Question about GE Spacemaker JVM1640SJ Microwave Oven
No heat... everything works on the xl1800 but the heat...it will not heat anything up...but everything else works just fine...??
  • 98 Answers
There are 2 fuses inmicrowave 1 for ac input 1 for high voltage transformer that will trigger the magnetron "for heating"
remedy;
uncrew the unit
replace fuse near the transformer this fuse.. usually enclose with plastic casing..
then test..
causes of blown fuse
improper ventilation
Posted on Feb 21, 2008
May Spacemaker XL1800 stop heating food. Was working fine. Then just stop
Is this an over the stove type unit? I have had a few problems with my over the range spacesaver. I think the heat from cooking gets up into the microwave and damages it. The steam from me boiling things on the stove had mine quit heating and I purchased a new one. The parts to replace the faulty ones can be quite expensive over $150.00, so its better to purchase a new microwave.
Feb 24, 2013 | GE Microwave Ovens
MICROWAVE IS NOT HEATING--EVERYTHING IS WORKS FINE
If the magnetron was making louder noises prior then replace the magnetron. While the cabinet is open make sure to look for burned wires, check the continuity of thermal cutoffs, and check the main circuit-board for burned traces or components. The relays in most electronics are known for arcing (spot welding) and staying in the wrong position. Tap them hard with the back end of a screwdriver.
You may have to replace the capacitor as well. During all of this use safe electrical practices by having the power cord unplugged. The capacitor could still have a high charge on it so be careful.
Feb 02, 2013 | GE XL1800 1100 Watts Microwave Oven
It worked fine for pizza two nights ago and does not heat anything. The sensor does not work and food is not heating
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 28, 2010 | GE XL1800 1100 Watts Microwave Oven
Ge xl1800 not heating and sounds a little different everything else is working fine...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101][][][
Jul 11, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, no heat and a humming noise.
magnetron problem DON'T KNOW IF WITH FIXING - WOULD LIKE TO KNOW MYSELF
May 02, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Not heating up anything
Tat would be a magnetron problem. The magnetron is what provides the heat
Apr 30, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
No Heat but everything else works
Magnetron and diode most likely. Need more info.
Nov 02, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker XL1800 (jvm1850sh06) problem
Use a hair blow dryer to dry out the underside of the microwave. After you are convinced that it is dry you may operate it again.
That said, if it still is acting up read this:
When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician.
Aug 06, 2009 | Microwave Ovens
GE Spacemaker XL1800 Microwave No Heat
Microwave Oven Basic Troubleshooting Tips
heatman101
yuetywe
Jul 19, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE XL1800 will not heat
sounds like the twt is bad (the traveling wave tube) that is quite expensive. Unfortunately your solution is probably to buy a new one.
Jan 22, 2009 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
314 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
