is used to erase all the registered codes and cancel the wireless door lock function.
Use this mode when the transmitter is lost.
 The confirmation mode is to confirm how many recognition codes have already been registered before
an additional registration of a recognition code.
 All the following registration procedures must be performed in order continuously.
(a) The vehicle should be in the following conditions.
(1) The key is not inserted in the ignition key cylinder.
(2) Driver’s door is OPENED. (The other doors are CLOSED)
(3) Driver’s door is UNLOCKED.
(b) Perform the following operations to select the desired mode.
(1) Insert and remove the key from the ignition switch twice within 5 seconds.
(2) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
(3) After the above operations, close and open the driver door twice within 40 seconds. Then insert the
(4) Turn the ignition switch from LOCK to ON and back to LOCK at approximately 1 second interval 1
to 5 times to select a mode.(2 times for rewrite mode) Then remove the key from the ignition key cylinder.
(5) After selecting a mode, the integration relay automatically performs the power door
LOCK-UNLOCK operation within 3 seconds to inform the selected mode.
(c) Register the new recognition codes :
(1) Within 40 seconds after the add mode or the rewrite mode has been selected, press the LOCK and
UNLOCK switches on the transmitter switch simultaneously for 1.0 - 1.5 seconds.
seconds.
(2) Within 3 seconds after the transmitter switch has been turned OFF, the LOCK-UNLOCK operation
completed correctly. In case the LOCK-UNLOCK operation is performed twice, the registration of
(3) If the multiple transmitter to be registered, repeat step (c) within 40 seconds after the previous registration.
this is why the dealer charges for this
Jun 19, 2008 | 2003 Mini Cooper
Weiser Lock POWERBOLT ELEC DEADBOLT Logo
606 people viewed this question
Top Weiser Lock Locks & Locksmithing Experts
Jim Goldsmith
Jim Goldsmith
john h
Are you a Weiser Lock Lock and Locksmithing Expert? Answer questions, earn points and help others
